Thread started 19 Apr 2012 (Thursday) 20:35
LR4 renaming - file extension case
Artdime
Apr 19, 2012 20:35 |  #1
I played today with file renaming in Lightroom 4 and noticed that not only does LR rename the file, but automatically changes the file extension to upper case (.cr2 becomes .CR2). I would prefer to keep it lower case but did not find an option in the settings.
Does anybody know how to change this?
Thanks!
- Florian
http://artdime.com (external link)
Mark1
Apr 19, 2012 21:06 |  #2
There is no control for it as I dont think it matters any, other than personal querks.
Artdime
Apr 19, 2012 21:40 |  #3
Mark1 wrote in post #14295906 (external link)
Thanks, at least I know I am not overlooking something.
- Florian
tonylong
...winded
Gallery: 60 photos
Apr 19, 2012 21:49 |  #4
I you look at the LR Import dialog , in the File Renaming panel at the upper right side (below File Handling) there is an Extensions option with a drop-down list where you can choose Lowercase, Uppercase, or Leave as-is (the default).
Tony
tzalman
Fatal attraction.
Apr 20, 2012 01:35 |  #5
In the case of CR2 (as opposed to tiff, tif, jpg, or jpeg) I don't think I have ever seen it written in lower case. Certainly not in any file I have obtained directly from any camera.
Elie / אלי
tonylong
...winded
Gallery: 60 photos
Apr 20, 2012 01:40 |  #6
Just to add to my above post:
The Copy as DNG, Copy and Move functions allow you to change the extention case. The Add function does not. And, as far as I can see when you change filenames in the Library module (F2) you can't change the case.
Tony
Mark1
Apr 20, 2012 10:23 |  #7
I took a quick look and didnt see this. I have the file handling. But not a file renaming tab. Maybe I have it turned off somewhere in a control panel.
NinetyEight
"Banned for life"
Apr 20, 2012 14:17 |  #8
All my files get imported into LR after importing to my PC's hard drive using ImageIngester Pro and they all end up with upper case 'CR2' - It doesn't really matter though...
Kev
tonylong
...winded
Gallery: 60 photos
Apr 20, 2012 16:33 |  #9
Mark1 wrote in post #14298349 (external link)
Well, here's a screen shot of the right side of my Import module:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/04/3/LQ_591832.jpg
Image hosted by forum (591832) © tonylong [SHARE LINK]
Tony
Artdime
Apr 20, 2012 20:48 as a reply to  @ tonylong's post |  #10
Yes, I do see the file handling tab in the import module - good to know. But I was only renaming, the photos were already imported.
- Florian
Higginsb
1 post
Joined May 2012
May 26, 2012 13:29 as a reply to  @ Artdime's post |  #11
Unfortunately it matters very much if extensions are upper or lower case.
Not on windows servers, but unix etc server make a strict difference between upper and lowe case extensions (and filenames). So uploading your file as x.JPG and have a x.jpg href in your html code, will give you a file not found. ;)
tonylong
...winded
Gallery: 60 photos
May 26, 2012 14:10 |  #12
In the LR Export dialog you can set your extension to either Upper- or Lowercase, so yeah if you are going to be using Linux/Unix you want to pay attention!
Tony
CanonCameraFan
Joined Sep 2011
Jun 01, 2012 11:01 |  #13
MAC is Unix based and Android is based on someting historic, so do these warnings apply to those enviroments?
I only work in Windows and Android.
EOS 7D w/BG-E7 (3), 550EX (3), 430EX II, Vivitar 285HV, Opteka 6.5mm/3.5, Canon EF-S 10-18/4.5-5.6 IS STM, Canon EF-S 24/2.8 STM, Canon EF 40/2.8 STM, Canon EF 100mm/2.0 USM, Canon EF 70-300mm/4-5.6 L IS USM, Canon 77mm 500D Macro, Tamrac 614 Bag & 787 Backpack, Crumpler 8 MDH, 7 MDH, 6 MDH
http://www.flickr.com/​photos/johnebersole/se​ts/ (external link)
5,383 views & 0 likes for this thread, 7 members have posted to it.
1358 guests, 174 members online
