Thread started 07 May 2012 (Monday) 00:46
how can i set camera calibration setting default for my camera ?
mantra
May 07, 2012 00:46 |  #1
Hi
i'm using photoshop cs5 and i'm using cs6 trial
well i can't store my camera calibration to default
in the camera raw preferences i set enabled make default spefic to camera serial ON
i delete all the xmp sidecar files
i load a 5d mark 2 raw file, in default setting
i changed only camera calibration setting
i changed ->
camera profile -> Neutral
process -> 2003
after i did save camera new raw default
but when i load a raw image camera raw doesn't load my default settings (for example processing is always to 2012 in cs5 and cs6)
what's wrong?
thanks
cheers
canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
3 analogic Hasselblad and 2 anologic Mamiya
René ­ Damkot
May 08, 2012 05:36 |  #2
Why on earth would you want to set PV2003 as default when PV2012 is so much better?
Anyway, gave it a try and indeed the PV won't stick as a default. It's "translated" to PV2012 settings.
Might be a bug, might be a feature. Don't know. You could ask Adobe.
But frankly, I'd stick with PV2012.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
mantra
May 08, 2012 11:14 |  #3
René Damkot wrote in post #14397658 (external link)
i 'm under w7 64 , 16gb 8 cores hi end machine
the acr zoom is slow (zoom in ,zoom out)
2010 is faster
2003 is amazing fast
tonylong
...winded
Gallery: 60 photos
May 08, 2012 14:42 |  #4
Do you realize that if you switch to PV 2003 then all of your development tools will revert to the old (LR1) version?
Tony
mantra
May 09, 2012 01:15 |  #5
tonylong wrote in post #14400042 (external link)
yes i know
did you find a slow down?
in the zoom
tonylong
...winded
Gallery: 60 photos
May 09, 2012 02:14 |  #6
Not a slowdown, but a bit of a lag in the rendering, but not enough to bother me much
Tony
mantra
May 09, 2012 10:59 |  #7
tonylong wrote in post #14403279 (external link)
do you mean when you zoom in do you notice a lag?
by the way , do you think have a big monitor could slow down ?
thanks
cheers
tonylong
...winded
Gallery: 60 photos
May 09, 2012 11:17 |  #8
mantra wrote in post #14404794 (external link)
Well, if say I zoom to 100% it takes just a brief bit to "crystallize". By "brief", I mean barely enough to notice, but it seems like it's a bit longer than I remember LR3 taking, but I haven't even started LR3 since I've had LR4...
Anyway the only time it affects me is if I'm quickly moving through images and marking them as Picks or Rejects. And, like I said, the lag is quite brief.
I really don't know any "under the hood" stuff about that. For example, I'd imagine that it would have to do with your graphics card, and whether LR uses the card enough to be slowed down by the monitor activity, and I just don't know, maybe others do.
thanks
cheers
Cheers back at you!
Tony
D ­ Thompson
May 09, 2012 11:40 |  #9
mantra wrote in post #14403125 (external link)
in the zoom
It's almost instantaneous on mine, even on my old XP machine.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
mantra
May 10, 2012 00:11 |  #10
D Thompson wrote in post #14404981 (external link)
may i know your resolution ?
do you have a dual or 4 core?
thanks
D ­ Thompson
May 10, 2012 07:35 |  #11
mantra wrote in post #14408599 (external link)
thanks
Resolution is 1920x1080. My XP machine is ancient - single core with hyper thread.
Dennis
mantra
May 11, 2012 11:16 |  #12
D Thompson wrote in post #14409590 (external link)
i got it
and you run cs6 or cs5 2012 ?
by the way even lightroom 3.x is fast to you
lucky !
cheers
D ­ Thompson
May 11, 2012 11:42 |  #13
CS5 and CS6-beta (2012) on the XP machine. CS6 (2012) on the Win7. I don't use LR.
Dennis
mantra
May 11, 2012 12:09 |  #14
D Thompson wrote in post #14416190 (external link)
can't understand why when i zoom there is a lag
do u have a single core 3.6?
dmward
Gallery: 29 photos
May 12, 2012 08:33 |  #15
If you are frustrated by the time it takes Lightroom to render the 100% preview image, do the rendering in bulk at a time when you are away from the computer. Then the preview will pop into place when you click zoom.
3,498 views & 0 likes for this thread, 5 members have posted to it.
1053 guests, 103 members online
