Thread started 12 Apr 2012 (Thursday) 15:29
Step Up Ring
No ­ One
Apr 12, 2012 15:29 |  #1
Beginner's Question:
I am shopping for a Neutral Density filter.I am using an 82MM size lens.Anyway,what does a Step Up 77-82MM Ring mean?
Thanks.
Indecent ­ Exposure
Apr 12, 2012 15:43 |  #2
A step-up would allow a 77mm filter to mount into a 82mm lens. Why you would want to do this I have no idea.
- James -
www.feedthewant.com (external link)
500px (external link)
Gear List and Feedback
Voaky999
Gallery: 810 photos
Joined Nov 2010
Apr 12, 2012 15:57 |  #3
A 77-82 lens to filter step up ring means you can use an 82 mm filter on a 77 mm lens
Don
"Knowledge is Good" Emil Faber
No ­ One
Apr 12, 2012 15:58 |  #4
Indecent Exposure wrote in post #14255237 (external link)
Beginner's Question Again:
What Would be wrong if you do that?
Again,Thanks.
steelbluesleepr
Apr 12, 2012 16:44 |  #5
No One wrote in post #14255295 (external link)
Again,Thanks.
It would only have a 77mm opening on the front of your lens that normally has a larger, 82mm front element. This would cause significant vignette in your images.
What you are talking about, though is an adapter to fit an 82mm filter on a 77mm forward element, which is common practice for those with multiple lenses and only want to buy one size filter.
-Jayson- my flickr (external link)
In the bag: 5D mark II+Vello grio/10d+grip/Canon 17-40L/Canon 28-135/Canon 50 1.8/Canon 35-80 Macro Conversion/Vivitar 135 2.8 M42/Vivitar 28 2.5 M42/Yongnuo YN460II x3/Yongnuo RF-602 x3
T2i4me
Joined Jun 2011
Apr 12, 2012 18:14 |  #6
Using the reduction rings allows for use of larger filters (usually CPL's and ND's) on smaller lenses, this saves money by using one filter for several lenses, but the draback is that on some lenses the hood may not fit with the larger filter attached. I typically try to stay within 5mm in size otherwise it getts rather odd looking.
-- Eric --
6DMKII - 5DC - 80D - 70-200 F2.8 IS III - 100-400 L IS - 70-200 F4 L - 17-40 L - EF 85 1.8 - EF-S 10-22 - EF-S 15-85 IS - EF-S 18-135 USM IS - EF-S 60 macro - 430EX II
bratkinson
Joined Dec 2011
Apr 12, 2012 18:19 as a reply to  @ steelbluesleepr's post |  #7
Several companies make both step-up and step-down rings.
I use step-up rings to accomodate my 82mm CPL on my 77mm and 72mm filter-size lenses. I just double-step-down for the 72. This way, I only need one CPL to work on all my lenses. One lesson I learned was not to tightly screw the rings together...taking them apart is very difficult. Using the hood on the 72mm size lens with the rings on won't fit. No surprise there.
A step-down ring allows a too-small filter to be used on a larger filter-size lenses. The issue immediately becomes one of vignetting. However, on a 1.6 crop body, it might not be too noticeable, if used on a full-frame (EF) lens. The solution would be to crop out the dark areas in post processing.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." General George S Patton, Jr 1885-1945
Jon
Joined Jun 2004
Apr 12, 2012 18:36 as a reply to  @ bratkinson's post |  #8
Wrong. That would be a step-down ring.
Voaky999 wrote in post #14255284 (external link)
Correct. A step-down would be a terrible idea since, as steelbluesleepr said, you'd be "choking" the lens. It's like using a telephoto lens hood on a wide angle lens. You narrow the available field of view. So part of your picture would be the "step-down" ring.
Jon
Cocker Spaniels
Indecent ­ Exposure
Apr 12, 2012 18:39 |  #9
bratkinson wrote in post #14256007 (external link)
This is right.
- James -
Indecent ­ Exposure
Apr 12, 2012 18:42 |  #10
Jon wrote in post #14256081 (external link)
Yeah. Apparently I can't walk and chew gum.
- James -
2,237 views & 0 likes for this thread, 7 members have posted to it.
Step Up Ring
2266 guests, 125 members online
