Just picked up my "new" used 1DMk3
50D is officially gone, let the learning curve and photo taking begin !
Any pointers ??
alexxn Senior Member 396 posts Likes: 9 Joined Nov 2011 Location: S Florida More info | May 02, 2012 09:40 | #1 Just picked up my "new" used 1DMk3 Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
cfcRebel Cream of the Crop 10,252 posts Joined Feb 2005 Location: Austin, TX More info | May 02, 2012 10:35 | #2 Congrats on the 1 series! Fee
May 02, 2012 10:45 | #3 Thanks ! Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
cfcRebel Cream of the Crop 10,252 posts Joined Feb 2005 Location: Austin, TX More info | May 02, 2012 11:21 | #4 Then set the Servo Tracking Method to "Continuous" instead of "Main" because as you pan, you want to keep the focus on your skateboarder or surfer when another object appears between you and your subject. Having it at "Main" the focus will shift to the nearer subject which may not be what you want. Fee
May 02, 2012 13:12 | #5 cfcRebel wrote in post #14366782 Then set the Servo Tracking Method to "Continuous" instead of "Main" because as you pan, you want to keep the focus on your skateboarder or surfer when another object appears between you and your subject. Having it at "Main" the focus will shift to the nearer subject which may not be what you want. Try the Servo Sensitivity straight out of the box first. If it's too jumpy, make it less sensitive. Some likes to separate AF from metering to two different buttons, using thumb to press the * button to AF, and index finger on shutter button to meter. I also customized my slow burst to 6FPS, just right for my bird in action. It's hard to believe 10FPS is sometimes "too fast", i know. ![]() Thanks for all the valuable info, the previous owner was big on Sports shooting so I'm going to run with the settings he left and see how I make out. Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
cfcRebel Cream of the Crop 10,252 posts Joined Feb 2005 Location: Austin, TX More info | May 02, 2012 13:17 | #6 alexxn wrote in post #14367362 I was going to register it with the rest of my equipment for CPS Gold coverage so I wonder if Canon would know what if anything was fixed. I don't know either. I imagine with today's technology, it's rather easy to store the serial number to keep track when the camera comes in for service. If Sigma does that, it's hard to believe Canon does not. Fee
May 02, 2012 13:59 | #7 that's a good one, my discussions with Canon over s/n and what has been done with a body haven't produced anything useful. You might do better, maybe they track the pro bodies better.
| Latest registered member is MWCarlsson 1265 guests, 172 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
