Thread started 19 Apr 2012 (Thursday) 17:07
iMac Graphics Problems
Mark-B
Apr 19, 2012 17:07 |  #1
This is on a early 2009 24" iMac. Problems started a few days ago.
Horizontal lines across the screen - three of them approximately 1/3 of the way from the top, in the center, and 1/3 up from the bottom. It also gets progressively darker and more pixelated from the top to the bottom.
Shortly after that, the screen started really distorting after waking from a sleep. It also started showing ghost images on the screen. All of this goes away after about 30 seconds and it goes back to the lines on the screen pictured above.
When doing lots of editing in Aperture, the iMac temperature starts to rise. Once it reaches 120 degrees, part of the screen goes black and the rest of it starts to flicker. This is a short video of the problem: http://flic.kr/p/bND2a​p (external link)
I've done a bit of research on this and the most likely culprit seems to be the graphics card or the logic board. Even if it is the graphics card, it can't necessarily be replaced independently of the logic board. Repair costs could be up to $900.
If repair costs are that high and I choose to buy something else instead, what are you using for your photo editing?
Mark-B
msbphoto.comexternal link
Tony-S
Apr 19, 2012 22:28 |  #2
Hackintosh for the last three years. First a q6600 and now an i7 with ATI 5870/2 gb vRAM. I have a 24" HP H-IPS matte CCFL display.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
Titus213
Apr 22, 2012 22:36 |  #3
Refurbed iMac 27" i7 with ATI Radeon HD 4850 512 MB
But I'm getting interested in this Hackintosh idea.
Dave
Perspiring photographer.
imjason
Joined Nov 2010
Apr 23, 2012 00:47 |  #4
if this happened in the past, you shouldve been suspicious when your gpu or cpu hits 120 degrees. any normally functioning modern computer shouldnt be pass the ~90 degrees even under heavy load. if it does, then theres probably something wrong with the cooling systems, processors, etc. @$900. id consider a replacement machine instead of repair.
Canon gear: EOS M, Canonet QL17, SX230HS, S95, SD1200IS
Non-Canon gear: D600, D5000, D70, XG-2, U20
biffstephens
Joined Apr 2012
Apr 23, 2012 00:55 as a reply to  @ imjason's post |  #5
Does an iMac have a display out? That should tell you if it is the LCD or the video card.
If it's the LCD you can find replacements on ebay usually.
Mark-B
Apr 23, 2012 07:26 |  #6
Apple Store hooked it up to an external monitor and the screen was clear, so they diagnosed it as a bad LCD panel. It's in for repair now.
I never paid attention to operating temperatures before I started having graphics problems, so I don't know if that's normal for my machine or not.
There's no way I could have bought a new comparable PC for under $1000 or another comparable Mac for under $1500. The LCD panel replacement was $500 - ridiculous for a computer just under 3 years old, but it was the least expensive option.
I've had 2 Packard Bell computers, 2 HP computers, 1 Gateway computer, and 1 Mac over the last 18 years. I guess I've been fortunate that this is the first hardware problem I've ever had.
Mark-B
MCAsan
Joined Jun 2010
Apr 23, 2012 22:59 as a reply to  @ Mark-B's post |  #7
i72600K hack with Geekbench score of 14,563.
Numenorean
Apr 23, 2012 23:05 |  #8
I use a custom PC and could replace any of the parts relatively easily at low cost....at least compared to $900.
Titus213
Apr 23, 2012 23:20 |  #9
imjason wrote in post #14311462 (external link)
Unless you're speaking celsius mine hits 120+ regularly.
Dave
2,054 views & 0 likes for this thread, 7 members have posted to it.
1185 guests, 136 members online
