I'm looking for a 50mm for my newly acquired 1Dmk3, is a Canon a better bet over the Sigma ?
alexxn Senior Member 396 posts Likes: 9 Joined Nov 2011 Location: S Florida More info | May 02, 2012 10:54 | #1 I'm looking for a 50mm for my newly acquired 1Dmk3, is a Canon a better bet over the Sigma ? Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
whmeltonjr Goldmember 1,363 posts Likes: 3 Joined Apr 2012 Location: Houston More info | May 02, 2012 10:57 | #2 I just upgraded to the Sigma from the Canon. The Sigma feels like it is built better to me, is sharper at 1.4, and I like the bokeh a lot better. You may have to go through a few to get one that focuses well, or just adjust it with your body. William | Fuji X-E1 | Fuji X100S | Flickr
tb1891 Member 173 posts Likes: 1 Joined Feb 2011 Location: Columbia MO More info | May 02, 2012 11:25 | #3 The Sigma is excellent if you get a copy that will focus accurately. My first one last fall was all over the place on my camera, so I switched to the Canon 50. After a few months, I gradually got the itch to give the Sigma another try and just buy new this time so I could get a free calibration if necessary. Second time around, it's perfect. I had to MA it to +20, but on my 5D2, after a few thousand photos, I'd say the focus is accurate 99% of the time - and that 1% is probably just some user error. The bokeh is just amazing, it's a bit sharper, and the build quality isn't even close. I couldn't be happier with my decision, but just know there is some inherent risk if you choose the Sigma.
PandaSPUR Member 98 posts Joined Mar 2012 More info | May 02, 2012 12:01 | #4 I bought my Sigma 50 used. It does front focus slightly when I tested it, but in actual use I didnt notice it (user error at f/1.4 is more likely than lens error in my case). Canon 5D Classic: Sigma 50mm f/1.4, Rokinon 14mm f/2.8
kay188 Senior Member 825 posts Joined Apr 2009 More info | May 02, 2012 12:12 | #5 Sigma Ricoh GRD4 | Canon 1Ds, 1D, 1D2, 1D2n| Canon XTi | Tokina 11-16 F/2.8 | Canon 16-35L I | Canon 24 F/2.8 | Canon 35 F/2 | Canon 50 F/1.8 I | Canon 135L | Sigma 24-70 EX DG Macro | Sigma 70-200 F/2.8 APO EX DG | Sigma 30 F/1.4 |Sigma 50 F/1.4 |Sigma & Kenko 1.4x TC| Canon 580EX II | Sigma EF-500 Super | 2x Vivitar 285HV | RF-602 Triggers |
mkville Goldmember More info | May 02, 2012 12:12 | #6 I've had the Canon, but used both and could say the Sigma was the better of the two.... provided you don't experiance any of the aformentioned focusing issues, that unfortunetly the Sigma lenses suffer from. I liked my Canon 50 but it just wasn't sharp at 1.4 to 2.0, I know you get what you pay for, but if your advertising it at 1.4 then it should shoot at 1.4 . I say go Sigma
May 02, 2012 13:51 | #7 Sigma is a much better feeling lens, very solid feel to it. It looks better too. However, the three that I tried didn't work. Hopefully you'll have better luck - if you need more info, search "sigma lottery"
May 02, 2012 14:17 | #8 rick_reno wrote in post #14367590 Sigma is a much better feeling lens, very solid feel to it. It looks better too. However, the three that I tried didn't work. Hopefully you'll have better luck - if you need more info, search "sigma lottery" So I'm guessing if I buy used from here even if it's sharp on one camera it may not be sharp on mine ? Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
SamuelYCWang Senior Member 280 posts Joined Feb 2008 More info | I had both in the past. In fact, I recently let go of the Sigma just a month ago. IMO, the Sigma is better built, faster, and the new matted finish looks and feels great. However, like what most people already know, or will find out the hard way is that, with Sigma it's a hit or miss. It's literally like playing the lottery. If you get a good copy, it's wonderful piece of glass. If you don't and your body does not support micro adjust, you'll have to send it in for calibration and hope they don't give you the runaround. If your not the original owner of the lens, and it also happens to be under warranty, then you will get the runaround cause they will only ship the lens back to the original purchaser of the lens. That being said, good luck. Canon 5D MK III
tb1891 Member 173 posts Likes: 1 Joined Feb 2011 Location: Columbia MO More info | May 02, 2012 14:39 | #10 alexxn wrote in post #14367736 So I'm guessing if I buy used from here even if it's sharp on one camera it may not be sharp on mine ? It would still be sharp - but it may not focus accurately/consistently. When I first bought one last fall, I got it used on POTN. The guy I bought it from said it worked great on his 5D2 - but when I got it, it was horrific on my 7D. Whenever I eventually sold it to a friend, it worked great on his old 5D. So it's really just a tossup. Even my new one doesn't work perfectly on the 7D, but I don't really care, as it IS perfect on my 5D2.
PandaSPUR Member 98 posts Joined Mar 2012 More info | May 02, 2012 15:18 | #11 Yea in terms of buying used, it seems like the lens will AF the same on bodies with similar AF systems. Canon 5D Classic: Sigma 50mm f/1.4, Rokinon 14mm f/2.8
eye_projekt Senior Member 349 posts Joined May 2012 Location: Toronto More info | May 02, 2012 15:25 | #12 |
svassh Senior Member 302 posts Likes: 5 Joined Dec 2011 Location: Texas More info | May 02, 2012 15:43 | #13 Had both currently have the Sigma 50mm and love it. As others have said solid build, BIG and beautiful bokeh. With a body that has MFA its a much better built lens than the Canon. The Canon performs well but not as sharp as the Sigma or as nice on the bokeh. On a budget the Canon is still a fine lens, if you can afford the Sigma its worth playing the focus lottery. Samsung NX1, NX 500, 16-50S, 50-150S, 12-24mm, 45 1.8
PandaSPUR Member 98 posts Joined Mar 2012 More info | May 02, 2012 15:46 | #14 Oh also worth noting when considering the two... Canon 5D Classic: Sigma 50mm f/1.4, Rokinon 14mm f/2.8
pkilla Goldmember 2,943 posts Likes: 57 Joined Jan 2012 Location: Boston More info | May 02, 2012 16:04 | #15 The question is how many copys does it take to you get a good copy and I think having to send your brand new lens in with your camera body is just unexceptionable!! T3i griped - rokinon 8mm/rokinon 35 1.4/rokinon 85mm 1.4/
| Latest registered member is MWCarlsson 1264 guests, 172 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
