There has been a lot of discussion regarding the strengths & weaknesses of LR vs. PS/PSE. Since a lot of us rely on Adobe Camera Raw, I would be curious to hear your thoughts on the RAW processor in LR compared to ACR.
Thank you.
kitjv Member 238 posts Likes: 3 Joined Nov 2007 Location: Oregon USA More info | Apr 28, 2012 22:39 | #1 There has been a lot of discussion regarding the strengths & weaknesses of LR vs. PS/PSE. Since a lot of us rely on Adobe Camera Raw, I would be curious to hear your thoughts on the RAW processor in LR compared to ACR.
TTunaEye Member 202 posts Likes: 32 Joined May 2011 Location: Suburban Minneapolis More info | Apr 28, 2012 23:42 | #2 I believe they both use ACR as their conversion tool. I use LR after using PSE for a while. I really like LR in comparison as the workflow is much easier and seems less resource intensive. 6D, 60D, 100L, 24-105L, Sig 150-500, nifty 50, EF-S 60mm, Tam SP70-200 f/2.8 Di VC, Underwater gear T2i in a Watershot housing with Inon S2000 strobes.
tonylong ...winded More info | Apr 29, 2012 00:22 | #3 kitjv wrote in post #14345986 There has been a lot of discussion regarding the strengths & weaknesses of LR vs. PS/PSE. Since a lot of us rely on Adobe Camera Raw, I would be curious to hear your thoughts on the RAW processor in LR compared to ACR. Thank you. Heh! When you mention "a lot of discussion" have you actually read many discussions? It gets repeated over and over here that LR and ACR share the same processing engine with the same tools, assuming your versions of LR and ACR are "equivalent"! At this point you will need Photoshop CS6 to get the full features that you get in LR4, but once CS6 gets out of Beta, same ol' same ol'! TTuna Eye wrote in post #14346188 I believe they both use ACR as their conversion tool. I use LR after using PSE for a while. I really like LR in comparison as the workflow is much easier and seems less resource intensive. Although this goes beyond what the OP seems to be asking about, it is still the relevant matter as to why so many people prefer to do their work in Lightroom even if they have Photoshop -- Lightroom was designed to be an efficient workflow manager built around the Camera Raw processor, and for many of us it indeed does that very well! Tony
Apr 29, 2012 07:45 | #4 Be it as it may .... I was unaware of the fact that ACR & the RAW processor in LR are identical. The reason I ask is that in PSE8 (at least my copy) the full version of ACR is "hidden" in Adobe Bridge. That apparently is not the case in subsequent versions of PSE.
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | Apr 29, 2012 12:51 | #5 It depends on your platform. The Mac version of PSE includes Adobe Bridge as its front-end viewer and the full version of ACR. The PC version of PSE differs; it has its own viewer/browser called Organizer and many of the batch-processing functions in ACR are disabled. kitjv wrote in post #14347266 Be it as it may .... I was unaware of the fact that ACR & the RAW processor in LR are identical. The reason I ask is that in PSE8 (at least my copy) the full version of ACR is "hidden" in Adobe Bridge. That apparently is not the case in subsequent versions of PSE. I discovered that the version of ACR (5.7) in PSE8 does not support the Canon 60D -- well, that is unless I convert the CR2 files to DNG. Not a problem; just a hassle. LR just might be a bit more seamless to work with. Thank you kindly.
Apr 29, 2012 13:39 | #6 That apparently is not the case in subsequent versions of PSE....I discovered that the version of ACR (5.7) in PSE8 does not support the Canon 60D Have you tried the normal upgrades that you're entitled to? The things you do for yourself die with you, the things you do for others live forever.
tonylong ...winded More info | Apr 29, 2012 14:54 | #7 Adobe added support for the 60D in ACR 6.2: Tony
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Apr 29, 2012 16:35 | #8 The raw processing engine is the same, but the interface to it is different. To say I'm not a fan of Lightroom would be a massive understatement. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
| Latest registered member is semonsters 1037 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
