Does the use of a Drop in UV filter make much difference to the EF500mm f/4 IS USM? Or does the loss of one stop of light cause issues for AF & IQ?
smclaren Member 213 posts Joined Mar 2009 Location: London More info | Apr 30, 2012 22:57 | #1 Does the use of a Drop in UV filter make much difference to the EF500mm f/4 IS USM? Or does the loss of one stop of light cause issues for AF & IQ?
FlyingPhotog Cream of the "Prop" 57,560 posts Likes: 178 Joined May 2007 Location: Probably Chasing Aircraft More info | Apr 30, 2012 23:00 | #2 A UV filter shouldn't cost you a stop at all. Jay
Thanks for the info, I thought the Hoya pro UV stepped down one stop.
May 02, 2012 02:37 | #4 FlyingPhotog wrote in post #14357655 A UV filter shouldn't cost you a stop at all. There's really no need for a UV filter in the large primes. I use a .6 ND in mine to limit diffraction at small apertures. You do need to use the clear drop in that comes with the lens in order to maintain the proper light path and to avoid a light leak where the filter fits.
CanonBob Goldmember 2,063 posts Likes: 52 Joined May 2007 Location: Poitou-Charentes, France More info | May 02, 2012 02:41 | #5 smclaren wrote in post #14364928 Does a .6 ND step down two stops of light? It certainly does. 1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
May 02, 2012 05:17 | #6 Digital camera sensors have a UV filter, you dont need one. If you want darker then the drop in CPL may be better. http://natureimmortal.blogspot.com
What is the top recommendation for the best filter?
LesterWareham Moderator More info | May 03, 2012 06:39 | #8 You can't put a protective filter on the 500mm, the only other reason to filter is a ND or a polariser which you could do with a drop-in. My Photography Home Page
If you do not use gel filters, is it wroth changing the drop in filter with a clear canon or hoya filter?
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | May 05, 2012 00:35 | #10 You'll need to buy a drop-in holder for a screw in filter... The one that comes with the lens is for gel filters. It comes fitted with a clear or sky filter. Alan Myers
May 05, 2012 00:44 | #11 amfoto1 wrote in post #14382196 You'll need to buy a drop-in holder for a screw in filter... The one that comes with the lens is for gel filters. It comes fitted with a clear or sky filter. The 500/4 IS uses standard 52mm filters (the earlier, non-IS 500mm uses 48mm, if memory serves). Any good quality "skylight" or clear or UV filter will do... but there should be a filter in there all the time. It's part of the optical formula of the lens. I mostly use B+W, but Hoya, Marumi, Kenko and others make very good filters, too. If you are trying to lose one or more stops of light for some reason (video?), you'll need to go with a Neutral Density filter. The same manufacturers offer them in a wide variety of strengths. A Circular Polarizer would lose one or more stops, too... but you have to buy a special drop-in version that's pretty expensive. Thanks, I have a drop-in holder which came with a Canon clear 52mm screw in filter. But I can find anything on th net about the quality of the glass, so I was thinking about replacing it with a Hoya Pro 1 clear? Although the Hoya Pro 1 clear is coated both sides?
May 05, 2012 02:15 | #12 Mke sure you buy a low profile filter because standard CPLs and such wont fit in the gap http://natureimmortal.blogspot.com
| Latest registered member is Monkeytoes 1364 guests, 163 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
