Thread started 05 Apr 2012 (Thursday) 17:15
Flare and full frame lenses
colintf
Joined Apr 2012
Apr 05, 2012 17:15 |  #1
Hi,
on a 5d and using a UV filter, is one of the following better at resisting flare than the others? I was at about 18 mm
16-35Lf2.8 mk2
17-40L
24-105L
I was trying the 16-35 and was suprised to see the flaring. Maybe I am better off with one of the others? The lens hood was being used at the time
Many thanks in advance.
Saint728
Apr 05, 2012 17:46 |  #2
Get rid of the UV filter and you will see less flair. I use the 17-40mm and 16-35mm and they both have very little flair shooting directly into the sun.
Take Care,
Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Click Here To See My Gear
Click here to see my Flickr (external link)
http://www.runryder.co​m/helicopter/gallery/9​019/ (external link)
colintf
Joined Apr 2012
Apr 05, 2012 17:51 as a reply to  @ Saint728's post |  #3
many thanks Patrick.
I prefer the safety of the filter to protect the lens. In a safer environment I will give it a go without the filter on.
Carlwashere
Joined May 2011
Apr 05, 2012 18:05 |  #4
What brand of filter? Effects will be much less apparent with higher quality filters than cheaper ones.
-Canon T2i- -Tammy 17-50 non-VC- -50 f1.4- -100 f2.8 macro- -85 f1.8-
-Pentax SP1000- -SMC Takumar 55 f2- -Takumar 28 f3.5- -Vivitar 135 f2.8-
ejenner
Gallery: 67 photos
Joined Nov 2011
Apr 06, 2012 09:53 as a reply to  @ Carlwashere's post |  #5
They are all pretty good with the 24-105 being perhaps slightly worse.
Personally I also keep the UV on (B+W MRC), but when shooting into/near the sun and/or seeing flare on my shots I do remove it. Sometimes it helps, sometimes not.
Edward Jenner
5DIII, 7DII, M6, GX1 II,M11-22, Sig15mm FE,16-35 F4,TS-E 17,Sig 18-250 OS Macro,M18-150,24-105,T45 1.8VC,70-200 f4 IS,70-200 2.8 vII,Sig 85 1.4,100L,135L,400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
colintf
Joined Apr 2012
Apr 06, 2012 13:13 as a reply to  @ ejenner's post |  #6
thanks for the advice.
Hoya Pro UV filter (quite thin)
:cool:
kf095
Apr 06, 2012 13:24 |  #7
UV filter is totally useless, it cost more but still modifies light.
Use digital protective filters.
I have 17-40 on 5d with protect filter and hood. No flare.
Old Site (external link). M-E and ME blog (external link). Film Flickr (external link). my DigitaL and AnaLog Gear.
colintf
Joined Apr 2012
Apr 07, 2012 13:15 |  #8
kf095 wrote in post #14220974 (external link)
many thanks for the tip :cool:
ed ­ rader
"I am not the final word"
Apr 07, 2012 13:53 |  #9
colintf wrote in post #14216389 (external link)
Hi,
16-35Lf2.8 mk2
17-40L
24-105L
All those lenses are very flare resistant. Don't put any stock into the filter argument. There are times when anyone except maybe an idiot will or won't use a filter.
5D4, 80d, 16-35L III, 24-70L II, 70-200L F4 IS II, 100-400L II, sigma 15mm FE, 35mm ef-s macro, tc 1.4 III, 430exII, gitzo 3542L, gitzo GM4562, markins Q10, markins Q3, kirk, really right stuff, sirui
colintf
Joined Apr 2012
Apr 07, 2012 15:39 |  #10
ed rader wrote in post #14226084 (external link)
so do you think changing from a UV filter to a plain Protector filter will help me? thanks :cool:
David ­ C
Apr 07, 2012 15:52 |  #11
Examine how your lens hood is positioned when using. If not using a hood, try one, or else shade the lens with your hand from sun that could be reflecting off the front of the lens.
Wilt
Apr 07, 2012 16:21 |  #12
colintf wrote in post #14226464 (external link)
It will not make any difference in the world whether you use a UV filter or use a 'clear, protective' filter.
If both are good filters (passing 99.5%+ of the light), under most circumstances you will not be able to see their presence. Under very demanding circumstances, filters will always reveal their presence, as even 0.5% is light which bounces around as visible flare (reflections) that can be seen against dark backgrounds.
So a wise person uses good quality filters for situations where salt spray and blowing sand or goopey toodler fingers need to be kept off the front element (less cleaning, less wear on coatings = more pristine lens at resale time), and they take off good quality filters when demanding situations arise.
A pendulum swings thru many intermediate positions in between the two extremes of position. Same for position regarding use of filters.
colintf
Joined Apr 2012
Apr 07, 2012 16:25 |  #13
Wilt wrote in post #14226590 (external link)
It will not make any difference in the world whether you use a UV filter or use a clear 'protective' filter.
thankyou for the explanation. I am on a very steep learner curve with the 5d. I rarely got flare issues using the 7d. I need to be brave and take the filters off at times by the sounds of it. :cool:
colintf
Joined Apr 2012
Apr 07, 2012 16:26 |  #14
David C wrote in post #14226499 (external link)
Lens hood being used. I'll try the extra shading with hand and see how that goes. thanks for the tip :cool:
Wilt
Apr 07, 2012 16:30 |  #15
colintf wrote in post #14226610 (external link)
Unless you are getting by economically by using one of the generic one-size-fits-all-FL lens hoods, it is unlikely that your hand will reduce any further the problems induced by a bright source of light falling upon the lens, as the manufacturer designed the hood for max protection.
Admittedly, APS-C cameras see 60% less area than FF, so there is that 40% margin of improvement, since a hood designed for 100mm lens on FF really ought to be a hood designed for 160mm (FOV on FF), when the same lens is mounted on APS-C body since the framed area is smaller.
2,623 views & 0 likes for this thread
Latest registered member is justinelisz
401 guests, 252 members online
