I was wondering if it was possible to trigger a monolights using any combination of the following gear:
Nissin Di866 mkII
YN-560
Cactus v5
ST-E2
optical slaves
If not, what other options are there besides using TTL triggers(radio poppers, tt5,etc)?
ChadAndreo Goldmember 1,879 posts Likes: 15 Joined Nov 2006 Location: WPB, FL More info | May 08, 2012 01:02 | #1 I was wondering if it was possible to trigger a monolights using any combination of the following gear: Photographer + Cinematographer
PhotographersWorldWide Senior Member 395 posts Joined Mar 2008 Location: UK More info | May 08, 2012 04:36 | #2 All except the ST-E2 will trigger a monolight by using the monolights in-built optical slave or by adding a receiver in the case of the Cactus v5. For HSS the monolight needs to have a longish flash duration and this is normally only achieved at full power. It does depend on what monolight you chose to use.
Aressem Goldmember More info | May 08, 2012 07:40 | #3 PhotographersWorldWide wrote in post #14397545 All except the ST-E2 will trigger a monolight by using the monolights in-built optical slave or by adding a receiver in the case of the Cactus v5. For HSS the monolight needs to have a longish flash duration and this is normally only achieved at full power. It does depend on what monolight you chose to use. Wrong. HSS and Hypersync (Pocket Wizard technology) essentially accomplish the same thing but in different ways. It is important not to get them mixed up. HSS is a speedlight-only technology. Moonlights are not capable of HSS. However, studio monolights and heads can achieve above x-sync speeds via PW's Hypersync technology. Ryan Mackay WEBSITE
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | May 08, 2012 07:49 | #4 ChadAndreo wrote in post #14397073 I was wondering if it was possible to trigger a monolights using any combination of the following gear: Nissin Di866 mkII YN-560 Cactus v5 ST-E2 optical slaves If not, what other options are there besides using TTL triggers(radio poppers, tt5,etc)? Precisely what are you asking about? Your thread title specifically asks about "HSS" which is Canon's "High Speed Sync" mode for their Speedlites. That mode is different from what any monolight can do. Skip Douglas
Aressem Goldmember More info | May 08, 2012 07:54 | #5 SkipD wrote in post #14397978 Precisely what are you asking about? Your thread title specifically asks about "HSS" which is Canon's "High Speed Sync" mode for their Speedlites. That mode is different from what any monolight can do. When functioning in HSS, a Speedlite actually emits a very rapid string of very short flash pulses. In effect, it is producing "continuous" light for the illumination during the entire shutter travel time. There are some experimental tricks that have been discussed here to get certain monolights, triggered with certain hardware, to allow very high shutter speeds to be used. The problem that is common to all of these solutions (typically called "hypersync") is that there is no flash meter in the world that can provide information for the exposure settings in the camera. Using "hypersync" is purely a trial-and-error thing. Well said! Ryan Mackay WEBSITE
chrisandaivi Senior Member 718 posts Joined Apr 2010 Location: Virginia Beach More info | May 08, 2012 12:11 | #6 SO...there is no way at all to trigger a monolight above 1/250th? execpt using pocket wizards? Gear: 5D Mark II, Canon 85mm 1.2 L ,Canon 17-40mm F4L
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | May 08, 2012 12:22 | #7 chrisandaivi wrote in post #14399290 SO...there is no way at all to trigger a monolight above 1/250th? execpt using pocket wizards? Do you understand how a focal plane shutter works? This is critically important to understanding how to synchronize a flash source with our Canon SLRs. Skip Douglas
chrisandaivi Senior Member 718 posts Joined Apr 2010 Location: Virginia Beach More info | May 08, 2012 13:07 | #8 Yes... I was just wondering Gear: 5D Mark II, Canon 85mm 1.2 L ,Canon 17-40mm F4L
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | May 08, 2012 13:24 | #9 chrisandaivi wrote in post #14399591 Yes... I was just wondering The "max sync speed" for a focal plane shutter is the fastest shutter speed that will have the entire film/sensor area uncovered by the shutter at the same time. At shutter speeds faster than the "max sync speed", the trailing shutter is already closing off the first part of the film/sensor area before the leading shutter has fully uncovered the last of the film/sensor area. Skip Douglas
PhotographersWorldWide Senior Member 395 posts Joined Mar 2008 Location: UK More info | May 08, 2012 15:14 | #10 All except the ST-E2 will trigger a monolight by using the monolights in-built optical slave or by adding a receiver in the case of the Cactus v5. For HSS the monolight needs to have a longish flash duration and this is normally only achieved at full power. It does depend on what monolight you chose to use. Aressem wrote in post #14397946 Wrong. HSS and Hypersync (Pocket Wizard technology) essentially accomplish the same thing but in different ways. It is important not to get them mixed up. HSS is a speedlight-only technology. Moonlights are not capable of HSS. However, studio monolights and heads can achieve above x-sync speeds via PW's Hypersync technology. Where did I mention Hypersync? I didn't.
Aressem Goldmember More info | May 08, 2012 18:59 | #11 PhotographersWorldWide wrote in post #14400197 All except the ST-E2 will trigger a monolight by using the monolights in-built optical slave or by adding a receiver in the case of the Cactus v5. For HSS the monolight needs to have a longish flash duration and this is normally only achieved at full power. It does depend on what monolight you chose to use. Where did I mention Hypersync? I didn't. I don't have PW's and I can sync at up to 1/8000s, - so because I don't have PW's I'm not using Hypersync, and I'm not using HSS or FP mode at all, I prefer to retain my flash output. I can do it with optical slaves, I can do it with radios, I can do it with sync cables. Its all down to the shutter timing in the camera and using the correct light source. Hell, I can even do it with flashbulbs! Monolights (I don't know what moonlights are) with longer flash durations are easily capable of this, particularly with longer flash durations as I pointed out - and no special equipment with fancy names attached to them.. after all this technique has been around a LONG time before PW thought of giving it a name , slapping it in a box and selling it. So where exactly am I wrong? You said... PhotographersWorldWide wrote in post #14397545 For HSS the monolight needs to have a longish flash duration and this is normally only achieved at full power. It does depend on what monolight you chose to use.
Ryan Mackay WEBSITE
PhotographersWorldWide Senior Member 395 posts Joined Mar 2008 Location: UK More info | May 09, 2012 06:48 | #12 Aressem wrote: Wrong. HSS and Hypersync (Pocket Wizard technology) essentially accomplish the same thing but in different ways. Aressem wrote in post #14401358 That aside, I'll be the first to admit that I certainly don't know it all. I'd like to know more about how you manage 1/8000 with a studio strobe and no Hypersync. Please elaborate ![]() So, not wrong then... and there's me thinking you were some self appointed expert, eager to point out I was wrong and pointing me to where I could learn more about Hypersync - which I never mentioned.. but you did..(?)
elv Goldmember 1,491 posts Likes: 181 Joined Jul 2006 More info | May 10, 2012 00:19 | #13 ChadAndreo wrote in post #14397073 I was wondering if it was possible to trigger a monolights using any combination of the following gear: Nissin Di866 mkII YN-560 Cactus v5 ST-E2 optical slaves If not, what other options are there besides using TTL triggers(radio poppers, tt5,etc)? You can try tail method "hypersync" by putting the Di866 on the camera hotshoe set manual power and HSS, and have that trigger the monolights optic slave. You often need full power but it depends on your lights so try low power as well. Otherwise the Pixel King or Phottix Odin will do basically the same thing as above a little more conveniently. One other manual trigger is the Ojecoco H-550 which actually has a manual timing adjustment (a bit like PocKetwizards TT5, but its a manual dial not software adjusted).
May 10, 2012 03:02 | #14 I have tried that method with no luck. HSS only works in ETTL mode and the preflashes trigger the V5s prematurely even with the canon specific optical trigger from flash zebra. Photographer + Cinematographer
PhotographersWorldWide Senior Member 395 posts Joined Mar 2008 Location: UK More info | May 10, 2012 08:43 | #15 Your Nissin Di866 mkII has an x-sync socket. Can't your V5's just plug into that to obtain a sync signal?
| Latest registered member is semonsters 1682 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
