Ok...
So I've always run spot center focus and metering in the past.
After reading a bunch here on the AF system, and using the joystick to move focus point, I have been using it a little and actually love it and get more comfortable with it every day.
My problem is my camera is still set to spot meter. I've run into a few situations where i've moved the focus point out to the edge, but it seems spot metering, which stays in the middle, causes me to meter in the wrong spot.
How do you guys handle this?
Should I go evaluative on my metering, which I understand still stays in the center, but some say favors the focus point?
Thanx for you help!
