FORUMS Photography Talk by Genre Critique Corner
Thread started 01 May 2012 (Tuesday) 22:29
What about this simple setup?
nate42nd
May 01, 2012 22:29 |  #1
One 430 EXII set on the ground pointed up toward a white wall behind subject. Natural light, tungsten, and fluorescent filling in the face a bit. Could have used a longer shutter speed but I think it looks okay. How about you?
IMAGE: http://farm6.staticflickr.com/5110/5633257378_8f932d8cea_z.jpg
IMAGE LINK: http://www.flickr.com/​photos/nate42nd/563325​7378/  (external link)
IMG_9515-1 (external link)
7D - - 17-55 F/2.8 - 24-105 F/4L - 100mm F/2.8 - 50mm F/1.8 - S95 / To see all click here
My Flickr (external link)
PhotosGuy
Moderator
Joined Feb 2004
May 01, 2012 22:50 |  #2
It's a start, but I don't think that the "Natural light filling in the face a bit." is enough. Add a bounce card near the camera, or move the wall light more to your rear.
nate42nd
May 01, 2012 22:51 |  #3
PhotosGuy wrote in post #14364248 (external link)
I agree with that assessment. Thanks for the tips. This was shot at 58mm with a 24-105 on a crop so that adds to the info. a bounce card could be placed in a good spot.
CactusJuice
May 01, 2012 22:53 |  #4
Shutter speed is the least of your worries here. The lighting is flat. The white balance is off; subject looks a touch jaundiced. The tight crop doesn't work. Keep practicing.
nate42nd
May 01, 2012 23:12 |  #5
CactusJuice wrote in post #14364272 (external link)
Thanks for that comment. It was shot in RAW and I chose the WB so that could be a color problem with my monitor. Other stuff is good. Thanks for the C&C
Here is another one processed slightly differently. They both need some fill on the front I know that....
IMAGE: http://farm6.staticflickr.com/5266/5632713153_340a6bd65b_b.jpg
IMAGE LINK: http://www.flickr.com/​photos/nate42nd/563271​3153/  (external link)
IMG_9518-1 (external link)
Titus213
May 02, 2012 00:43 |  #6
Fill flash is definitely needed. Or some way to bring up the light on the face. You can't safely do it with the shutter speed so try opening up the lens more. Not sure what you'll end up with if the flash is ETTL. If the flash is manual you should be fine.
More light on the face is an easy fix now - just brighten it up - raise exposure. The white just goes whiter.
I'd cool it down a bit too.
Dave
Perspiring photographer.
1,127 views & 0 likes for this thread
Latest registered member is qawsedrftg
885 guests, 304 members online
