rang wrote in post #14261363
Actually it's a bayonet style receiver. The weird part is that I believe if you were to order the Canon mfg'd filter adapter and the Canon mfg'd hood...they are mutually exclusive usage wise.
I just ordered a cheap filter adapter made by Vivitar which then gives you a standard 67mm threaded end and screwed on a standard 67mm threaded deep 3 position rubber hood which in turn has standard 67mm threads so you can use the hood against glass with a flash with no flash back glare and surprise you can then mount standard filters as well.
So for macro I use the Canon 500D CloseUpFilter doublet and zoomed out to 840mm you get forensic type shots of bugs...huge eye patterns+leg hair and fuzz hairs on butterfly bodies at the SD Wild Animal Park.
Plus using the Canon CloseUpFilter...you can use that on any other lens with step up/down rings.
Yeah, the filter adapters are bayonet mounted to the camera. However trying to mount a filter directly to the lens, as OP was asking about, will bring about the problem I described. The grooves in the front of the lens mount aren't really threads, though people have forced filters onto them, eventually leading to the problem I described.
