Thread started 04 Apr 2012 (Wednesday) 12:47
Why use back button focus?
Vendee
Apr 04, 2012 12:47 |  #1
I keep reading people recommending the use of back button focus. What are the advantages of this? I normally use centre point focus using the shutter button and recompose if needed before pressing the shutter all the way.
| EOS 6D| EOS 3 |EF 24-105mm f/4L|EF 70-200mm f/4L IS |EF 40mm f/2.8 STM | EF 50 f/1.8 II | Sigma 35mm f/1.4 Art | Pentax MX |Pentax ME Super|Pentax K1000|Kiev 4A|Yashica Electra 35 GTN|Yashica 24|Ricoh GR III
My stuff:- www.giverin.co.uk (external link)
yourdoinitwrong
Apr 04, 2012 12:55 |  #2
Vendee wrote in post #14209035 (external link)
I use it for sports with AI Servo. That way I can continuosly track my subject and then take the shot(s) when needed. It is much easier to do that than trying to keep the shutter half-pressed when I'm moving the camera around. It took a little while to get used to but it is the only way I shoot now. There is also the added benefit of people not wanting to use my camera either because it won't focus for them with the shutter button!
5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
Full List
bsmotril
Gallery: 11 photos
Joined Feb 2006
Apr 04, 2012 12:56 |  #3
When shooting action sports, it allows you to track focus of a moving subject prior to locking exposure with the shutter half press. This has two big advantages. In some indoor sports venues, lighting is not even so you don't want to meter until you actually take the shot. Second, tracking AF prior to taking the shot gives the camera time to calculate a focus solution and will get you an almost instant shutter release if you have your custom functions set to give priority to achieving focus versus release shutter. This can mitigate a delay of sometimes half a second or so until the shutter releases if AF is on the shutter button because the camera only begins calculating the AF point when you half press, or fully press the shutter. For shooting indoor sports like swimming, gymnastics, basketball, roller derby, etc, back button focus will get your keeper rate up higher than using shutter button AF. It really comes into it's own on circular or oval track sports where the closing velocity vector of a subject coming at you is constantly changing while the subject is in the curved section of the track. Giving the camera time to calculate an AF solution with back button focus in that situation will always get you a much quicker shutter release than pressing the shutter button to take a shot. Add in spotty overhead lighting where you want exposure metered at the moment of shutter press and not before, and you have the perfect back button AF environment. As stated above, Servo AF is a given for it to make sense.
Galleries: http://www.flickr.com/​photos/smopho/ (external link) --- http://billsmotrilla.z​enfolio.com/ (external link)
Leopold ­ Stotch
Joined Jul 2011
Apr 04, 2012 12:56 |  #4
That works fine in one-shot AF, but if you use Ai servo the camera will continue to focus while the shutter button's halfway down - making recomposition a PITA. With the two functions on separate buttons, it becomes much easier with continuous AF. That's why sports shooters often use the back button.
Edit: ninja'd twice
50D | 5D | Tokina 12-24 f/4 | 24-85 f/3.5-4.5 | 24-105 f/4L | 50 f/1.8 | 70-200 f/4L | Metz 50 AF-1
Reviews & Articles (external link) | 500px (external link)
PLLphotography
with the TF
Apr 04, 2012 13:00 |  #5
I like back button focusing because I set my shutter half-press to lock in an exposure meter, and can then recompose, focus with back-button, and depress the shutter to take a pic. I typically keep my camera on spot metering.
Phillip - phillipwardphotography​.com (external link) | Instagram (external link) | Donate to POTN
LeeRatters
Apr 04, 2012 13:08 |  #6
For me, because focusing & metering/exp lock are two seperate functions so have them on two seperate buttons :)
>> Flickr << (external link)
>> Instagram<< (external link)
sonnyc
Joined Jun 2005
Apr 04, 2012 13:22 |  #7
With the back focus, you can leave it on AI Servo all the time.
Press and release ~ one shot
Press and hold ~ tracking
Sonny
Mike ­ K
Joined Apr 2001
Apr 04, 2012 13:22 |  #8
https://photography-on-the.net/forum/showthre​ad.php?t=46965
http://www.learn.usa.c​anon.com …ckbutton_af_art​icle.shtml (external link)
http://www.outbackphot​o.com …hnique/essay06/​essay.html (external link)
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Apr 04, 2012 13:31 |  #9
Another vote for BBF - but then I like to shoot team sports and it is great for that, as explained above.
On a related note you might want to look at customising the mini-joystick to move/select AF points. That can save on having to recompose as you frame the shot and use one of the outer AF points to focus.
Dan Marchant
PLLphotography
with the TF
Apr 04, 2012 13:32 |  #10
Dan Marchant wrote in post #14209251 (external link)
I've got this setup as well. pretty quick to change your active AF points, or just press the joystick and select all.
Vendee
Apr 04, 2012 16:08 as a reply to  @ PLLphotography's post |  #11
Thanks for the info guys :cool:
rick_reno
Apr 04, 2012 17:01 |  #12
I like it because that's where my thumb sits and it makes it handy.
jase1125
Apr 04, 2012 17:51 |  #13
What all those other people said ;)
Jason
sempaidavid
Apr 04, 2012 18:03 |  #14
bsmotril wrote in post #14209088 (external link)
This is one of the best explanations I have ever read of the advantages of back button focus. Thanks for taking the time to write this.
5D mkIII, 1D mkIV, Tokina 16-28 f/2.8, EF 24-70L, EF 70-200 f/2.8L II IS, EF 100-400L, EF 85 f/1.8, Sigma 50 f/1.4, EF 24-105
http://www.davidcostap​hotography.com (external link)
kf095
Out buying Wheaties
Gallery: 64 photos
Apr 04, 2012 18:43 |  #15
Why? Because it works much more better. If you are advanced photographer :)
14,479 views & 0 likes for this thread, 27 members have posted to it.
1454 guests, 128 members online
