http://www.youtube.com/watch?v=933rE2YDUM8![]()
http://www.youtube.com/watch?v=ybHnfD95TMw![]()
This "issue" is also seen in 5D Mark ii, not just the Mark iii. I was using the Mark ii for years without any real problems though.
mrmarks Senior Member 822 posts Likes: 11 Joined Jan 2010 More info | Apr 24, 2012 08:42 | #1 http://www.youtube.com/watch?v=933rE2YDUM8
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Apr 24, 2012 10:48 | #2 All the more reason to use M and a separate, incidence meter. Alan Myers
KCY Unlocked the hidden 117 point AF 7,170 posts Likes: 8 Joined Jun 2009 Location: I wish I knew... More info | Apr 24, 2012 11:05 | #3 amfoto1 wrote in post #14319444 All the more reason to use M and a separate, incidence meter. ![]() Actually, I just tested one of them and can get my 7D to do the same thing. I'll have to pull out the other 7D, 5DII and 50Ds to see if they all do too, sometime when I have nothing better to do. It's sort of silly.... if there were a lens on the camera instead of a body cap, a tiny bit of light leaking in via the top LCD would be a very small percentage of the total light reaching the metering system. That's a 2/3 stop variance in those vids, which really isn't very much when you consider the total darkness inside the camera. It does sound more serious on 5D3... enough that Canon stopped distribution and is checking them. It wasn't more serious, its just people blew things waaaaaaaaaaaay out of proportion KC - The Circle of PoTN - Member of the UCPC
Apr 24, 2012 18:45 | #4 I tried with my 7D (with a lens on, however) and I was unable to affect the metering enough to see any change in shutter speed when on Av mode. A6000
harcosparky Goldmember More info | Apr 24, 2012 18:48 | #5 KrakenWakes wrote in post #14322426 I tried with my 7D (with a lens on, however) and I was unable to affect the metering enough to see any change in shutter speed when on Av mode. I have two 7D's here and neither of them do it.
bikeboynate Goldmember 3,127 posts Joined Aug 2011 Location: San Francisco More info | Apr 24, 2012 18:48 | #6 KCY wrote in post #14319559 It wasn't more serious, its just people blew things waaaaaaaaaaaay out of proportion I concur. There is no "issue." Unless you're KC and did a whole portfolio on lens cap on shooting. -Nate
HiggsBoson Goldmember 1,958 posts Likes: 4 Joined Jan 2011 Location: Texas Hill Country More info | Apr 24, 2012 18:59 | #7 I put my 7D body cap on my 5Diii and the problem went away. There is a light leak in the 5D3 body caps! A9 | 25 | 55 | 85 | 90 | 135
| Latest registered member is semonsters 1470 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
