Thread started 11 May 2012 (Friday) 04:02
Syncing 20D & 30D parameters
geoffbubbles
Joined Sep 2011
May 11, 2012 04:02 |  #1
I'm having troubles synchronising parameters between two cameras, the 20D and the 30D.
I know about the new Styles, but after comparison tests I find the differences so subtle as to not make much differerence in practise.If I were to select my favourite style it would be Autumn Hues.
I was under the impression that Neutral on 30D was equivalent to Para 2 0n 20D but I found that Neutral was less punchier than Para 2.On looking up Details I found that the measurents were different too ! Whilst the 30D showed numbered settings, the 20D showed High, Mid High, etc.
As I like to work with two cameras is there any way I can synchronise the two cameras to provide similair results without having to resort to detailed comparison tests ?
I'm sure that I'm not the only one to have come across this problem.
number ­ six
fully entitled to be jealous
May 11, 2012 14:01 |  #2
You can shoot in raw and use DPP for editing. Current versions of DPP will allow you to apply Picture Styles (like the 30D) to your 20D images. The camera parameters set in your 20D will be ignored.
At least I assume so - don't have a 20D. But that's the way it works with raw images (.CRW) from my 300D.
Give it a try...
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
537 views & 0 likes for this thread, 2 members have posted to it.
1283 guests, 130 members online
