Thread started 03 May 2012 (Thursday) 17:40
should i replace my t2i with 1dmkii
abuha
May 03, 2012 17:40 |  #1
hi,
so I have been thinking of getting a 1dmk ii ''idx eventually'' for bird photography, so should I sell my t2i and get the 1dmkii? Should i expect less detail in images because of the 1DMK II Low mega pixels? Or will i be better-off getting a 7D instead?
TooManyShots
May 03, 2012 17:47 |  #2
Lens? What lens you have for bird photography? 400mm and longer is generally recommended.
One Imaging Photography (external link) and my Flickr (external link)
Facebook (external link)
jayadeff
Joined Feb 2004
May 03, 2012 17:56 |  #3
The 1DMkII is a huge step up in autofocus performance and frame rate, which would server you much better than the added Mp of the T2i. However, you will absolutely hate the tiny low-res LCD on the MkII compared to the T2i.
professorman
May 03, 2012 18:15 |  #4
Yes, you should. Its a excellent value for money now.
MyGear | Feedback | facebook (external link)|My Site (external link)|Flickr (external link)
abuha
May 04, 2012 04:25 |  #5
jayadeff wrote in post #14375235 (external link)
Getting used to the Smaller LCD would require some time, but I think the faster AF and the burst rate would make for that, no?
professorman wrote in post #14375320 (external link)
hmmm, so there is a mk iiN version, Is their big enough of a deference between the two that I should get the N and not the MK II
Unregistered.Coward
May 04, 2012 04:48 |  #6
No. You'll trade some differential advantages for others but you won't realize a "wow" improvement.
I'd work a plan for the 7D. Better yet, a long lens if you're looking at birding. I still use my T2i / Sigma 150-500 combo quite a bit. Lightweight, sharp.
....the best camera is the one you have on you at the time.
jayadeff
Joined Feb 2004
May 04, 2012 12:02 |  #7
abuha wrote in post #14377527 (external link)
The MkIIN has a larger LCD, and a slightly larger buffer. Other than that it's the same as the MkII. They are a bit more expensive, but as far as I know Canon is still servicing the MkIIN whereas the MkII has reached end-of-life status and is no longer serviced by Canon.
1,440 views & 0 likes for this thread, 5 members have posted to it.
Latest registered member is EBiffany
1601 guests, 97 members online
