Thread started 03 May 2012 (Thursday) 17:51
BlackRapid FastenR-T1 vs Manfrotto RC2 stock ring to attach BlackRapid straps
kaushama
Joined Feb 2006
May 03, 2012 17:51 |  #1
What is the issue with using the stock RC2 ring with BlackRapid straps? Any danger?
If not having a $17.95 worth FastenR-T1 with each of one's RC2 plates gives only aesthetic value???
Please share your expert thoughts!
IMAGE: http://farm2.static.flickr.com/1156/5101675572_67df7d92ee_b_d.jpg
Jon
Joined Jun 2004
May 03, 2012 18:32 |  #2
Asked before - the D ring in the Manfrotto screw isn't structural. It may well bend and pull out under dynamic load of the camera (especially if you've got a hefty lens on it) hanging off it.
Jon
Cocker Spaniels
kaushama
Joined Feb 2006
May 03, 2012 18:43 as a reply to  @ Jon's post |  #3
Found this (external link). Will it be a good alternative for expensive Balckrapid solution?
Jon
Joined Jun 2004
May 03, 2012 19:00 |  #4
Never tried it. It's your camera. You decide how much you're prepared to risk. It's 2/3 the price of the BR one, which isn't all that costly even then.
Jon
Cocker Spaniels
donsullivan
May 03, 2012 21:07 |  #5
kaushama wrote in post #14375210 (external link)
The stock metal ring is not strong enough to hold the weight of most new DSLR's reliably with a lense attached. It's is a very soft metal designed only for turning the screw, not holding any weight at all. I know of at least one person who tried it and had the metal ring on the RC2 stretch out and detach causing his camera to drop to the ground. It's obviously your choice but I would spend the $17.95; it's a whole lot less than the potential damage to your gear.
Canon EOS 5D Mark III/ Sony Alpha 7R/ 14mm f/2.8L II USM/ 24-70mm f/2.8L II/ 70-200 f/2.8L II IS/ 16-35 f/2.8L II/ 50mm f/1.4/ 8-15mm f/4L Fisheye/ 580EX II/ 2x Extender III/
Diesel_Dog
May 04, 2012 10:50 |  #6
I've had the Manfrotto D ring pop out of its housing before. I would never use it to carry my camera.
Dillon
5Dmk II | 30D | 17-40L |24-70L | 70-200L F4 IS | 300L F4 IS | 1.4 TC
luciddreamer
May 04, 2012 12:08 |  #7
Try hanging some weight (40-50 lbs or so) from it for a few days. See how that works.
materialism ~
preoccupation with or emphasis on material objects, comforts, and considerations, with a disinterest in or rejection of spiritual, intellectual, or cultural values.
wookiee2cu
May 04, 2012 14:05 |  #8
I contacted BR about it and they said the the d-ring on the manfrotto doesn't go all the way through the base. So like others have said over time it can expand/stretch and eventually fall out of the base causing your camera to fall to the ground.
tdodd
May 04, 2012 14:37 |  #9
This is not an original Manfrotto part (eBay knockoff), but this is very much the sort of thing you might wish to avoid....
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/05/1/LQ_594253.jpg
Image hosted by forum (594253) © tdodd [SHARE LINK]
fishinfool
May 04, 2012 15:55 |  #10
I've been using the BlackRapid FastenR-T1 with my gripped 7D and 70-200 2.8 on dozens of hikes ( mostly around the tough terrain of Hawaii Volcanoes National Park) and so far so good. I do check to see if they are screwed in tight several times during my hikes. Just a habit I guess.
6D + BG-E13, 7D2 + BG-E16, 7D + BG-E7, 16-35 f/2.8L II USM, 100-400mm f/4.5-5.6L IS II USM, + 1.4x III, 70-200 f/2.8L IS USM, 24-105 f/4L IS USM, 100 f/2.8L IS USM Macro, 50 f/1.4 USM, 15-85 f/3.5-5.6 IS USM, 580EX II & 430EX II, Manfrotto MT057C4 + RRS BH-55, Manfrotto 055CXPRO3 + Acratech GP, Manfrotto 190CXPRO3 + 128RC , Manfrotto 681B + Sirui L-10, Gorillapod Focus + Manfrotto 234RC.
whmeltonjr
Joined Apr 2012
May 07, 2012 22:49 |  #11
Anybody carry the Blackrapid with the Manfrotto on a regular basis? I'm about to order a tripod and I'm trying to decide if it's worth getting the Blackrapid piece or just putting the plate on when I want to use it.
William | Fuji X-E1 | Fuji X100S | Flickr (external link)
tdodd
May 08, 2012 01:28 |  #12
The whole point of a QR plate is to make it quick to use. I have three T1s - one on my 100-400, one on my 70-200 and one on my 5D2 and could do with a couple more for my 7D and 1D3. Considering the total price of the kit, and even just the Black Rapid strap itself, it seems a trivial additional expense for the convenience time and time again. It's a pity they aren't offered as a standard option instead of the FastenR-3s.
For security I do use threadlocker nowadays, which makes avoiding the need to swap components out even more beneficial.
whmeltonjr
Joined Apr 2012
May 08, 2012 02:23 |  #13
Thanks. That's kinda what I was thinking too. I don't mind the $17, or whatever it is. I agree, would be a great standard option to have.
sherpa25
Joined Nov 2012
Jun 19, 2013 07:08 |  #14
Just saw this as I plan to get the FR-T1 too for my RC2. I noticed in the picture in the 1st post that the stem of the FR-T1 appears shorter and has less threads, w/c appears like it won't enter the tripod hole as deep as the stem of the RC2. Also, I notice the FR-T1 has sort of a neck at the top of the stem, does this go in the tripod hole as well, or does it block the stem from going in the hole fully? Lastly, does everyone just use the parts (i.e washers, etc) that came with the FR-T1, or replace them with the ones w/ the RC2? I ask because some feedback in Amazon give different descriptions, some say they use/prefer the washer of the original RC2, perhaps due to poor QC? Thanks.
Canon EOS 60D | Σ17-50 f2.8 | Canon 50mm f1.8 | Canon EF-S 55-250mm f3.5-5.6
tdodd
Jun 19, 2013 08:31 |  #15
There is another option which, despite now having several FR-T1s nowadays, I most commonly use. That is to use a Manfrotto MN323 quick release platform. It isn't terribly expensive and comes with an extra RC2 plate. This actually gives me a quick release to remove my camera from the strap, for tripod use, and instead of buying several FR-TR1s (too late now) a pair of these platforms will work with a double strap and ordinary Manfrotto plates and bolts. Of course there is a little more bulk and weight, but potentially more convenience, and once you have the platform(s) your costs are kept lower for any number of additional plates you might need.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/06/3/LQ_653330.jpg
Image hosted by forum (653330) © tdodd [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/06/3/LQ_653331.jpg
Image hosted by forum (653331) © tdodd [SHARE LINK]
13,807 views & 0 likes for this thread, 12 members have posted to it.
492 guests, 122 members online
