Thread started 06 May 2012 (Sunday) 13:37
Pocket Wizard Help.
SpartanWarrior
May 06, 2012 13:37 |  #1
I have the Flex TT5 and Mini TT1, everything works fine in ETTL but want to set mode 2 to basic trigger so I can use my Metz 58 AF-2 in full manual, well when I open the Utility and go to Misc I check basic trigger then I go back to the channel tab and set a channel like 25 instead of the default 32, but the flash doesn't fire I also tried my canon flash in manual mode and doesn't fire either, is there another setting I am forgetting in the utility? I sent an email to pocket wizard and they told me the Mini doesn't need to be in basic trigger ( which with or without the mini in basic trigger won't fire anyway) but they told me the mini has to have the same channel as the flex which in the channel tab for the mini only has mode 1 or 2, can someone help me out? thanks;)
Canon 5D III, EF 24-105 f4, EF 16-35 2.8 L II, EF 70-200 2.8 IS L II, EF 100 2.8 IS L, EF 2x III, EF 1.4x III, 500D 77mm close up filter, Kenko extension tubes set, SpeedLight 600 EX RT, Metz 58 AF-2, Pixel Kings, Benro C3780T Tripod, Benro G3 Ball Head.
www.chrisksphotography​.com (external link)
jdotuk
May 06, 2012 14:56 |  #2
I'm pretty sure that basic trigger mode only works on the basic channels - you can't use the ttl channels for the dumb trigger feature. I wish that pw would release an app though so you could easily chnge settings in the field.
Jeremiah (J.) Mullins
5D & 7D | 35L, 50 1.4, 85 1.8, 135L | X100s
SpartanWarrior
May 06, 2012 15:15 |  #3
jdotuk wrote in post #14388715 (external link)
Thanks but how can I set it up to basic trigger so the flash will fire in manual mode?
SpartanWarrior
May 06, 2012 16:06 |  #4
Never mind figured it out.
1,034 views & 0 likes for this thread, 2 members have posted to it.
Pocket Wizard Help.
615 guests, 124 members online
