I don't like to carry a kit of filters and if I could just carry one, it would be most ideal.
Does anyone here use the Singh-Ray Vari-ND filter? - Thoughts?
Thanks!
pxchoi Goldmember 1,146 posts Likes: 1 Joined Aug 2009 More info | May 01, 2012 05:48 | #1 I don't like to carry a kit of filters and if I could just carry one, it would be most ideal. Patrick Choi
May 01, 2012 09:44 | #2 pxchoi wrote in post #14358816 I don't like to carry a kit of filters and if I could just carry one, it would be most ideal. Does anyone here use the Singh-Ray Vari-ND filter? - Thoughts? Thanks! As far as loss in IQ, there is no issue in any way shape or form. You wil get a variable in the color cast however, from a slight warming in the 2 to 3 three stop range, being fairly neutral at 3 to 5 stops (ballpark), and gradually getting bluer towards the full 8 stop range. You will get cross hatching before 8 stops when using a lens less than say a 35 mm. Working your way up the mm ladder, the cross hatching will eventually disappear at the 8 stop range.
ocabj Goldmember 1,120 posts Likes: 3 Joined Jan 2008 Location: Riverside, CA (USA) More info | May 01, 2012 12:13 | #3 The Singh-Ray Vari-ND 77 standard ring mount will vignette on a 24-70 under 35mm on a full frame. http://www.ocabj.net/?p=1785 Jonathan Ocab - https://www.ocabj.net
timeasterday Senior Member 960 posts Likes: 21 Joined Jun 2008 Location: Anderson, SC More info | May 01, 2012 19:02 | #4 I have a slim-mount Vari-N-Duo arriving tomorrow and I'll do some testing with full frame and crop Canons. 7DMKII, 5DMKII, Canon 17-40L, Canon 100mm f/2.8 Macro, Canon 70-200mmL f/2.8 II, Sigma 150-600mm f/5-6.3 DG OS HSM Contemporary, Zeiss ZE 50mm Makro Planar, Rokinon 14mm f/2.8, Kenko Pro 300 DG 1.4x TC, Canon 2X III TC, 580EX II x2, YN560, RF603's
kwando Goldmember 1,345 posts Likes: 1 Joined Aug 2008 Location: Aurora, Co More info | May 01, 2012 21:25 | #5 Heard they are the best! ~Simon~
May 02, 2012 04:55 | #6 timeasterday wrote in post #14362970 I have a slim-mount Vari-N-Duo arriving tomorrow and I'll do some testing with full frame and crop Canons. Definitely keep me posted. Patrick Choi
timeasterday Senior Member 960 posts Likes: 21 Joined Jun 2008 Location: Anderson, SC More info | This was a quick test I just did with a Canon 5DMKII and a 17-40mm L lens set to 17mm. Filter set to Min Filter at 1/4 7DMKII, 5DMKII, Canon 17-40L, Canon 100mm f/2.8 Macro, Canon 70-200mmL f/2.8 II, Sigma 150-600mm f/5-6.3 DG OS HSM Contemporary, Zeiss ZE 50mm Makro Planar, Rokinon 14mm f/2.8, Kenko Pro 300 DG 1.4x TC, Canon 2X III TC, 580EX II x2, YN560, RF603's
timeasterday Senior Member 960 posts Likes: 21 Joined Jun 2008 Location: Anderson, SC More info | This was at 24mm (minimum I needed to go to avoid any vignetting). Filter set to Min Filter at 1/4 7DMKII, 5DMKII, Canon 17-40L, Canon 100mm f/2.8 Macro, Canon 70-200mmL f/2.8 II, Sigma 150-600mm f/5-6.3 DG OS HSM Contemporary, Zeiss ZE 50mm Makro Planar, Rokinon 14mm f/2.8, Kenko Pro 300 DG 1.4x TC, Canon 2X III TC, 580EX II x2, YN560, RF603's
timeasterday Senior Member 960 posts Likes: 21 Joined Jun 2008 Location: Anderson, SC More info | This was at 40mm. Filter set to Min Filter at 1/4 7DMKII, 5DMKII, Canon 17-40L, Canon 100mm f/2.8 Macro, Canon 70-200mmL f/2.8 II, Sigma 150-600mm f/5-6.3 DG OS HSM Contemporary, Zeiss ZE 50mm Makro Planar, Rokinon 14mm f/2.8, Kenko Pro 300 DG 1.4x TC, Canon 2X III TC, 580EX II x2, YN560, RF603's
timeasterday Senior Member 960 posts Likes: 21 Joined Jun 2008 Location: Anderson, SC More info | May 02, 2012 14:37 | #10 I tried the same test with my wife's 7D and 10-22mm lens. The results were pretty close although going almost totally black at max. Not sure what was going on there - the camera did not seem to be metering properly, or at least not the same as my 5DMKII. I tried inside and didn't get the really dark exposure at max, so maybe the bright sunlight was doing something to the metering. That camera & lens combo did not vignette from 14mm on up. 7DMKII, 5DMKII, Canon 17-40L, Canon 100mm f/2.8 Macro, Canon 70-200mmL f/2.8 II, Sigma 150-600mm f/5-6.3 DG OS HSM Contemporary, Zeiss ZE 50mm Makro Planar, Rokinon 14mm f/2.8, Kenko Pro 300 DG 1.4x TC, Canon 2X III TC, 580EX II x2, YN560, RF603's
Voaky999 Goldmember More info | May 03, 2012 22:07 | #11 I have an 82mm Singh Ray. Using it on a 17-40 with BW 77-82 stepup ring it can open to 20mm before it starts vignetting Don
May 04, 2012 05:53 | #12 timeasterday wrote in post #14367825 I tried the same test with my wife's 7D and 10-22mm lens. The results were pretty close although going almost totally black at max. Not sure what was going on there - the camera did not seem to be metering properly, or at least not the same as my 5DMKII. I tried inside and didn't get the really dark exposure at max, so maybe the bright sunlight was doing something to the metering. Ordinary ND filters let in a lot of IR, which the metering sensor can see. That'll ruin auto-exposure in bright sunlight. I guess the same happens with the VND. With an ordinary ND you can calculate what exposure is needed. With a VND you can't as you don't know how many stops you've dialled in. Yet another reason why I don't use one. Frank Hollis - Retired mass spectroscopist
timeasterday Senior Member 960 posts Likes: 21 Joined Jun 2008 Location: Anderson, SC More info | May 04, 2012 06:04 | #13 hollis_f wrote in post #14377678 Ordinary ND filters let in a lot of IR, which the metering sensor can see. That'll ruin auto-exposure in bright sunlight. I guess the same happens with the VND. With an ordinary ND you can calculate what exposure is needed. With a VND you can't as you don't know how many stops you've dialled in. Yet another reason why I don't use one. That's a good point and explains why it worked better indoors. Funny that my 5DMKII didn't seem to have much problem with it. My wife wanted a variable ND so we'll see how she likes it this weekend at some waterfalls, which will be the typical use of this filter. I prefer my 3-stop and 10-stop B+W ND filters and between one of those and my CPL, that's enough for me. Sometimes I really want 10 stops and unfortunately the Vari-N-Duo is not usable at that setting. 7DMKII, 5DMKII, Canon 17-40L, Canon 100mm f/2.8 Macro, Canon 70-200mmL f/2.8 II, Sigma 150-600mm f/5-6.3 DG OS HSM Contemporary, Zeiss ZE 50mm Makro Planar, Rokinon 14mm f/2.8, Kenko Pro 300 DG 1.4x TC, Canon 2X III TC, 580EX II x2, YN560, RF603's
ocabj Goldmember 1,120 posts Likes: 3 Joined Jan 2008 Location: Riverside, CA (USA) More info | May 04, 2012 07:41 | #14 hollis_f wrote in post #14377678 With an ordinary ND you can calculate what exposure is needed. With a VND you can't as you don't know how many stops you've dialled in. Yet another reason why I don't use one. I did experiments to 'measure' the amount of light loss for the index marks on my own Singh-Ray Vari-ND: http://www.ocabj.net/?p=2066 Jonathan Ocab - https://www.ocabj.net
timeasterday Senior Member 960 posts Likes: 21 Joined Jun 2008 Location: Anderson, SC More info | May 04, 2012 08:11 | #15 ocabj wrote in post #14377947 I did experiments to 'measure' the amount of light loss for the index marks on my own Singh-Ray Vari-ND: http://www.ocabj.net/?p=2066 Yep, that was my experience as well. I was taking photos at every tick mark and didn't notice much change at first and then it really started working. But it's a shame there's so little room from a noticeable effect to an unusable result. 7DMKII, 5DMKII, Canon 17-40L, Canon 100mm f/2.8 Macro, Canon 70-200mmL f/2.8 II, Sigma 150-600mm f/5-6.3 DG OS HSM Contemporary, Zeiss ZE 50mm Makro Planar, Rokinon 14mm f/2.8, Kenko Pro 300 DG 1.4x TC, Canon 2X III TC, 580EX II x2, YN560, RF603's
| Latest registered member is Marcsaa 472 guests, 156 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
