Thread started 02 May 2012 (Wednesday) 12:39
is there a program to load calibrated monitor profiles?
mantra
May 02, 2012 12:39 |  #1
Hi
yesterday i did rent the last version of spyder
and i calibrated my monitors in different light situation
for example , dark , windows closed , the only light my monitor
and i used a neon for the only light
so i created different profiles
now , is there a program that let me load this profiles?
i'm looking for windows 7 and xp
thanks
cheers
canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
3 analogic Hasselblad and 2 anologic Mamiya
tzalman
Fatal attraction.
May 02, 2012 16:41 |  #2
X-Rite has a free applet with which you can switch profiles. It is described here courtesy of Damo
http://www.damiensymon​ds.com.au/art_vista.ht​ml (external link)
Don't be put off by the fact that it says "Discontinued" on the X-Rite site, the link is still active. I use it every day to switch between my dim photo editing profile and a brighter surfing profile.
Elie / אלי
Rimmer
Joined Nov 2010
May 02, 2012 16:49 |  #3
On Windows 7 tap the Windows logo key and type "color management" (without the quotes, of course) in the "Search programs and files" box. Press "Enter." That will bring up the Color Management control panel where you can select whichever of your profiles you want to be active.
Ace Rimmer -- "What a guy!"
"Smoke me a kipper, I'll be back for breakfast." ;)
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
May 02, 2012 16:53 |  #4
With the Spyder Pro software there is a little app called Profile Chooser that lets you choose and load different profiles.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
mantra
May 02, 2012 23:56 |  #5
tzalman wrote in post #14368447 (external link)
thanks
but it doesn't work
i mean it doesn't visualize my monitor profiles
mantra
May 02, 2012 23:57 |  #6
Moppie wrote in post #14368511 (external link)
have i donwload all the spyder pro software again ?
because there is not only the profile chooser in the download list
thanks
cheers
tzalman
Fatal attraction.
May 03, 2012 01:28 |  #7
For XP there is Microsoft's Color Control Panel
Elie / אלי
Mark ­ Vuleta
Gallery: 48 photos
May 03, 2012 01:29 |  #8
As Rimmer says, go to the display settings part of control panel, colour management, advanced properties and select the one you want. Hopefully you have labeled each in a way you can remember.
This will only be of use provided you can guarantee that you haven't adjusted any of the physical display settings accidentally. You are also recommend to re-check the profile periodically. It is not a one off thing.
mantra
May 03, 2012 02:28 |  #9
Mark Vuleta wrote in post #14370995 (external link)
thanks
but i uninstall the spyder software
are these icc all compatible?
or the spider icc profiles are compatible with colormonki icc?
thanks
again!
Mark ­ Vuleta
Gallery: 48 photos
May 03, 2012 02:49 |  #10
The ICC/ICM profiles are stored in the Windows System32/Spool/drivers​/color folder on your C drive and will be applied to the monitor/printer/scanne​r.... that are connected to the computer.
You do not need the Sypder software to utilize them. Once they are generated, they are used by your computer systems & devices, not the calibrating/profiling software.
As far as being compatible, they all take the same form so I would imagine that a profile generated by one piece of appropriate software would be able to be read & modified by another brand of the appropriate software.
mantra
May 03, 2012 04:52 |  #11
Mark Vuleta wrote in post #14371217 (external link)
thanks
but with xp how can i do it?
1,753 views & 0 likes for this thread, 5 members have posted to it.
1053 guests, 103 members online
