Will this work for Volleyball, Track & Basketball on a canon 450 XSi
70-200mm f/2.8 EX DG APO OS HSM for Canon
Or do I need to look at something else
Lone-eagle Senior Member 269 posts Likes: 2 Joined Oct 2007 More info | Apr 12, 2012 12:01 | #1 Will this work for Volleyball, Track & Basketball on a canon 450 XSi Dale
mrbtd Senior Member 418 posts Joined Nov 2009 Location: Lindenhurst, IL More info | Apr 12, 2012 12:06 | #2 Beach volleyball yes..indoor you are going to need a body with better ISO performance. I am using my 7d at 6400 all the time paired with a 17-55 2.8. Learn to shoot cross court with the 85 1.8 and you will be better off.
MTStringer Goldmember 4,652 posts Likes: 6 Joined May 2006 Location: Channelview, Tx More info | Apr 12, 2012 12:17 | #3 For shooting indoors in high school gyms, I use the 100 f/2. The 85 1.8 will work great also. Just depends on where you have access to shoot from. If the gym is well lit, the 70-200 f/2.8 will work at high ISO.
bikeboynate Goldmember 3,127 posts Joined Aug 2011 Location: San Francisco More info | Apr 12, 2012 12:25 | #4 In my gym I use my 70-200 f/2.8L IS II USM at ISO 3200, SS 400, and f/2.8 on my 5D3. I usually shoot JPEG too since I don't want all my memory taken up by sports. -Nate
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Apr 12, 2012 14:21 | #5 Lone-eagle wrote in post #14253948 Will this work for Volleyball, Track & Basketball on a canon 450 XSi 70-200mm f/2.8 EX DG APO OS HSM for Canon Or do I need to look at something else that lens should work fine
RustyHammer Senior Member 685 posts Likes: 1 Joined Dec 2011 Location: New Orleans / New York More info | Apr 12, 2012 18:35 | #6 MT Stringer wrote in post #14254021 For shooting indoors in high school gyms, I use the 100 f/2. The 85 1.8 will work great also. Just depends on where you have access to shoot from. If the gym is well lit, the 70-200 f/2.8 will work at high ISO. Like the reader above posted, most of the time I have to shoot at ISO 6400 at f/2.2 - 2.5. ... that!
kin2son Goldmember 4,546 posts Likes: 3 Joined May 2011 Location: Sydney, Australia More info | Apr 12, 2012 18:47 | #7 Permanent banUpgrade the body along the way, maybe a second hand 7D? The 450D is noisy pass iso800 and if this is indoor volleyball, the body will drag the lens down for sure. 5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
Tug08 Member 61 posts Joined Feb 2012 More info | I have had good luck in most gyms with the ef 85mm f/1.8. I have a XTi
| Latest registered member is MWCarlsson 604 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
