Thread started 01 May 2012 (Tuesday) 11:11
T1i - Too many bad photos
wickiup
May 01, 2012 11:11 |  #1
I have spent quite a bit of time with this camera yet have a huge percentage of unacceptable photos.
They appear to be in focus but indicate camera shake.
Most of my shooting is from a tripod using remote shutter release.
The only lenses I use are a Canon 24-70 L and a Tamron 18-270.
The Tamron having vibration damper often provides the better photos.
Live view sometimes helps but not significantly.
Does it make sense the shutter action is virbrating this camera an undo amount?
Thanks for any opinions
Jim Curts
zenarcher
May 01, 2012 11:16 |  #2
Post a photo up with shooting info and maybe someone can help.
Gear Canon 5D3/ 550D/ EF 24-105L IS / EF 70-200L f4/ Takumar 105 f2.8/ SMC Takumar 28 f3.5/SMC Takumar 55 f1.2/ Super Takumar 135 f3.5 /Takumar 50 f1.4/ Canon 430-EX
crn3371
May 01, 2012 11:18 |  #3
Post up some examples, with exif. In most cases it's user error.
NeverFollow
Joined Jun 2005
May 01, 2012 11:40 |  #4
Make sure you have IS or vibration reduction off when mounted to a tripod
Heres an article on the subject:
http://www.bhphotovide​o.com …n-use-it-and-when-turn-it (external link)
https://500px.com/chri​skennedydotphoto (external link)
dpds68
May 01, 2012 11:57 |  #5
Also what Tripod do you have a cheap one may not be that sturdy and transfer vibrations .
Gripped Canon 7D,20D,XT / Tamron 17-50mm 2.8, Canon 85mm f1.8 , 70-200 2.8L,EF50mm1.8 II,Sigma 150-500mm OS, Sigma 105mm 2.8 Macro, Sigma 10-20mm 4-5.6
Vivitar285Hv x2,Canon430EX,Nissin Di866,CTR-301P Triggers,
http://www.flickr.com/​photos/dpds68/ (external link)
ejenner
Gallery: 98 photos
Joined Nov 2011
May 02, 2012 15:39 as a reply to  @ dpds68's post |  #6
You could try mirror lock-up, but it should only matter for shutter speeds from about 1/30s to 1s. Also if you take the shot when in LV, then the mirror is already up, so that cannot be the problem.
Shaky tripod, or on a shaky surface? I know for long exposures (1-10s) even my kids running somewhere in the house is enough to cause camera shake.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
HiepBuiPhotography
Joined Mar 2012
May 02, 2012 15:47 |  #7
I have a t1i, and I can get sharp images handheld, let alone a tripod.
It seems to me that this is a user's error thing.
Hiep Bui Photography | Harrisburg Wedding Photographer (external link)
kitacanon
May 02, 2012 16:07 |  #8
wickiup wrote in post #14360357 (external link)
Jim Curts
Well, the first misconception to clear up is that the shutter makes no significant impact on camera vibration...
....it would be the mirrors flapping up and down that would cause vibration...as ejenner suggests...
What shutter speeds are you using?
I would venture that shutter speeds slower than 1/60 sec would allow the SUBJECT motion to blur the image (blowing grass and leaves as well as moving people) as much as the camera shaking itself would contribute to soft images....
My Canon kit 450D/s90; Canon lenses 18-55 IS, 70-210/3.5-4.5....Nikon kit: D610; 28-105/3.5-4.5, 75-300/4.5-5.6 AF, 50/1.8D Nikkors, Tamron 80-210; MF Nikkors: 50/2K, 50/1.4 AI-S, 50/1.8 SeriesE, 60/2.8 Micro Nikkor (AF locked), 85mm/1.8K-AI, 105/2.5 AIS/P.C, 135/2.8K/Q.C, 180/2.8 ED, 200/4Q/AIS, 300/4.5H-AI, ++ Tamron 70-210/3.8-4, Vivitar/Kiron 28/2, ser.1 70-210/3.5, ser.1 28-90; Vivitar/Komine and Samyang 28/2.8; 35mm Nikon F/FM/FE2, Rebel 2K...HTC RE UWA camera
kitacanon
May 02, 2012 16:13 |  #9
NeverFollow wrote in post #14360561 (external link)
The Canon 24-70 has no IS
tempest68
May 02, 2012 16:47 |  #10
kitacanon wrote in post #14368307 (external link)
But the OPs Tamron 18-270 does.
Jim
Canon: EOS 3, 40mm f2.8 STM, 85mm f1.8 USM. Voigtlander: R3A, 28mm F2.8 SL II, Nokton 40mm f1.4, 50mm f2 Heliar.
Nikon: SB-25. Yongnuo: YN565EX, YN-622C transceiver (x2)
Sony: A7S, a6000, 24-240mm f3.5-6.3 G, Nissin i40.
kitacanon
May 02, 2012 17:02 |  #11
tempest68 wrote in post #14368474 (external link)
Jim Curts
Note that OP says the Tamron gets better results...
jhayesvw
Gallery: 167 photos
May 02, 2012 17:16 as a reply to  @ kitacanon's post |  #12
it sounds like your shutter speed is too low.
I have a t1i and a 60d and both tof them will suffer from camera shake if my shutter speed is below 1/100th of a second.
My Flickr (external link)
kitacanon
May 02, 2012 17:29 |  #13
jhayesvw wrote in post #14368616 (external link)
OP is talking about shots taken ON A TRIPOD....where I would think camera shake would not be as much the issue as when being hand-held....though I do agree that the slow shutter speed must be the issue....
Chewy734
Joined Jul 2011
May 02, 2012 17:42 |  #14
I would keep the shutter speeds faster than 1/250, or even 1/500 if you're photographing something moving.
Foggiest
Joined Mar 2012
May 02, 2012 17:58 |  #15
There is something else here , need more info and examples from the OP.
For instance , why would live view help ? Is there a focus problem too ?
3,455 views & 0 likes for this thread, 13 members have posted to it.
1739 guests, 171 members online
