Thread started 30 Apr 2012 (Monday) 15:31
Lightroom 3 reordering photos...
GadgetRick
Apr 30, 2012 15:31 |  #1
Ok, been using LR for about 2 years now and I've seen this happen in the past and never understood why it would start happening or stop happening.
So I'm in the Develop module and have my photos along the bottom of the LR window. I edit in LR, sometimes do some things in other applications (select, "Edit In..."), then manage photos in LR.
Now, what normally (should) happen is, when editting a photo in an application using the, "Edit In..." selection (like Photoshop as an example), you edit the photo in the other application, then, when you save the photo it should put it next to the original file in LR in the same order it was there to begin with. Unfortunately, what happens every so often--and is happening right now and is REALLY annoying--LR will put the edited photo--along with the original file--at the END of the photos. So they're out of order. When you're editing photos from a wedding (like I'm doing right now)--and you have hundreds of photos--it becomes a real PITA.
Anyone know what causes this or how to fix it?
Thanks.
FlyingPhotog
Cream of the "Prop"
Apr 30, 2012 15:34 |  #2
Check near the bottom and see that you haven't moved off "Capture Time" to "Added Order" or "Edit Time" instead.
Jay
nathancarter
Gallery: 32 photos
Apr 30, 2012 16:11 |  #3
And make sure you're working in the real folder, and not still working in the "Most recent import" collection.
This gets me pretty often, when I want to change to User Order. If you're in "Most recent import" it won't let you make a user order.
GadgetRick
Apr 30, 2012 16:18 |  #4
FlyingPhotog wrote in post #14354973 (external link)
Where do I find this? I can only find the Filter area (no filters selected).
Thanks.
GadgetRick
Apr 30, 2012 16:18 |  #5
nathancarter wrote in post #14355216 (external link)
Definitely working in the folder...I checked. Thanks.
nathancarter
Gallery: 32 photos
Apr 30, 2012 16:21 |  #6
I think go back to the Library module (tap E for loupE or G for Grid), then if you don't see the Sort Order near the bottom, above the filmstrip, tap T to turn on the Toolbar.
... not sitting in front of Lightroom right now, just trying to remember off the top of my head.
GadgetRick
Apr 30, 2012 16:28 |  #7
nathancarter wrote in post #14355280 (external link)
Thanks. It was User Order. Changed it to Capture Time and it's working properly.
I appreciate the help!
tonylong
...winded
Gallery: 60 photos
Apr 30, 2012 17:31 |  #8
You can also show the Sort Order by clicking the little white arrow at the right side of the toolbar and choosing it.
Tony
GadgetRick
May 01, 2012 05:29 |  #9
tonylong wrote in post #14355705 (external link)
That only gives you View Modes.
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
May 01, 2012 06:42 |  #10
GadgetRick wrote in post #14355320 (external link)
What do you do with your original CR2 files after the new TIFF has been created?
Image Editing OK
GadgetRick
May 01, 2012 07:47 |  #11
digital paradise wrote in post #14358968 (external link)
I keep them. Never know when I need to go back to the RAW file.
digital ­ paradise
Gallery: 157 photos
May 01, 2012 08:07 |  #12
What I meant was what method do you use to prevent them from being exported?
Image Editing OK
tonylong
...winded
Gallery: 60 photos
May 01, 2012 12:30 |  #13
GadgetRick wrote in post #14358773 (external link)
When you click on the arrow are you saying you don't see the options for Sorting, Flagging, Rating, etc, under View Modes? Hmm, you should -- check again!
digital paradise wrote in post #14359337 (external link)
Well, the CR2 is the core part of my LR2 Library -- it stays put! If I want/need to do Photoshop work then LR creates a tiff or psd to incorporate my Photoshop work, but it doesn't replace the Raw file, it just "sits" beside it in my library. I din't do that with every image, but I do work on every image in Lightroom.
Tony
GadgetRick
May 01, 2012 13:54 |  #14
[QUOTE=tonylong;143608​43]When you click on the arrow are you saying you don't see the options for Sorting, Flagging, Rating, etc, under View Modes? Hmm, you should -- check again!]/QUOTE]
Ah, I've got it now.
tonylong wrote in post #14360843 (external link)
Exactly.
2,889 views & 0 likes for this thread, 5 members have posted to it.
1676 guests, 137 members online
