Thread started 25 Apr 2012 (Wednesday) 17:10
So close..... Too far.......
Kevin ­ Hall
Apr 25, 2012 17:10 |  #1
This guy is a little rascal. I've known him for three years now and I believe he is as ornery as I am. He's the one that likes to attack car mirrors and will chase away anything that flies into his territory. Today I decided to see if he would enjoy a water drip so I set one up in his area. I had no problem getting him to take a few sips and it wasn't a thing at all to entice him onto the brass fitting of my water discharge - he sat there and sang for a good eight minutes.
You can bring together all the elements for a great image and still miss it by a hundred miles on just one detail.
Would he take to the perch behind him? Hell no! There was never any danger of that happening.
Birds do what birds do, you may control every other variable in the equation but you are still dependent upon a favorable subject. It's never a sure thing.
He is a parula, perhaps I'll try using Perrier in the drip next time.......
“By reading this message you are denying its existence and implying consent.”
cfcRebel
Apr 25, 2012 19:07 |  #2
LOL! At least he let you take photos of him. Some as soon as you raise the lens, they'll take off.
Learning through observing bird's behaviors is such as joy. That really enhances the whole birdwatch/bird photography experience. Wish i had a Parula like yours. :)
Fee
Canon | SIGMA | TAMRON | Kenko | Amvona
Kevin ­ Hall
Apr 25, 2012 19:51 |  #3
Hi Fee
I'll trade ya a Northern Parula for a Golden-cheeked.......
jhayesvw
Gallery: 167 photos
Apr 29, 2012 08:59 as a reply to  @ Kevin Hall's post |  #4
I still like the shot!
My Flickr (external link)
Kevin ­ Hall
May 06, 2012 08:57 |  #5
Some days the bear gets you, go back after the mauling another day and you might get the bear - with an assist from a little french water.
Hard work and persistence pays off, it may take more time than you would like but as long as you don't ever give up - it will pay off.
To quote from one of my boy's favorite shows a few years back - Reach High, Think Big, Work Hard, Have Fun.
Kevin ­ Hall
May 06, 2012 09:59 |  #6
For those interested, here are a few images of the portable water drip I am using - I've built a few over the years and this is the lightest and best yet.
Here is our little friend at the watering hole.
Here is the setup (different day). No, the van doesn't go everywhere - that's why you get a doghouse blind. ;)
Here is the drip pond. A 7 watt aquarium pump circulates the fountain. A couple of nano clamps with a mini ball head to position the brass discharge. An 18 inch (2 inch depth) pot saucer for the pool. Various rocks and lichen covered bark to make for a natural setting - also to allow for various depths in the water. Silicone sealed at the bolt hole (uncovered for the photo).
A tripod is a key element for this pond. It does two things. It's a stable platform that allows simple adjustment on uneven terrain for leveling the pond. Also, it allows you to set a sufficient height of the pond to control the background making it possible to shoot clean images of birds on the water. I chose a Sirui T-1005X for it's 22 pound load capacity, it's height adjustment from about 5 inches to 44 inches, and it's light 2.2 pound weight.
And this is the flux capacitor, it's what makes time travel......
Nope, wrong script. :oops:
This is the Buff Vagabond Mini, it's what makes this water drip portable. I've played with
solar panels but the cheap ones either don't work well or do not work in the early morning / end of day hours during the sweet light. They also aren't so hot under heavy canopy - in other words, you need lots of bright light in places or times that you don't have it or don't want it. The Vagabond will run that 7 watt pump for 8 hours + and still have a 1/4 tank of juice on one of it's lithium batteries. You can run all kinds of things off of it, even a laptop. It's relatively small for it's power and only weighs 3 1/2 pounds.
The pond holds just a little more than a gallon of water which isn't too bad for mobility. Because it recirculates in the basin, the only water loss occurs from evaporation and splash (which can be controlled depending on how you set the discharge).
Is it perfect? I hope not - I enjoy fabricating this stuff almost as much as making the images.
Hope you learned a thing or two or that it gives you a spark.
Evan
May 06, 2012 13:41 |  #7
Is that a glass briefcase????
Evan
May 06, 2012 13:44 |  #8
Didn't even realize that you were using a flash. Normally I cannot stand flash photography for birds but this is a pretty sweet setup with some awesome results.
How long did you have to wait before it shows up?
Kevin ­ Hall
May 06, 2012 19:52 |  #9
Flash is just another instrument in your toolbox, you can use it anyway that you want but there are proper techniques (plural) that you employ if you want the best results.
When we are new to photography we often dream about the next best camera body, how much nicer all the bells and whistles would be. With some more experience we gain an understanding that the lens is a more important ingredient than the body for making a delicious recipe. Better still is the light, being able to control it and use it to the advantage of your subject. Portrait and commercial photographers know this especially well - that you don't need the latest, greatest f0.007 piece of glass hanging off the front of your light-tight box as long as you understand the light that you have or can create your own light at will and manipulate it for the best image possible. It's how the old masters made the lasting images that are so memorable even today in this age of modern digital technology. They understood light and how to use it. Yet even as great a tool as light is, there is a better tool still.
Sometimes the birds come in fast - if you are in a hot, dry climate it may be no time at all. Water is gold in such places. Also in migrant traps where a bird has just arrived after flying thousands of miles over the Gulf of Mexico or just before flying over a great lake - places where they will fall out for food, drink, and rest before continuing during a migration. If none of the above applies then it could be several hours to several days for them to find it. Hot days in the last couple hours of light seem to work better than the hours of early morning light. You may need to camp out in a spot or keep coming back for a couple of days for it to work. But once it does work it will attract even the birds that don't come in to feeders, the insectivores - especially warblers. You could try mixing in some playback song to bring them in faster, but in my experience they come in only for defending territory and pay no attention to the water. It is better to let them find it on their own. When they do come in they will give you all you can handle for great photo opportunities. For warblers, vireos, and thrushes I believe it to be the very best way to get them on a perch.
The briefcase is a lexan watertight box.
Chris
May 06, 2012 21:00 |  #10
Those are some amazing images and thanks for the behind the scenes shots.
Chris
70D | 24-70 2.8 | 400 5.6 | 580 EXII | 2X Yongnuo 622C |
tonylong
...winded
Gallery: 60 photos
May 07, 2012 00:29 |  #11
Kevin, what a great followup post to your first one!
Tony
MakeMeShutter
May 07, 2012 15:33 |  #12
Fantastic setup Kevin!
New York Dragonflies (external link)
NYDragonflies.com
Kevin ­ Hall
May 07, 2012 19:38 |  #13
Glad you guys like it.
We all stand on the shoulders of the giants that came before us - but don't be content with that. Learn what they discovered and then use that to take things farther. I've learned plenty from making lots of mistakes and there is always plenty more to learn. I've also gotten ideas from books, things people have shared on the internet, and things I've seen people do. I often like to take things that were meant for one purpose and apply them to an entirely new task.
Take this, use what you will from it and mix it with your own ideas - see what you can come up with.
Most of all have fun. :D
Keebert
May 08, 2012 11:59 |  #14
Stunning! You should port your set-up in this thread
5D3, 50/1.4, 40/2.8, 24-105L, 100L, 70-200L II, 400/5.6L, 600EX-RT, Zuiko 28/2.8, flickr (external link)
cfcRebel
May 08, 2012 14:42 |  #15
Wow, that's a fantastic setup Kevin! The effort has definitely paid off.
Fee
5,116 views & 0 likes for this thread, 9 members have posted to it.
626 guests, 120 members online
