Thread started 25 Apr 2012 (Wednesday) 14:14
SD vs CF?
pxchoi
Apr 25, 2012 14:14 |  #1
I always thought that CF cards performed better than SD cards but has that gap been minimized or has it disappeared completely?
The 5D Mark III has slots for CF and SD... which is better? Why?
Patrick Choi
Portfolio (external link) | Flickr (external link) | Facebook (external link)
EOS 7D | 580EX II | 10-22mm f3.5-f4.5 | 17-55mm f/2.8 IS |70-200mm f/2.8L IS II
For Sale: 17-55mm f/2.8 IS | 10-22mm f3.5-f4.5
aegid
Joined Apr 2011
Apr 25, 2012 14:28 |  #2
Since the 5D3 doesn't support UHS1 the SD slot is, depending on your purposes, adequate to insufficient. According to Rob Galbraith (external link) the SD slot gets to a maximum of 20MB/s no matter the max speed of the card. It does let you use eye-fi cards though. If you don't shoot action then it won't affect you but if you do, you may well be on the waiting end of a buffer flush.
5d3,17-40,24-105,24 1.4,85 1.4,70-200 2.8 is ii
tlzimmerman
Joined Jan 2012
Apr 25, 2012 14:41 |  #3
Pros of CF- Faster, bigger, harder to break (more sturdy) more reliable.
SD...smaller, slower, has better connection system (vs pins on CF).
I will have an SD card to have a small jpg backup, raws will go on the CF cards.
5d Mk III - 5d Mk II - 550d - 24-70L - 70-200L IS II - 24-105 F4 L - 85 1.8 - 50 1.4 - 60 Macro - 15 Fisheye
Cody21
Apr 25, 2012 16:07 |  #4
Is there a way (5DM3) to set a custom control that says "When shooting RAW, send to CF", "When shooting JPEG, send to SD" ???
I've enabled the switch between RAW & JPG using the MFN button, but the images all go to my CF Card, and then will "auto-switch" to the SD card when that one is full ... I'd like to keep them separate if possible , I think. (unless that itself presents new problems.)
5DM3 | 16-35mm f/2.8L II USM | 70-200mm IS f/4L | 24-105 f/4L | Sigma 18-50mm f2.8 | Speedlite 430EX
watt100
Apr 25, 2012 16:10 |  #5
tlzimmerman wrote in post #14327634 (external link)
seems like almost every other electronic thing except DSLRs use SD cards and they are significantly cheaper
jwcdds
Gallery: 1924 photos
Best ofs: 8
Joined Aug 2004
Apr 25, 2012 16:10 |  #6
I think you can specify that RAW gets saved to one card while jpg is saved to another card. But that's when you shoot in RAW + jpg mode. I don't think it gives you a "If RAW, save CF, elseif JPG, save SD." :D But I could be wrong.
Julian
Cody21
Apr 25, 2012 16:22 |  #7
Yea, so far that's the way it seems to work ... I tried that setting ... thanks
MCAsan
Joined Jun 2010
Apr 25, 2012 18:58 |  #8
CF cards are available with UDMA 7 for much faster read/write than an SD card. If you only shoot an occasional file or a few shots a day...maybe you don't care. But if you are shooting action wildlife or sports sequences, you want the write to the card to be ASAP. Also after a long do of shooting, I want the read from my 32GB or 64GB card to be ASAP over USB 3 (not FW800 or USB 2). My Lexar card reader is UDMA 7 compliant.
phantelope
Apr 25, 2012 19:08 |  #9
I'd actually like to know the reasoning behind offering two different card slots in one camera. I really don't care to have to keep track of two different kinds of cards, just complicates things more than necessary. Add that I'm not a fan of the "smaller is better" philosophy here, that SD slot would never get used in my (imaginary) 5DIII. If there were a 2nd CF slot though, I'd have two cards in it at all times, use one as instant backup.
I've seen this in other cameras, it's just weird to me. Are they trying to broaden their market appeal, so people that have only SD cards consider the camera? At $3.5k I somewhat have my doubts cost of cards plays much of a role to target customers.
40D, 5D3, a bunch of lenses and other things :cool:
pxchoi
Apr 25, 2012 19:27 |  #10
phantelope wrote in post #14329108 (external link)
This was my thought exactly.
Patrick Choi
harcosparky
Apr 25, 2012 19:36 |  #11
That's a small reason I am waiting on the 1DX - it will have dual CF slots.
cristphoto
Apr 25, 2012 19:48 |  #12
My 1D cameras have dual format cards and I like it that way. When I'm at a location I can shoot RAW on the CF card and then internally in the camera copy them over to the SD card to load directly into my laptops built-in SD slot without any external readers. If its a critical shoot (i.e. wedding) I simply shoot in redundant mode. I keep the CF card in my pocket and give the SD card to an assistant to input to the laptop - total file security. If I had to go to only one format it would be CF as they are faster, thus quicker to download to computer.
1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
skater911
Apr 25, 2012 20:51 |  #13
aegid wrote in post #14327547 (external link)
I guess I didn't realize that. I actually just ordered another sd card that was a 600x so it will only write at the slower rate if I am reading that correctly? If that is the case I may just send it back and keep the one I have since it is 50.00 cheaper. I did however, just spring for a new 32 gig 600x transcend cf card so hopefully I should see a difference from my Kingston 266x.
Nikon D850 l Nikon 28 1.4E l Nikon 50 1.8 g l Nikon 24-120 F4 l Tamron 100-400 l
3,890 views & 0 likes for this thread, 11 members have posted to it.
SD vs CF?
472 guests, 156 members online
