Thread started 01 May 2012 (Tuesday) 20:22
ballhead on monopod
finalwish
May 01, 2012 20:22 |  #1
Just wondering what do folks generally use with a monopod... use a ballhead with monopod with a lens plate or directly screw mount monopod directly on the larger lens?
5Dmkiii | 24-105mm f4 L | 135mm f2 L | 70-200mm mkII L | 680EX-RT
Jon
Joined Jun 2004
May 01, 2012 20:24 |  #2
Depends on what you shoot. Although with long lenses (with tripod mounting rings) all you really need is a simple monopod tilt head, not a ball head. I use the RRS MH-1 since I use A-S plates. There's also the Manfrotto 234RC (external link), if you use the Manfrotto RC2 QR plates.
Jon
Cocker Spaniels
Russ61
May 01, 2012 20:31 |  #3
People are free to do or use whatever they want including using a heavy, expensive ballhead...but I've NEVER understood that. I've always used a Manfrotto 234 (or predecessor 3234) or its equivalent in a QR version. I use one with an Arca Swiss compatible (Wimberley C-10) QR clamp. The clamp allows me to clamp/unclamp readily and the 234's tilt ability allows to mount a camera via the tripod mount ring (on lens). The lens then can rotate to any rotational position and the tilt head (if mounted so that its horizontal rotational axis is perpendicular to the lens axis) allows the whole assembly to be TILTED up or down easily. If you're using a smaller lens (ie without a tripod mount ring), then you have to decide if want to TILT the head fore/aft OR portrait/landscape (ie horizontal axis parallel to lens) OR use an L-bracket. It's a lot simpler than I made it sound.
x_tan
Gallery: 137 photos
May 01, 2012 20:43 |  #4
Just be careful with some cheap ballhead, which will NOT hold the weight as they claimed - the camera + lens will drip down as you try to take a shoot; it'll be very irritating and can damage the camera or lens.
Canon 5D3 + Zoom (EF 17-40L, 24-105L & 28-300L, 100-400L II) & Prime (24L II, 85L II, 100L, 135L & 200 f/2.8L II; Zeiss 1,4/35)
Sony α7r + Zeiss 1,8/55 FE
Nikon Coolpix A; Nikon F3 & F100 + Zeiss 1,4/50
Retiring  (external link)
finalwish
May 02, 2012 08:25 |  #5
thanks... I'll shop around for a tilt head.
luciddreamer
May 02, 2012 08:35 |  #6
I use a pan/tilt head and I'm quite happy with it. A ball head would be useless for most of what I do. Everyone's mileage varies. What works for me may not work for you. Which is why I cringe when I see 20 guys chirp in to say you must get an expensive ball head. It might be right for you, or it might not be. You need to assess your shooting style/needs and go from there. A good ball head is nice if it fits your needs. It doesn't fit mine at all. It might not fit yours either.
materialism ~
preoccupation with or emphasis on material objects, comforts, and considerations, with a disinterest in or rejection of spiritual, intellectual, or cultural values.
Calicajun
Gallery: 11 photos
May 02, 2012 08:43 |  #7
Jon wrote in post #14363390 (external link)
Cool head for a Monopod, thanks for posting the link.:)
Remember, Stressed spelled backward is Desserts.:)
Suggestions welcome.
Sony A7rIV, Sigma 24-70 f2.8, Sigma, 14-24 f2.8, Sony 100-400G, Godox V860II
1,337 views & 0 likes for this thread, 6 members have posted to it.
ballhead on monopod
1042 guests, 119 members online
