dynamitetony wrote in post #14359417
b) taking people in a room with ambient light where flash is not the only source
im just trying to work out if you have to use a slightly faster shutter speed with b as the ambient light might show some movement and not look sharp, compared to a
If you are talking about a case where the ambient is too strong to overpower but not strong enough to make a nice fast exposure, yes. But your flash power gives you some control over how much of the ambient is allowed. If you have a ton of flash power, you can overpower the ambient. Usually you don't want to go THAT far but the flash lets you get a lot faster. Say you'd be shooting at 1/60 to get an all-ambient exposure, and that's just not enough to be sharp in your situation. Indoors, flash would easily let you get to 1/125 or 1/200 without looking too 'flash-y' which is probably enough shutter speed to keep the ambient from showing motion blur. So you still have ambient, but you're controlling it and therefore controlling its unwanted side effects.
In cases where you have a lot of ambient, things are different because you're not using the flash to get enough light, you're using it to get light where you want it (like fill flash on someone under a tree with a bright sunlit background). This is where the outdoor portrait people are using ND filters, fast shutter speeds and HSS.
