Thread started 29 Apr 2012 (Sunday) 18:40
Difference of zoom between crop and full frame
J.Litton
Apr 29, 2012 18:40 |  #1
This may have been answered already but I didnt see it. Could someone help me understand how much of a difference there' is between say a 500mm lens on a 1Dmkiv, a 7D, and a 5dmkiii?
7D MK II.17-40L.100-400L.500L
www.jlitton.com (external link)
www.facebook.com/jlitt​on.nature.photography (external link)
FlyingPhotog
Cream of the "Prop"
Apr 29, 2012 18:51 |  #2
It's 500mm on all three with the difference being successively tighter field of view from FF to APS-C.
Jay
Evan
Apr 29, 2012 18:57 |  #3
^this..
wish there was a like button on these forums..
gjl711
According to the lazy TF, My flatulence rates
Apr 29, 2012 18:59 |  #4
500mm on 1d mark iv
500mm on 7d
500mm on 5d mark iii
Of the three the 7D will put the most pixels on target with a density of 54,000 pixels per each square mm.
The MkIV and the MkIII are real close with 30k and 26k pixels per sq/mm.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
ScatterCr
Apr 29, 2012 19:09 |  #5
I wasn't aware that the 500L was a zoom
Erik
Gear | flickr (external link)
gjl711
Apr 29, 2012 19:12 |  #6
ScatterCrSport wrote in post #14349901 (external link)
siggy 50-500 and 150-500.
::Gear::
J.Litton
Apr 29, 2012 19:24 |  #7
Thanks for the responses. I just see so many people say to avoid full frame for wildlife and birding, but am trying to grasp why. If the full frame gives you better quality, but you have to crop more, how does it compare to if the camera in essence from what I understand does a crop for you in the crop sensor bodies?
saintz
Joined Mar 2012
Apr 29, 2012 19:30 |  #8
To be helpful instead of pedantic, multiply by the crop factor (1.3 or 1.6) to get the equivalent focal length that would create the same framing on a full frame sensor. So a 500 mm on a 7D will frame a scene similar to a 800 mm on a 5D.
Sony A6000 | 18-55 | 16-50 | 50 f1.8
Ricardo222
Apr 29, 2012 19:43 |  #9
J.Litton wrote in post #14349959 (external link)
If ALL you want is close up pictures of distant objects then the advice you have been given may be of some use, but I really would not advise people to "avoid" full frame for shooting wildlife. There are dozens of threads that will tell you that this or that is bad, but in the end it all works if you press the button at the right time, in the right place!
Crop cameras give greater "reach" for any given focal length, and they may fit your needs perfectly, but only you can tell if the trade-offs are worth while.
While you make up your mind, checkout the best birding sites like BirdsAsArt. No-one there seems to be too pedantic about cameras, but there's good discussion on lenses and techniques. Good luck!
Growing old disgracefully!
sandpiper
Apr 29, 2012 19:57 as a reply to  @ saintz's post |  #10
For wildlife and birding, ignore the "crop factor" as such. The difference in field of view only makes a difference when using the total frame area of each camera.
With critters it is quite likely that you will not be close enough, most of the time, to fill the frame and so will need to crop anyway. The 500mm lens projects the same image circle on the sensor, regardless of the sensor size, so if you aren't filling the frame and only using a part of the sensors area, how much sensor there is outside the chosen composition makes no odds. Once you crop to the part with the bird in, the image will cover the same amount of sensor real estate regardless, so there is no "crop factor".
There is one big difference however, in that crop factor cameras have more densely packed pixels than contemporary FF cameras. This means that although the image covers the same amount of the sensor, the crop body has more pixels on that same area, and it is that which gives you a larger, higher resolution image - by placing more "pixels on target".
So, saying the 500 becomes an 800mm on a 1.6x crop is pointless (as well as being wrong factually). If you have to crop in further to remove excess wasted space in the frame, the crop factor increases accordingly, so you could end up with a 3x crop for example, giving an equivalent field of view to a 1500mm on a full 24x36 framed image. However, that cropped image could as easily be taken from a FF camera as a 1.6x crop camera, it would still be a 1500mm equivalent.
So, forget "crop factor", and "equivalent focal lengths", what counts is pixel density and it is that which gives you additional "reach". How much, depends on the camera you have, something like a 7D will provide more reach than a camera with fewer megapixels.
As for a comparison between the bodies you mentioned, I am sure someone will do the math and work it out based on the pixel pitch of each sensor.
xarqi
Apr 29, 2012 21:45 |  #11
Ricardo222 wrote in post #14350037 (external link)
Crop cameras give greater "reach" for any given focal length...
... because, purely by coincidence, the current crop camera offerings have higher pixel density than the current full frame camera offerings. Sensor size itself, or crop factor, if you prefer, has no bearing on the issue at all.
Ricardo222
Apr 29, 2012 22:42 |  #12
xarqi wrote in post #14350647 (external link)
Yes of course...and I should have used the qualifier "apparent" in that sentence.Because no matter which way you slice it, looking through the viewfinder of a crop sensor camera any given FL appears longer, simply because you are not seeing as much of the subject as on FF. And this is what sticks in people's minds, no matter what math or logic you throw at them.
gjl711
Apr 29, 2012 22:59 |  #13
I took these a couple days ago. The first is taken with the 7D, 100-400, very little post. The second is taken from the same location with the 5DMkII and 100-400. These are not cropped just the full frame re-sized.
IMAGE: http://farm9.staticflickr.com/8150/6980895186_39a357bf38_b.jpg
IMAGE: http://farm9.staticflickr.com/8166/7126981037_31b70a5729_b.jpg
::Gear::
gjl711
Apr 29, 2012 23:06 |  #14
And these are the 100% crops.
IMAGE: http://farm8.staticflickr.com/7207/7127083737_b2339e897d_b.jpg
IMAGE: http://farm8.staticflickr.com/7231/6980996858_eab4bbb06b_b.jpg
::Gear::
MakisM1
Gallery: 22 photos
Joined Dec 2011
Apr 29, 2012 23:10 |  #15
In the first one I thought 'He bit the bullet'...
Gerry
Canon 5D MkIII/Canon 60D/Canon EF-S 18-200/Canon EF 24-70L USM II/Canon EF 70-200L 2.8 USM II/Canon EF 50 f1.8 II/Σ 8-16/ 430 EXII
4,813 views & 0 likes for this thread
Latest registered member is armychemical
549 guests, 208 members online
