Thread started 01 May 2012 (Tuesday) 08:09
Help - speedlight on a tripod
NJKEV
Joined Apr 2011
May 01, 2012 08:09 |  #1
Sorry if this has been posted, I did look and googled.
I have a tripod that I'm not using and I wanted to mount a speedlight with umbrella to it. How can this be done? I see hundreds of different mounts on Amazon but which is the right one?
dmward
Gallery: 29 photos
May 01, 2012 08:28 |  #2
You need something like this (external link).
And also a cold shoe adapter to fit onto the spigot with the male thread. The spigot with the female thread can be attached to tripod.
All this said, the tripod is likely to be too short to get the light high enough to be effective.
I guess it will depend on what you are planning to photograph.
chugger93
May 01, 2012 08:50 |  #3
dmward wrote in post #14359414 (external link)
I've always wondered this. Is it best practice to get the speedlight, strobe etc high enough so its even, if not higher than the camera? Is that more effective than lower than the camera when u are shooting?
Jon | JMBPhotography
5D MK II / 5D MK III --- 24L II | 50L | 135L | Canon 85 F/1.8 | 430 EX II/Yongnou 560 Speedlites | Manfrotto 055XPROB Pro Tripod
zerovision
May 01, 2012 08:52 |  #4
+++1 This is the ONLY one I would recommend. I've purchased some that the are cheap and the hot shoe flash won't even fit in the mounting bracket.
dmward
Gallery: 29 photos
May 01, 2012 09:05 |  #5
I also have several of these (external link).
I forgot that they can with the female spigot. Nice thing is this one includes the cold shoe. They are metal. very much the same as the Manfrotto.
v35skyline
May 01, 2012 09:13 |  #6
^^^I've recently "switched" to these "short" adapters. Not to say that I'm replacing any of the Manfrottos I have, but any new adapter purchase is of this "short" style. I have one from Midwest and another from Cheetah - the Midwest version is much nicer.
X100s | X-Pro1 | X-T1 | XF 14 | XF 18 | XF 35 | XF 56 | XF 60 | XF 10-24
Gear List & Feedback
zerovision
May 02, 2012 08:51 |  #7
chugger93 wrote in post #14359517 (external link)
Raising the flash above the camera, but more importantly above the subject at a 45 degree angle, to camera left, will give the Rembrandt effect i.e. nose shadow down and to the side. This will also reduce or eliminate shadows being thrown onto a wall or other object near the subject.
john78
1 post
Joined May 2012
May 02, 2012 08:53 |  #8
Thanks. I was looking for the same :)
If you want to lose weight,
chugger93
May 02, 2012 08:57 |  #9
Good to know, so the flash should always be above the camera in most situations it sounds like.
Does the same theory apply to OCF and using softboxes or umbrella's? Thanks!
amirg
Joined Apr 2012
May 02, 2012 09:26 |  #10
chugger93 wrote in post #14365927 (external link)
Yes, the umbrella/softbox are there to increase the apparent size of the light source which softens the shadows but your lighting principle is pretty much the same. 45 degrees to the side and above subject is commonly used in portraiture as a safe start. You can then add fill/rim/hair light as needed.
http://www.twilightand​tulle.com (external link)
Facebook (external link)
Drive4show
May 02, 2012 09:41 |  #11
The only time you want light coming from below is for horror lighting. Think about your most natural light source ( the sun ).... it is usually above you. Even windows provide light a little above the subject. If you want portraits to look natural, then you try to simulate nature.
Hounder
30D , 50D, 7D, Tamron XR DII 18-200mm f3.5-6.3, Sigma 10-20mm f3.5,Rokinon 14mm f2.8, Canon 24-70mm f2.8, Sigma 70-200mm f2.8, Canon 50mm f1.8, Canon 85mm f1.8, Canon Macro 100mm f2.8, CanonL 400mm f5.6, Macro Ring Lite MR-14EX, Speedlite 580 EXII, 580EX, 430 EX II:lol:
NJKEV
Joined Apr 2011
May 02, 2012 09:44 as a reply to  @ amirg's post |  #12
Well so much for using those tripods. Another idea in the trash :(
chugger93
May 02, 2012 09:54 as a reply to  @ NJKEV's post |  #13
thanks for the clarification guys
SJRobbins
May 02, 2012 09:57 |  #14
A decent height light stand doesn't cost much anyway, I get the Konig ones for around £10 each, and a cheap coldshoe brolly adapter for another £5 on top of that.
Canon 60D | Tamron 17-50mm f2.8 nonVC | Canon EF-S 60mm f2.8 Macro | Canon EF-S 55-250mm f4-5.6 IS | Canon 50mm f1.8 MkI | Carl Zeiss Jena DDR 135mm f3.5 | Loads of flashes 'n' stuff
2,923 views & 0 likes for this thread, 9 members have posted to it.
1115 guests, 173 members online
