Anyone know what the Φ-symbol means that appears on most (at least 350D, 20D & 1D) bodies?
Dew Senior Member 395 posts Joined Apr 2005 Location: UK More info | Dec 02, 2005 06:47 | #1 Anyone know what the Φ-symbol means that appears on most (at least 350D, 20D & 1D) bodies? EOS 1D MkIV | EOS 40D | BG-E2N | EOS 30D | BG-E2 | EF 50mm f/1.4 USM | EF-S 17-55mm f/2.8 IS USM | EF 16-35mm f/2.8L II USM | EF 70-200mm f/2.8L IS USM | EF 300mm f/4L IS USM | EF 400mm f/4 DO IS USM | Extender EF 1.4x II | Tamrac Model 5575 Expedition 5
tiha Senior Member 960 posts Likes: 24 Joined Feb 2005 Location: 44°49′14″N 20°27′44″E More info | Dec 02, 2005 06:52 | #2 It's indication of sensor (or film on film cameras) plane. I think distance on lens is distance from subject to sensor plane. EOS 5D, EOS 30D, EOS 3, PowerShot G6
PhotosGuy Cream of the Crop, R.I.P. More info | Dec 02, 2005 06:55 | #3 I think that mark shows the sensor/film location for people who measure distance to calculate exposure factors for close-ups. It's not as important today as it was when we only had film. FrankC - 20D, RAW, Manual everything...
tiha wrote: It's indication of sensor (or film on film cameras) plane. I think distance on lens is distance from subject to sensor plane. Well - you learn something new everyday! EOS 1D MkIV | EOS 40D | BG-E2N | EOS 30D | BG-E2 | EF 50mm f/1.4 USM | EF-S 17-55mm f/2.8 IS USM | EF 16-35mm f/2.8L II USM | EF 70-200mm f/2.8L IS USM | EF 300mm f/4L IS USM | EF 400mm f/4 DO IS USM | Extender EF 1.4x II | Tamrac Model 5575 Expedition 5
Az2Africa Goldmember 3,481 posts Likes: 6 Joined Mar 2005 Location: North Scottsdale, Arizona USA More info | [I]I saw this being used to set up the camera on a pano tripod head. They said it was needed to keep everything on the same axis when panning and stitching photos together. Called the nodal point. Correct me if I am wrong here. "If you're not living on the edge. You're taking up too much room !"
PhotosGuy Cream of the Crop, R.I.P. More info | Dec 02, 2005 07:39 | #6 If I remember right, the nodal point will be found somewhere in the middle of the lens. If you rotate the cam around it, you won't see parallax on distant subjects. Do a forum search for pano to maybe find some more info. FrankC - 20D, RAW, Manual everything...
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Az2Africa wrote: [I]I saw this being used to set up the camera on a pano tripod head. They said it was needed to keep everything on the same axis when panning and stitching photos together. Called the nodal point. Correct me if I am wrong here. They were wrong if they called it the nodal point, as the nodal point is a characteristic of the lens. It's the optical center of the lens relative to either the subject (first or front nodal point) or the film plane (second, or rear, nodal point). They may have a table of nodal point distances and be using that (the sensor plane) to precisely locate the nodal point. It's an easy enough matter to explain fuzzily, but a little less intuitive to explain clearly. Jon
pfogle Senior Member 581 posts Likes: 1 Joined Dec 2004 Location: Auckland NZ More info | Dec 02, 2005 08:55 | #8 Hey Photosguy - that's a wicked F setup in your image! Is that the 105/2.5 P Nikkor attached? That's the stuff I grew up on. _______________
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | PhotosGuy wrote: I think that mark shows the sensor/film location for people who measure distance to calculate exposure factors for close-ups. It's not as important today as it was when we only had film. So why isn't the film/sensor plane marker not important anymore just because we went digital? ...Leo
PhotosGuy Cream of the Crop, R.I.P. More info | Dec 02, 2005 09:34 | #10 Is that the 105/2.5 P Nikkor attached? Always nice to meet another Nikon guy! Yes, its the 105 which I'm sure that some people aren't too happy to hear, still rates higher that most "L" lenses! So why isn't the film/sensor plane marker not important anymore just because we went digital? What I said was, "It's not as important today as it was when we only had film." Big difference, no? FrankC - 20D, RAW, Manual everything...
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | PhotosGuy wrote: Always nice to meet another Nikon guy! Yes, its the 105 which I'm sure that some people aren't too happy to hear, still rates higher that most "L" lenses!
What I said was, "It's not as important today as it was when we only had film." Big difference, no? [B]Not as important since we have the histogram, or can pop the card into the computer & check out what's going on in the shot. And what does the histogram have to do with the camera focal plane? Not trying to be argumentative here. Just trying to get a little more enlightened since I've always known what that mark on the camera was, even during my film days, but I personally never had to use it myself. But I figured there must be a practical use for it, othewise why would camera makers bother including it on the body. Very tight close-up work would be one practical use. But I can't see how using a sensor vs film would make any difference as far as using the marker to measure distance from subject to the camera focal plane is concerned. ...Leo
Tonky Member 125 posts Joined Nov 2005 Location: West Mids UK More info | Permanent banPacAce wrote: And what does the histogram have to do with the camera focal plane? Nothing!
Kennymc Goldmember 1,501 posts Joined May 2003 Location: N.E coast of UK More info | Correct it is the exact position of the recording medium film/sensor, used mainly, as also mentioned for extreme close up shots where DOF is measured in millimeters... www.kennymc.com
davidfig we over look the simplest things 3,275 posts Likes: 85 Joined May 2005 Location: Fremont, California USA More info | Dec 02, 2005 12:37 | #14 Focal plane. 5D | 17-40L | Tammy 28-75 2.8 | 28-135 | 50/1.8 | 85/1.8 | Sony A6000 2-Lens Kit | SEL35 1.8 | EF 50 1.8 on NEX as my 75mm 1.8
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | PacAce wrote: So why isn't the film/sensor plane marker not important anymore just because we went digital? ![]() 'In the old days' if you shot macro work and wanted precise reproduction of sizes, you wanted to know exactly where the film was. Given the fact that digital sensors are all over the place in terms of precise size and given the fact that inkject printers are 1200 or 1440 dpi basic resolution, getting a 1:2 exact reproduction seems to be less an issue of how big the image is 'on the negative', and more a question of the output magnification and image sizing in your output software! But the digital world macro consideration is speculation on my part, since I don't try to shoot true macro and have accurately scaled prints. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
| Latest registered member is semonsters 1510 guests, 129 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
