Thread started 08 May 2012 (Tuesday) 13:34
Should I replace the ink cartridges for my Epson 3880?
joonrhee
May 08, 2012 13:34 |  #1
So, I bought a gently used Epson 3880 yesterday. Original owner said he bought the printer few years back but never had to replace the ink cartridges yet. I tested out some prints last night and they look phenomenal!!
At this moment, vivid light magenta and light light black is showing very low level. I just went ahead and bought the whole 9 new inkset cartridges from Adorama.
I've read somewhere that it's the most ideal to use the inks within 6 months from installing in the printer. If this is true, all the original inks have been in the printer for few years. Once again, the prints are coming out perfectly fine. Or I'm just not so keen in detecting details.
Other than 2 inks mentioned above, most are at 50%, 30%, and 20% ink levels. I think the photo (or matte) black ink is at 70%.
Here is my question. Should I just replace all cartridges and start fresh? Or just replace the ones that are very low? One thing I don't want to do is ruin the printer head. Any advice would be greatly appreciated. Thanks.
a7RII • a7C • V12 • L21 • S24GM • S85
Full Gear List & Feedback
SmugMug (external link)
Lowner
"I'm the original idiot"
May 08, 2012 13:39 |  #2
Epson don't guarantee any ink cartridge older than 6 months. But I've kept carts a lot longer than that without issues, so the one I had an issue with was probably faulty from new.
The expense of switching carts unneccesarily would prevent me doing it. I don't believe it would damage the print head, why would it?
Richard
joonrhee
May 08, 2012 16:38 |  #3
Yep, that's what I'm thinking... It's working just fine and printing perfect. I guess I'll just replace the low inks. Thanks! :)
gmikol
May 08, 2012 21:38 |  #4
The 3880 is an amazing printer. It also has the unique capability of replacing inks mid-print without interruption. Ink is expensive (as you well know, having bought a full set). There's no point in replacing a cartridge until the printer demands it.
--Greg
joonrhee
May 09, 2012 00:02 |  #5
gmikol wrote in post #14402104 (external link)
--Greg
Do you normally replace the cart when the ink level starts blinking or wait until there is a missing color on the prints?
dmward
Gallery: 29 photos
May 09, 2012 00:11 |  #6
Even with less capable printers, its not necessary to replace an ink cartridge until the printer stops.
I have had my R2880 stop half way through a print, replaced the empty cartridge and it finished the print. It was impossible to see where the pause occurred. I expect that the 3880 is as good or better.
I'll find out shortly. I have three carts that are showing about 20% so will probably get to do an in print replacement.
I would be reluctant to replace before the printer stops. That ink is way too expensive to waste. :-)
joonrhee
May 09, 2012 00:27 |  #7
dmward wrote in post #14402880 (external link)
Sounds fair and good! I'll keep running it until it runs dry. :D
Lowner
May 09, 2012 03:36 |  #8
joonrhee wrote in post #14402836 (external link)
Neither. My R2880 tells me on the monitor that the ink has run out (rather than just low) early enough that I cannot tell on the print. In fact I have changed cartridge mid print with no ill effects.
Richard
joonrhee
May 09, 2012 11:02 |  #9
Thanks Richard. I'll just keep printing! :D
3,112 views & 0 likes for this thread, 4 members have posted to it.
874 guests, 128 members online
