mrgooch wrote in post #14328693
On my old [cheap] tripod I began to run into trouble when I moved up to larger cameras and lens. When using my 24-105 in portrait mode the weight of the lens would pull down and tilt and not stay in position.
What type of tripod-head combo is recommended. I won't be using it much so I don't want to go overboard on the cost.
Well, what is going overboard? I am assuming with the gear you have listed you would not really risk it on a cheap tripod. I don't think you need to spend $1000 on one, but you need to explain what you will use it for and if you will be traveling with it. Tripods can be cheap, light or stable, pick two you can't have all three. I recently sold my Manfrotto for a new Benro travel angel and can't be happier with it.
