Thread started 08 May 2012 (Tuesday) 06:33
Yongnuo like flash with SHORT flash duration (for action)
TijmenDal
May 08, 2012 06:33 |  #1
Hi guys,
I would just like to know if there is a flash out there that's cheap, reliable and sturdy with a SHORT flash duration. I've got a YN-560 at the moment and am happy with it, but the flash duration of 1/200 is way too long for action (night photography).
Any alternatives?
Regards
//Tijmen
http://www.flickr.com/​photos/tijmendalexternal link
Gear
______________
flickrexternal link
_____________
JakAHearts
May 08, 2012 07:58 |  #2
What are you shooting? Youre a bit confused on how the whole flash thing works. The 1/200th is just the shutter speed that the camera is operating at. The actual flash duration is probably closer to 1/8000th of a second (just a guess) and actually gets shorter as you lower the power on the flash itself. So... what are you shooting that is moving so fast?
Shane
Aressem
Gallery: 39 photos
May 08, 2012 08:11 |  #3
The 1/200 number you are referring to is your cameras max flash sync speed which is a physical limitation of your camera governed by your first and second shutter curtains. The 5D II flash sync is around 1/160-1/200 whereas my 7D has a max flash sync speed of 1/320.
That aside, what you need to understand is that when working with flash, your ability to freeze moving objects is no longer dictated by your shutter speed but instead the flash duration. Flash durations vary from one flash to another (significantly) and some units produce the shortest (fastest) durations at full power while others achieve their shortest duration at the lowest power setting.
Watch this to get a better understanding of why your camera has a max flash sync
http://www.markwallace​photography.com …hp?id=13750145&​alb=262294 (external link)
Ryan Mackay WEBSITE (external link) | FACEBOOK (external link) | GEAR LIST | Buy & Sell Feedback: 1, 2, 3, 4, 5
SJRobbins
May 08, 2012 08:11 as a reply to  @ JakAHearts's post |  #4
If you want to shoot faster than your camera's flash sync speed then you'll either need a flash that does HSS (High Speed Sync), or a trigger that supports some variant of Hypersync.
As far as I know there aren't any cheap 3rd party flashes that support HSS. There are cheap triggers that support Hypersync with cheap flashes, although it relies on firing them on full power all the time and it's not as simple as using HSS.
Canon 60D | Tamron 17-50mm f2.8 nonVC | Canon EF-S 60mm f2.8 Macro | Canon EF-S 55-250mm f4-5.6 IS | Canon 50mm f1.8 MkI | Carl Zeiss Jena DDR 135mm f3.5 | Loads of flashes 'n' stuff
Christina
May 08, 2012 08:14 as a reply to  @ JakAHearts's post |  #5
Shane's right. You need to learn the foundation of how flash works. Flash duration and shutter speed are not the same. If you need a faster shutter speed, you need to enable high speed sync. Check out this article.
http://cameradojo.com …lash-101-high-speed-sync/ (external link)
Christina - Pittsburgh Wedding Photographer (external link)
Syncopated Pictures (external link)
http://christinamontem​urrophotography.com/bl​og/ (external link)
SkipD
Joined Dec 2002
May 08, 2012 08:17 |  #6
JakAHearts wrote in post #14398013 (external link)
The YN-560 does, in fact, have a very slow duration at full power. I found a review in which this was confirmed by measurement.
Skip Douglas
Aressem
Gallery: 39 photos
May 08, 2012 08:22 |  #7
SkipD wrote in post #14398091 (external link)
Well don't we feel stupid now! Haha - yup! Confirmed... I just googled it. What a surprise. Although really, I'm not that surprised considering its a $60 unit.
JakAHearts
May 08, 2012 08:36 |  #8
I cant find the article. How slow are we talking?
I found one that states 1/200th at full power. Thats crazy slow. Im still curious on what the OP is shooting at night that needs such a short flash duration.
Shane
SJRobbins
May 08, 2012 08:42 |  #9
This seems to suggest 1/640 is fine:
http://betterfamilypho​tos.blogspot.co.uk …-yn-560-flash-update.html (external link)
Bearing in mind that that's the full power exposure time - if you're constantly shooting a Yongnuo at full power you're a) going to nail recycle times and b) asking for it to shutdown on you :)
TijmenDal
May 08, 2012 10:24 |  #10
This is why I'm asking. I understand how sync speed works, and that's why I was confused at first as well. The flash duration and sync speeds are almost the same, hence the misunderstanding.
I haven't really done any testing myself but I just find that sometimes the flash duration is too long. Should probably dig a little deeper into this.
SJRobbins wrote in post #14398201 (external link)
I've seen this article, but from what I see I wouldn't say it's 1/640. No data to back this up though.
Does anyone know how I could measure the flash duration?
And thanks everyone for the input!
//Tijmen
Gear
______________
flickrexternal link
_____________
JakAHearts
May 08, 2012 10:25 |  #11
Tijmen, what are you shooting? :D
Shane
TijmenDal
May 10, 2012 06:49 |  #12
JakAHearts wrote in post #14398720 (external link)
I'm planning on shooting skateboarding at night, but when trying to freeze cars, that was impossible so...
//Tijmen
Gear
______________
flickrexternal link
_____________
Wilt
May 10, 2012 23:14 |  #13
The YN-560 indeed does have 1/200 flash duration at max power (GN58). Speedlights all seem to have slowest flash duration at max power...my Metz 54MZ, whose slowest duration is also at max power, is 1/200 as well. Canon is so secretive about the duration of the 580EXII, it does not bother to include information in the user manual or on the Canon USA web site.
TijmenDal
May 11, 2012 03:56 |  #14
Wilt wrote in post #14414067 (external link)
It's true most flashes have shorter flash durations when not used at full power, but most speedlights have outputs of 1/800 and faster...
//Tijmen
Gear
______________
flickrexternal link
_____________
asamimasa
May 11, 2012 04:02 |  #15
So speedlights and the PCB Einstein use an flash system called IGBT.
As far as flash duration is concerned, these flashes will get slower as you power up.
In contrast, a typical studio strobe (any other PCB strobe, elinchroms, even cheaper Calumet/Flashpoint strobes) gets a faster flash duration as you increase power.
If you want to continue using strobes, you may just have to lower the power as much as possible and bump up the ISO within reason. And get the lights in closer. Speedlights should get some pretty darn fast maximum flash durations, but that only happens at the lower 1/64 ~1/128 region
Gear List here
11,745 views & 0 likes for this thread, 10 members have posted to it.
1059 guests, 104 members online
