Jonathan Taylor wrote in post #14295378
The first and last time in history that 2 shuttles have been in the same (declassified) place at the same time.
Mike Deep wrote in post #14295652
This is not accurate, I'm afraid. There have been multiple scenes with two shuttles since T&R began, plus several while the program was still active. The most recent instance was in 2008, when a shuttle occupied each launch pad (See STS-400). The most recent instance since T&R began was March 9th.
This is, however, the only time that Enterprise and Discovery have been seen together. I like #2... What a difference several dozen re-entries makes, eh?
Terrific shots Jonathan, but I have to agree with Mike.... I think in the excitement of the moment at the Udvar-Hazy Center there may have been a bit of "artistic license" in the dedication speech. There have, indeed, been many occasions when two, or even three, Orbiters have been in (practically) the same place at the same time. I guess it depends (a bit) on how you define "same place." For example, the three Orbiter Processing Facilities, and the Vehicle Assembly Building, at KSC are all located within a few hundred feet of each other, and there certainly have been many times when the "active" Orbiters where all there together. But Enterprise is special, and she has been separated from the other Orbiters for quite a while, so perhaps the speakers were trying to point out the fact that Enterprise & Discovery had never "appeared together" in the past. I sure wish I could have been there -- thank you for sharing your pictures on the forum!
