Thread started 03 May 2012 (Thursday) 01:27
The transit of Venus - June 5 and 6
WesternGuy
May 03, 2012 01:27 |  #1
Anyone gearing up to photograph this transit? I would like to know what type of filter I might need for my camera to take direct pictures, without frying the sensor - maybe you can't do this, maybe it isn't worth the risk? I have two sets of ND filters, 2 each of 1, 2 and 3 stop filters and I am wondering if I put all of these in front of the lens - my 100-400L IS on my 5D, whether that would work or not, or am I better off trying to make a pinhole camera and photograph the projection from that? Maybe a Lee Big Stopper - http://www.leefilters.​com/index.php/camera/b​igstopper (external link) ?
Any ideas or experience that anyone would care to share will be appreciated. Thanks.
WesternGuy
ameerat42
May 03, 2012 18:17 |  #2
Yes, I am.
NOW STOP with your filters. ONLY use the likes of the "Thousand Oaks" ND 5, or the Baader FIlm ND 5.
The ND 5 means a reduction in the transmitted light of 10^5 or 100,000X. That's the type of filter you need for VIEWING - and it can be used for photogrraphy. For photography only (whatever that means, since you still have to look at it) you can use a Baader Film ND 3.8 (~6,000X).
WIth the ND 5 filters, your exposure for the sun in a clear sky are approx:
ISO 100, f/8 to f/11, 1/160 to 1/200 sec.
(It's been ages since I used the ND3.8 type and I can't remember, but exposure times are much higher.)
Am.
WesternGuy
May 06, 2012 02:00 |  #3
ameerat42 wrote in post #14375331 (external link)
Yes, I am.
Am.
Thanks for the information. I sent "Thousand Oaks" an e-mail and asked about the filter - no luck, they do make it, but the backlog is such that they would not be able to get one to me in time for the event. I guess I will have to try and construct a pinhole that I can use to project an image on a white board or something.
WesternGuy
ameerat42
May 06, 2012 04:21 |  #4
Then 4-get 1000 Oaks. Try for some Baader Solar Filter Film in your area. It's got to be around. Just make sure you get the ND 5 version (even if you also get the ND 3.8). Make up a SECURE filter housing yourself and off you go. Baader film comes in two varieties AFAI can tell. One is a thin black plasticky sheet, and the other is a silvery sheet. They are both OK, though I have only used the siiver stuff.
This is a link a mate sent me for the dark material:
http://www.ebay.com.au …_trksid=p3984.m​1497.l2649 (external link)
Good luck, though you won't need that much, I'm sure.
Am.
WesternGuy
May 06, 2012 14:04 |  #5
ameerat42 wrote in post #14386911 (external link)
Am.
Thanks for the info. I will call around to some of my local camera stores, who knows, they may have some. Do you think I could cut the material to fit a Lee square filter holder? I would just have to make sure that there was no light leakage around the filter. The other thing I could do is to "recycle" a couple of old UV filters that I have kept (no longer use) and try and make a "screw-on" for my camera. Any thoughts?
____________
WesternGuy
legoman_iac
May 06, 2012 18:47 |  #6
Hey guys, I did a lot of reading about this a while ago. I ended up getting a solar filter from my awesome local telescope shop. I'm paranoid about going blind or frying my equipment, so was happy to spend the $ 90 on it to get the right gear. I would advise against building something.
The instructions with my solar filter urge to never leave your gear unattended, and to make sure the filter is secured so it won't fall off if pointing down or gusty wind picks up.
I still won't look through it, but happy to risk my telescope and dslr if something bad happens, they're replacable. Hope this helps?
p.s. You'll also want a shade cloth. I'm used to astro/night time weather, so after 15min in the sun I was sweating like a ham! If anyone knows where to buy a big golf/shade umbrella that mounts onto a telescope with a hole for it, I'll buy one!
2x 50d: with 17-85mm f4-5.6, 100mm Macro USM, 50mm f1.8, 2x Sigma 30mm f1.4, 55-250mm (kit lens), Canon 100-400mm L, Tamron 200-400mm f5.6, Samyang 8mm. 480mm refactor with HEQ5. Home made beamsplitter stereo rig.
WesternGuy
May 06, 2012 20:29 |  #7
legoman_iac wrote in post #14389577 (external link)
Care to share the brand/type you bought and the specs. Don't forget, I am looking for one for my camera as I do not have a telescope(yet). Curious why you advise against building one, as there are lots of instructional stuff on the web about how to do this. Thanks.
______________
WesternGuy
Toxic ­ Coolaid
May 06, 2012 23:40 |  #8
You can look through it. Just put a piece of paper or your hand back there first. Better a hot hand than a fried camera. When I shoot the Sun my camera tends to get hot. Not from what is coming through the scope, but just because it's black and sitting in the sun. I usually wrap my camera with some aluminum foil just to reflect the sunlight off it.
The pics below are with Sky-Watcher PRO 80ED APO Refractor with an Orion Glass 4.57" Solar Filter. looks like the part # is 07798. It lets the light through as yello. I shot video and processed with Registax using prime, 2x barlow, and 2x barlow + 5x crop. For the transit I will shoot lots of single shots
I also use an Astro-Tech 8in with a Thousands Oaks wight light Solar Filter.
I hope this helps
IMAGE: http://i347.photobucket.com/albums/p446/mokpt/IMG_7179.jpg
IMAGE: http://i347.photobucket.com/albums/p446/mokpt/3-12-12sun3xprime2good2jpeg.jpg
IMAGE: http://i347.photobucket.com/albums/p446/mokpt/3-12-12sun3xbarlowx5jpeg.jpg
ameerat42
May 07, 2012 00:08 |  #9
WesternGuy wrote in post #14388546 (external link)
...Do you think I could cut the material to fit a Lee square filter holder? I would just have to make sure that there was no light leakage around the filter. The other thing I could do is to "recycle" a couple of old UV filters that I have kept (no longer use) and try and make a "screw-on" for my camera. Any thoughts?...
WesternGuy
Yes to all. I have done the same.
...to get the right gear. I would advise against building something...
...I still won't look through it...
Baader Solar Film ND 5 IS the right gear, both for optical viewing and for photography, but it's up to you. Bought or built yourself, there's no difference. The BSF ND 3.8 is ONLY for photography, though.
WesternGuy wrote in post #14390023 (external link)
...as I do not have a telescope(yet). Curious why you advise against building one...
WesternGuy
A "good" 400~500mm telephoto +/- 2X converter will yield the likes of TC's first image above. I agree with the rest.
Toxic Coolaid wrote in post #14390991 (external link)
...The pics below are with Sky-Watcher PRO 80ED APO Refractor with an Orion Glass 4.57" Solar Filter. looks like the part # is 07798. It lets the light through as yello. I shot video and processed with Registax using prime, 2x barlow, and 2x barlow + 5x crop. For the transit I will shoot lots of single shots
I hope this helps...
Top stuff, TC.
Am to all.
WesternGuy
May 07, 2012 02:13 |  #10
TC, great shots, that is the sort of thing I will be looking to try and get. Guess I will go and hunt for some Baader ND 5 film.
WesternGuy
heldGaze
Gallery: 13 photos
May 08, 2012 18:18 |  #11
I hope this helps
As usual, it does. Nice shots, I want to get a solar filter for this event.
Cameras: Sony α7R II, Canon 40D, Samsung Galaxy S7
Lenses: Canon 11-24mm f/4 L, 24-70mm f/2.8 L II, 50mm f/1.8 II, Sigma 18-200mm
Telescope: Meade LXD55 SN-6" F=762mm f/5, with a 2x Barlow T-Mount
Retired Cameras: Canon SD300, Nokia N95, Galaxy S, S3 & S4
C&C Always Appreciated
Toxic ­ Coolaid
May 08, 2012 23:10 |  #12
I think you can probably shoot video, but limit it to short lengths. You can get 30 frames a second, then use Registax to pick the best 80% from maybe 30 second batches. I think that taking very fast single pictures is what I will try 1st. If I get good shots I may try video next. The problem with video is you can't see it on the spot (sorry had to say it :rolleyes:) I'll just have to see on the day. Hopefully is't clear.
archer1960
Gallery: 6 photos
May 11, 2012 10:53 |  #13
____________
WesternGuy
Yes, I got a 4" square ND5 that works great in my Cokin Z-series holder (uses the same size filters as Lee).
Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
legoman_iac
May 16, 2012 05:23 |  #14
______________
WesternGuy
Hey WesternGuy,
Sorry for the delayed reply, been away for a bit. I bought the Orion 80mm Solar Filter, to go on my Orion ED80T CT ... but it fits on my Tamron 200-400mm as well, you'd just have to make sure it is well secured.
I advised against building one, mainly as I'm lazy ... haha, but also don't trust my handyman skills. Should've said, it's "easy to buy one than to build one ... if you're as handy as me", haha.
This thread has my first solar pic, if you want to see what my first attempt with this gear looks like ... https://photography-on-the.net …/showthread.php​?t=1116938
Hope this helps,
Daniel
Celestron
May 16, 2012 08:12 |  #15
Watch the video :
https://photography-on-the.net …/showthread.php​?t=1185987
6,096 views & 0 likes for this thread, 7 members have posted to it.
1674 guests, 139 members online
