I know the Maxilite is a lot wider and the HP seems deeper.
I've seen the Fireball thread for the Maxilite
but very little of the High Performance Relector
Could someone describe the major differences between the two?
Thanks in advance!
maxblack I feel like I'm in danger 2,052 posts Likes: 320 Joined Sep 2008 Location: NYC Area More info | Apr 21, 2012 18:13 | #1 I know the Maxilite is a lot wider and the HP seems deeper.
akfreak Goldmember 1,087 posts Joined Jan 2010 More info | Apr 25, 2012 00:20 | #2 Yes I would like to know, When I find out I will post it for you. http://www.speedtest.net/result/1460485335.png
sigmapi Cream of the Crop 11,204 posts Likes: 6 Joined Apr 2010 Location: Los Angeles More info | Apr 25, 2012 00:30 | #3 I am in the same boat I would like to know. The guy from vancouver that shoots snowboarding has the high performance reflector. Don't try to confuse me with the facts, my mind is already made up.
maxblack THREAD STARTER I feel like I'm in danger 2,052 posts Likes: 320 Joined Sep 2008 Location: NYC Area More info | Apr 25, 2012 23:46 | #4 These shots by, "tenoverthenose" are the only examples of the HP Reflector I could find
K.C. Senior Member 319 posts Joined Jun 2010 More info | Apr 28, 2012 16:47 | #5 The Max has a light dispersion angle of 43 degrees and is 40 cm in diameter. The HP 48 degrees and it's 26 cm in diameter. The interior finish is slightly different with the HP being more polished for efficiency. Both are designed for sports photography.
kokakaste2 Goldmember 3,546 posts Joined Jan 2008 Location: Luxembourg More info | Apr 28, 2012 18:38 | #6 Also remember about Maxi Spot, with more polished surface. Oskar (Oscar) - stuff I use- Flickr
K.C. Senior Member 319 posts Joined Jun 2010 More info | Apr 28, 2012 19:09 | #7 Which will cause more specular highlights and a higher efficiency, but the difference is subtle.
kokakaste2 Goldmember 3,546 posts Joined Jan 2008 Location: Luxembourg More info | Apr 28, 2012 19:24 | #8 True, it is different. But it is worth mentioning. Oskar (Oscar) - stuff I use- Flickr
abbadon31 Goldmember More info | Jul 27, 2012 18:21 | #9 Where's the the images of the two in use I AM SHOM
| Latest registered member is semonsters 935 guests, 109 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
