Thread started 18 Apr 2012 (Wednesday) 08:44
Tips for a 1 light setup...
dancinmyazoff
Apr 18, 2012 08:44 |  #1
I just purchased a 580 ex ii and 40" softbox for it. I've used it a few times on ETTL and definitely see an improvement with my images (especially sharpness). I would like to take advantage of more of the settings in the flash (assuming ETTL is like shooting on auto and probably a no-no according to you pros). I keep it directly to the right of my camera, would that be the best place when using only 1 light? I was wondering if anyone could give me any tips when using only 1 light or possibly any reading material/videos that would help me learn some of the settings on the flash. I've read the manual already :D
Canon 40D - Canon 50mm F/1.8 - Canon 55-250mm IS - Canon 580ex ii
Bond_Savingsbond
Apr 18, 2012 09:05 |  #2
Give a search for Zack Arais and his One Light DVD workshop, it's the main reason why I gave lighting a more serious look.
I would suggest putting your flash on manual mode (as well as the camera) to get consistent results when taking photos.
500px (external link)
My website (external link)
CAMTOGRAPHY (external link)
Fuji X-T2, xf35 1.4,xf90mm, Samyang 135 (heavy), Nikon 105(dirty), Vivitar 75-205, Helios 56(Fixed),Pentax 50 F1.9 (dirty)
Sony A7III, 28-70kit(nice lens), Sony20 1.8
Dustin ­ Mustangs
Apr 18, 2012 09:21 |  #3
Learn to control specular highlights and you can make one light look like two.
Check out lighting 101 on the strobist blog for hints on this and just about anything else you might need to know.
60D | 15-85 3.5-5.6 IS | 70-200 4L | 50 1.8 | 100 2.8 macro | 1.4x II | 580EX | 430EX II
FeXL
Apr 18, 2012 09:46 as a reply to  @ Dustin Mustangs's post |  #4
1. Don't be afraid to move that light well off the axis of the camera and have the subject look towards it.
2. Make sure you have plenty of separation (tonewise) between your subject & BG. You usually don't want to lose your subject in the BG. This can be accomplished with sunlight as a key light behind the subject (even through a window) or a lighter/darker BG than the subject (or both).
3. Experiment with reflectors to fill some of the dark shadows on the subject. Remember to position the reflector so it is taking some of the light from the flash & directing it towards the subject. The closer the reflector to the subject, the more fill.
HughR
Apr 18, 2012 10:27 |  #5
Joe McNally's book, Hot Shoe Diaries, has a lot of examples and discussion of one flash off-camera lighting as well.
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
dancinmyazoff
Apr 18, 2012 17:05 |  #6
Thank you for the replies everyone, I will look into the info you gave me. Just to clarify, I only have the flash on ETTL camera isn't on auto I only shoot Manual!
HughR
Apr 27, 2012 13:10 |  #7
dancinmyazoff wrote in post #14288647 (external link)
That's the way I usually do it (although I often use 2 off-camera flashes controlled remotely by the pop-up on my 60D. Yes, ETTL plus M for the camera usually works very well.
Hugh
SJRobbins
Apr 27, 2012 13:13 |  #8
+1 for the strobist blog and DVDs. I haven't read the hotshoe diaries yet, but its definitely on my list.
Canon 60D | Tamron 17-50mm f2.8 nonVC | Canon EF-S 60mm f2.8 Macro | Canon EF-S 55-250mm f4-5.6 IS | Canon 50mm f1.8 MkI | Carl Zeiss Jena DDR 135mm f3.5 | Loads of flashes 'n' stuff
HughR
Apr 27, 2012 14:04 |  #9
SJRobbins wrote in post #14339334 (external link)
Sketching Light, McNally's newest one, is also excellent. Hot Shoe Diaries is probably the one to read first.
Hugh
Kechar
Joined Mar 2011
Apr 27, 2012 14:09 |  #10
Beauty dish! :)
flickr (external link) KCharron.net (external link) - 5D mark III (gripped) | 24-70 2.8 VC | 85 1.8 | 50 1.4 | 70-200 2.8L
[LIGHTING: 3 Einsteins, AB400, CyberCommander, 2 VLMs w/2 spare bats, 2 64" PLMs, 24x32 softbox, 22" BD, grids and diffusers, Avenger stands and boom.]
Tiberius
Apr 27, 2012 14:51 |  #11
dancinmyazoff wrote in post #14286002 (external link)
ETTL does have a place, but if you are shooting in a situation where you are in control of the light, most serious photographers will recommend that you use full manual settings on both the camera and flash. Check the link in my signature for a tutorial on using manual flash.
The biggest advantage with using off camera flash is that it is off the camera. Don't think that there is only one position for it. IF you always have the flash in the same spot, all your photos will end up with the same light. And that would be boring. Try different positions, play around. It's digital, after all, and pixels are free.
My photography website!PHOCAL PHOTOGRAPHY (external link)
bobbyz
Apr 27, 2012 15:29 |  #12
Dustin Mustangs wrote in post #14286167 (external link)
Layman's terms can you please explain what you mean. Also some picture would be real nice.
Fuji XT-1, 18-55mm
dmward
Gallery: 29 photos
Apr 27, 2012 22:25 |  #13
Here (external link) is a lighting exercise on my tutorial site that describes how I emulate north window light with a speedlite, umbrella and reflector.
While using OCF in manual has many advantages there are also compelling reasons for using TTL flash.
For example, you can setup a lighting scheme that includes three groups A, B and C using Canon speedlites. Once you have the A:B ratio and group C set, if you want to change the F stop for shallower DoF all you have to do is change the aperture setting on the lens. ETTL takes care of the exposure for you.
Flash Exposure Compensaton (FEC) can also be used to accomplish this within a three stop range. Six if you work from -3 to + 3 by carefully setting up the lighting.
Toneaero
Apr 27, 2012 23:14 |  #14
I use single light setup for all my on-location shots. ETTL is great if you want fast shots and to capture the moment. Before I got wireless ETTL triggers, I have always used a light meter with the 580exii set on manual. It only took 5-10 seconds to take a reading and adjust your camera accordingly but it ruins the "spontaneousness" of a fun shoot. With wireless ETTL, I can tell my subjects to pose and take the picture without skipping a beat.
We shot this with one 580exii, ETTL, through a Qbox 24.
IMAGE: http://www.tonysouphotography.com/photos/i-wmzN49c/0/L/i-wmzN49c-L.jpg
We shot this with the same exact setup as above but later at night and PP with LR3.
IMAGE: http://www.tonysouphotography.com/photos/i-tv3bdk5/0/L/i-tv3bdk5-L.jpg
Dustin ­ Mustangs
Apr 27, 2012 23:35 |  #15
bobbyz wrote in post #14340106 (external link)
http://strobist.blogsp​ot.com …2-specular-highlight.html (external link)
IMAGE: http://farm1.static.flickr.com/191/496942843_81e731cf53_m.jpg
4,449 views & 0 likes for this thread, 16 members have posted to it.
1006 guests, 171 members online
