Thread started 02 May 2012 (Wednesday) 01:39
Small Boom for Speedlights
ChadAndreo
May 02, 2012 01:39 |  #1
While watching Joe McNally's Language of Light DVD, I noticed he uses a portable boom for his speedlights.
Does anyone else use these?
If so, which boom do you use?
Photographer + Cinematographer
LETS CONNECT - SOCIAL PHOTOGRAPHY SITE LINKS | Website (external link) | Wedding Site (external link) |
| Flickr  (external link) | Gear | 500px  (external link) | Tumblr (external link)
v35skyline
May 02, 2012 06:24 |  #2
I use a Manfrotto 420B with a speedlite, sometimes in a qbox24 but mostly snooted or flagged as a hair light.
X100s | X-Pro1 | X-T1 | XF 14 | XF 18 | XF 35 | XF 56 | XF 60 | XF 10-24
Gear List & Feedback
Harleypugs
I love camera porn.....makes me hawt.... ;-)
May 02, 2012 10:30 |  #3
I use a paint pole from Home Depot and a Kasey paint pole adapter....works like a charm....
5dMKIII/grip - 24-105 4.0 IS
Echo63
May 02, 2012 11:27 as a reply to  @ Harleypugs's post |  #4
I use my little Lumopro copies of the Manfrotto Nano Stand - 6 foot tall, and of course I need a VAL to hold it
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
happy2010
Looking for the light first
May 02, 2012 13:34 |  #5
Dear CHADANDREO,
Obviously everyone has their own solution/preference and depending on applications – for speedlight on location(drive or occasional fly) my criteria is compactness & light weight so I find this effective:
MANFROTTO Boom Assembly Mfr# 024B:
http://www.bhphotovide​o.com …_Boom_Assembly_​Black.html (external link)
-has a folded length of a nifty compact 28” (yet 3-sections for a LOA of 28", 56" or 6.5ft) which fits diagonally in 26" luggage and I can use on several different Manfrotto lightstands (e.g. primarily with Nano 6’2”, 6.75ft & 7.75ft light stands) depending on the application and the compactness required.
Or if I have an assistant and run & gun situations then have this:
Interfit Strobie Boom Arm [Mfr# INT333] (with a Manfrotto Mfr#026 adapter):
http://www.bhphotovide​o.com …333_Strobie_Boo​m_Arm.html (external link)
very feather-light-weight, durable, inexpensive and adaptible for supporting some of my other lighting stuff like this-
Westcott’s 43” Collapsible White Umbrella:
http://www.bhphotovide​o.com …Umbrella_Collap​sible.html (external link)
or
LightPanels Micropro LED light:
http://www.bhphotovide​o.com …_LED_On_Camera_​Light.html (external link)
Also can use the Interfit Strobie Boom Arm [Mfr# INT333] if I am just wanting the Manfrotto Nano 6’2” light stands & a snooted or gridded 580EXII hair light and if setup time is of the essence, I just use two interconnected very very compact & light weight Manfrotto Nano C-clamps [Mfr # 386BC]:
http://www.bhphotovide​o.com …86BC_386B_Nano_​Clamp.html (external link)
to hold the Interfit Strobie Boom Arm to the Manfrotto Nano light stand.
The Manfrotto Boom/Stand Mfr #420B is a nice value for money solution (but for my applications unfortunately it has a quite long folded length of 44.5” & weighs 6 lbs, which I find too long and too heavy; when for me every inch or bit of weight counts). So if folded length nor weight isn’t an issue, it is a nice set up.
Good luck…
Mary
MARY
Damian75
May 02, 2012 14:14 |  #6
For a little boom for a light stand and speed light you might want to look at a grip head and 40" grip arm like these. http://www.bhphotovide​o.com …CP_200_Grip_Hea​d_2_5.html (external link) http://www.bhphotovide​o.com …0_Extension_Gri​p_Arm.html (external link) . If you want to save a few bucks you can pick up a 5/8 36" plated steal rod from the hardware store for $9 to go with the grip head. This setup is also great for clipping reflectors, scrims or flags to as well.
Canon EOS 40D,30D, Canon 70-200 2.8L, 24-70 2.8L, 85 1.8, Canon extension tube, Elinchrom Lighting gear, 
dmward
Gallery: 29 photos
May 02, 2012 16:51 |  #7
I'd go with the grip head and a piece of tubing or be sure to get a grip arm that has a head with the light stand socket. It works better than the one that clamps around the light stand. The clamp version can deform the stand tubing if you're not careful.
My Blog (external link) has a post that shows how I used one with a Westcott Apollo Octa.
happy2010
May 02, 2012 17:37 |  #8
DMWARD agree with you; no question a grip arm is sturdy (use those like you too and with California Sunbounce stuff) but depends on the criteria, application/OP’s intended purpose(s)…
(eg. say on location for single or couple's portraits and get an additional impromptu request for a group portrait with say 4-6 people) the grip arm with say 40" often doesn’t enable say a hair or rim light in as precise a positioning as a conventional compact or telescopic boom arm. Fair comment about things such as a C-clamp but the cute little Manfrotto Nano C-clamps as long as are clamped at the top of the light stand and are careful is a quick/pocket option(albeit compactness in anything has its tradeoffs).
Many different options and routes along the journey...
[DMWARD - on a side note, thank you for your write-up on the new 600EX-RT’s, enjoyed that!]
Mary
MARY
Rocky ­ Rhode
Joined Apr 2011
May 02, 2012 18:10 as a reply to  @ happy2010's post |  #9
I use the Cheetah Boom:
IMAGE: http://i1103.photobucket.com/albums/g463/Roc34ky/Openingthepackage.jpg
Holds my "Q-box 24" nicely giving a nice soft light when the speedlight fires through it.
GEAR LIST Flickr (external link)
dmward
Gallery: 29 photos
May 02, 2012 18:13 |  #10
happy2010 wrote in post #14368722 (external link)
Mary
Thanks Mary.
As for booms, they require sturdy stands. If someone it taking the bigger stands then A boom with counter weights etc. is acceptable.
I'm disinclined to carry that kind of gear around with speedlites. Small, compact, transportable is part of my definition for that kit. :-)
That said, I do have a convertible stand its bigger but goes way up when needed and also can use the top section as a boom. Its the counter weights that's the biggest pain.
happy2010
May 02, 2012 18:42 |  #11
Please excuse me as I don’t want to hijack CHADANDREO’s good OP, but just a quick comment…
DMWARD/David - Yep, I hear you… I hate those counterweights too!
I found the 5lb & 10 lbs counterweights a bit overkill for speedlights and use this little guy which is reasonably compact for the times I find it necessary to be packing a counter weight for only certain boomed speedlight modifier configurations.
On-Stage Mfr# CW3:
http://www.bhphotovide​o.com …3_Counterweight​_3lbs.html (external link)
and this Manfrotto one is ok too but still a bit bulky Manfrotto 3LB Mfr# 172:
http://www.bhphotovide​o.com …unter_Balance_W​eight.html (external link)
Mary
MARY
dmward
Gallery: 29 photos
May 02, 2012 19:32 |  #12
Mary I like the first one.
I have some angle and wrist weights that I got a Target.
Work great for counter weights once I figured out how to attach them.
Also good for light stand weights or tripod weights.
happy2010
May 02, 2012 20:47 as a reply to  @ dmward's post |  #13
DMWARD/David,
Thanks David for the great idea; as you indicate even work if perhaps using them at the base of small Nano lightstands, as I would think they are about 1/3 the size of bulky traditional-style sandbags.
Somewhat like John Harrington's (I think Washington/ maybe ex-white house photographer) old staff training videos show the compact BOA/shot bags, which sometimes when on the light stand base, depending on the load or circumstance, seems to help almost alleviate the need for a boom counter-weight. http://www.assignmentc​onstruct.com …truct/whatweuse​/sandbags/ (external link)
Mary
MARY
dmward
Gallery: 29 photos
May 02, 2012 22:36 |  #14
happy2010 wrote in post #14369847 (external link)
DMWARD/David,
Somewhat like David Harrington's (I think Washington/ maybe ex-white house photographer) old staff training videos show the compact BOA/shot bags, which sometimes when on the light stand base, depending on the load or circumstance, seems to help almost alleviate the need for a boom counter-weight. http://www.assignmentc​onstruct.com …truct/whatweuse​/sandbags/ (external link)
Mary
Interesting video.
One of the things I really like about my Calumet Nano stands is the wide base when the legs are set to be on the ground. Putting one of the angle weights on it places the weight well away from the center post.
6,733 views & 0 likes for this thread, 8 members have posted to it.
1682 guests, 139 members online
