Someone wants to buy am image and turn it into a 8'x6' wall mural. I took the shot with my 5D2, and my OOC image is 78''x 52" @ 72ppi. How should I resize it so that it can be printed in that size? Or can I? The original is a large jpg, not a RAW...
Kasrielle Goldmember More info | Apr 19, 2012 15:52 | #1 Someone wants to buy am image and turn it into a 8'x6' wall mural. I took the shot with my 5D2, and my OOC image is 78''x 52" @ 72ppi. How should I resize it so that it can be printed in that size? Or can I? The original is a large jpg, not a RAW...
kirkt Cream of the Crop More info | Apr 19, 2012 16:01 | #2 You should work with the printer to decide if the image you have can be successfully printed at that size, and then let the printer help you convert the image for print to their specifications. When I say "printer" I mean the person or company rep, not a machine. Kirk
Apr 19, 2012 16:40 | #3 Thanks, Kirk! I just got more information from the customer - she is an interior designer and what she wants is a hi res digital download. She will then make a transparency that will be put on glass for a room divider in an office. So what I need to know is how how big to upres the image in photoshop so that she can download what she needs.
tonylong ...winded More info | Apr 19, 2012 16:55 | #4 When you open your image in Photoshop and select View/Actual Pixels then you are viewing it at the resolution of your monitor, which is about 100 pixels per inch (ppi). So for your 4770x3180 pic you are viewing what would be a 47.7x31.8 inch image. Tony
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Apr 19, 2012 17:01 | #5 I wouldn't enlarge it, I'd leave it for the lab to do. Just send them the processed jpeg at the original resolution. If they complain and ask for more pixels then upsize it in PS. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Panoz Member 195 posts Joined Feb 2012 More info | Do nothing. The previous post about leaving it at the original resolution is the best. Do NOT artificially step the dpi using Photoshop. The printer has the best algorithims to make the print the sharpest. Canon G12, Canon 5D MkII, Canon 24-105 L, Sigma 16mm fisheye
Apr 19, 2012 17:28 | #7 Ok - so I can process the original image - not resize, and at 5616 × 3744 pixels that will be ok? Even though the 5616x3744 is at 72ppi?
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Apr 19, 2012 17:35 | #8 The embedded ppi is completely irrelevant. Read this. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Apr 19, 2012 18:59 | #9 Thanks Tim and everyone - I really appreciate it!
Apr 19, 2012 19:11 | #10 tonylong wrote in post #14294604 ...However, you have a problem in that an 8x6 image will require cropping at the long dimension. Your image is at the "native" aspect ratio of your DSLR, 2:3, meaning that if enlarged it would produce a 6x9 image, not a 6x8. So you have to figure out what you really need here! I'm going to crop it and upload it, but I'm having a dementia moment about the dimensions.
tonylong ...winded More info | Apr 19, 2012 19:20 | #11 Well, a 6x8 pic is in the 4:3 aspect ratio. It's a common aspect ratio for P&S/compact digicams. Tony
Apr 19, 2012 19:28 | #12 Thanks, tony - I figured it out...
| Latest registered member is semonsters 1468 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
