Hi,
Can someone show me the way to set the WB for all the pictures based on the inital WB grey card shot? I know how to perform on a single raw picture. But, I am unable to set WB for all other photos.
chenga732 Senior Member 465 posts Likes: 4 Joined Jan 2011 More info | Apr 11, 2012 19:01 | #1 Hi, Xsi|24-105mm f4.0|70-200mm f4.0|85mm f.18
Apr 11, 2012 19:21 | #2 chenga732 wrote in post #14250212 Hi, Can someone show me the way to set the WB for all the pictures based on the inital WB grey card shot? I know how to perform on a single raw picture. But, I am unable to set WB for all other photos. Thanks Set WB on one pic. Then hit the copy button and click the WB checkbox. Go back to library module, select other pictures, and hit ctrl-shift-V to paste the settings from the first pic to the rest.
Apr 11, 2012 20:17 | #3 mike_d wrote in post #14250332 Set WB on one pic. Then hit the copy button and click the WB checkbox. Go back to library module, select other pictures, and hit ctrl-shift-V to paste the settings from the first pic to the rest. Thanks for the info. Silly question, where can I find the copy button. Xsi|24-105mm f4.0|70-200mm f4.0|85mm f.18
crn3371 Cream of the Crop 7,198 posts Likes: 2 Joined Mar 2005 Location: SoCal, USA More info | Apr 11, 2012 20:23 | #4 A quick search on google for batch processing in Lightroom 3 yields plenty of tutorials and YouTube videos.
Apr 11, 2012 20:27 | #5 thanks all Xsi|24-105mm f4.0|70-200mm f4.0|85mm f.18
Apr 11, 2012 20:45 | #6 chenga732 wrote in post #14250594 Thanks for the info. Silly question, where can I find the copy button. While in the Develop module, it'll be a button on the left, just above the filmstrip. It can also be accessed by ctrl-shift-c.
tonylong ...winded More info | Apr 11, 2012 20:57 | #7 Another quick approach: in the Develop Module, select your "target" pic and the rest of your set. So, with the target pic active/displayed, press the Ctl/Cmd button. At the lower right you will see that the Sync button has changed to Auto Sync. Click that button to activate the feature. Tony
FlyingPhotog Cream of the "Prop" 57,560 posts Likes: 178 Joined May 2007 Location: Probably Chasing Aircraft More info | Apr 11, 2012 21:09 | #8 You can also right-click your target image and choose Develop Settings and you'll get a fly out to copy your settings. Jay
tonylong ...winded More info | Apr 11, 2012 22:15 | #9 Heh! Chenga, this is a really good time to encourage you to get at least one of the three Lightroom "primers". There are three excellent books by Victoria Bampton, Scott Kelby and Martin Evening. If you get one or more of those and work your way through it you will know more about Lightroom than you could imagine! Tony
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Apr 12, 2012 03:38 | #10 The area of batch editing is one in which the LR designers really went overboard. There are like 6 different ways of doing the same thing. I use the "Previous" button a lot and Cntrl+A/Sync only sometimes for a single parameter. Elie / אלי
imjason Goldmember 1,667 posts Likes: 3 Joined Nov 2010 Location: Bay Area, CA More info | Apr 12, 2012 03:45 | #11 you might consider updating to 3.6 as it fixes some bug such as the adjustment brush and automasking. Canon gear: EOS M, Canonet QL17, SX230HS, S95, SD1200IS
Apr 13, 2012 20:01 | #12 Thanks all for the reply. Will pickup a book recommend by TonyLong. Xsi|24-105mm f4.0|70-200mm f4.0|85mm f.18
| Latest registered member is semonsters 1505 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
