Thread started 05 May 2012 (Saturday) 11:21
Changing file names
ICee
May 05, 2012 11:21 |  #1
I have two 7Ds and both have the same IMG**** file name in camera, is there any way of changing one of them, I can't find anything in the manual.
eye_projekt
Joined May 2012
May 05, 2012 11:23 |  #2
I believe it's under 'file numbering in the menu
Portfolio (external link)Facebook (external link)Flickr (external link)Pinterest (external link)
ICee
May 05, 2012 11:32 |  #3
That only gives you the option to reset.
I've come from Nikon and that had a way of changing the letters so you could use something like IC1**** instead of DSC****
hennie
Gallery: 30 photos
May 05, 2012 12:52 |  #4
simplest is to set one to rgb an the other to adobe rgb the prefix will change.
Or determine the filename by setting it during download
ICee
May 05, 2012 14:47 |  #5
Thanks, I give that a go.
Davinor
May 08, 2012 16:57 |  #6
I use Bulk rename utility, I copy the files to a new folder on the PC, rename them and shift them to wherever i want them. It stops my wifes photos and mine trying to share the same number.
http://www.bulkrenameu​tility.co.uk/Download.​php (external link)
David
A tidy desk is the sign of a sick individual
600D with Sigma 17-70 f2.8-4 DC OS HSM,
Tamron 70-300 f4.5-5.6 Di VC USD
Sigma EF500 DG Super and some other bit and pieces
whiteflyer
Gallery: 316 photos
May 08, 2012 17:13 |  #7
I use Apple Aperture and would just do a sort by serial number and then a batch rename.
I don't think having one set as sRGB and the other Adobe RGB is a good idea, it just added another step in your workflow putting them back to the correct colour space if shooting in raw, and if you shoot in jpeg it's going to give you all sorts of printing issues..
hennie
Gallery: 30 photos
May 08, 2012 17:27 |  #8
whiteflyer wrote in post #14400850 (external link)
I allways shoot raw and use DxO, I can set the target color space globally at conversion time, no extra step required.
For me it still is the simplest way to avoid duplicate filename.
Alternatively, I synchronize both cams with the computer using EOS utility, set the sequence nr manual at downloadtime, sort by exif-time and do a batch rename in order to have them numbered in a chronological sequence.
2,223 views & 0 likes for this thread, 5 members have posted to it.
Changing file names
1024 guests, 108 members online
