Thread started 11 May 2012 (Friday) 10:58
Which light stand are you using?
NJKEV
Joined Apr 2011
May 11, 2012 10:58 |  #1
I’m looking to pick up another light stand and was just curious to know what everyone else is using.
v35skyline
May 11, 2012 12:03 |  #2
What do you plan on using this light stand with? Speedlite? Strobe?
I use Manfrotto's 1052BAC and 420b as well as LumoPro's LP605 for speedlites.
X100s | X-Pro1 | X-T1 | XF 14 | XF 18 | XF 35 | XF 56 | XF 60 | XF 10-24
Gear List & Feedback
hawk911
May 11, 2012 12:16 |  #3
I have promaster LS2 (2 of them) and 4 of the Manfrotto small stands that came with my elinchrom kits. I prefer the LS2 for normal stands, but would be nice if they were air cushioned, not springs. I believe the LS3 might be air cushioned.
HAWK Photography Gallery (external link) FB Fan page (external link)|_My gear: 5d3, 70D & 40D (all gripped), 580exII, 550ex, Canon 24-70 L & 85 f1.8, 50mm f1.4; Tamron 70-200 SP Di VC, Canon 18-55, Sigma 1.4xtc; Elinchrom Whore, Skyport triggers, Speedotron BD and Kacey Grid, Vagabond minis
Teeth
May 11, 2012 12:16 |  #4
Speedlites on LumoPro's LUM5005 (8ft AC Stand). Basically, the old Strobist stuff sold from MPEX.
Scott | gear | flickr (external link) | website (external link)
scorpio_e
May 11, 2012 12:40 |  #5
I have different sizes for different uses.
Rave 8' stand
Manfrotto 5001B Inch Nano Stand
Promaster SystemPro LS-3
Paul Buff TS13AC
www.steelcityphotograp​hy.com (external link)
SJRobbins
May 11, 2012 13:06 |  #6
Only speedlights here, but I use Konig stands.
Canon 60D | Tamron 17-50mm f2.8 nonVC | Canon EF-S 60mm f2.8 Macro | Canon EF-S 55-250mm f4-5.6 IS | Canon 50mm f1.8 MkI | Carl Zeiss Jena DDR 135mm f3.5 | Loads of flashes 'n' stuff
JakAHearts
May 11, 2012 13:22 |  #7
http://strobist.blogsp​ot.com/2012/05/q-c-stands.html (external link) :D
Shane
mike_d
May 11, 2012 13:32 |  #8
I have a couple of Manfrotto 1052BAC's. I really like that they fold flat and snap together for transport and storage. I want to get a couple more to use as background support.
aroundlsu
May 11, 2012 13:35 |  #9
I love big c stands, Matthews combo stands, and Matthews medium and high rollers. I also just got a Mole Richardson junior roller in a deal that is pretty nifty. All these stands are expensive and must be used carefully to avoid expensive accidents but they will allow you to put anything practically anywhere.
If you get a c stand I urge you to get The Grip Book to learn to properly use it. They are called century stands because it takes a century to learn to properly use one. If you don't set it right it will fall and hurt someone. I have been getting the avengers from amazon with free prime shipping. They are bigger than the Matthews c stands.
Teddy Smith, SOC
IATSE Local 600 Cinematographer
Darkwand
May 11, 2012 15:39 |  #10
As of today a Manfrotto 1004BAC.
I got a little worried about the weight of my new 1200RX and instead of using a no name light stand which I have and have used with speedlites I chose to get that one.
That it reaches 3.66 meters was also a deciding factor.
It was more then i wanted to spend in total but i'm happy with it and i love the way the legs fold up.
Adrian My Flickr (external link)
Canon 5D MkIV, Canon 6D, Canon 7D, Canon 18-55mm 3.5-5.6 IS, 17-55mm f/2.8 IS USM, 50mm f/1.4 USM, 85mm f/1,8 USM, Sigma 70-200mm HSM Macro, 10-20mm f/4-5,6
Manfrotto 055 CXPRO4 + 498RC2, Manfrotto 410 Junior, Elinchrom: RX1200, 2x BRX250 , Dlite-it 4 and 2, Canon 580EXII
Gizmo1137
May 11, 2012 16:00 as a reply to  @ Darkwand's post |  #11
You did not mention for what kind of lights (speedlights or studio flash) but what I use for my speedlight is a lightweight Bogen (sorry forgot the model#) For my Speedotron I use Manfrotto Alu Master 3 Riser 12' AC Stand. I love them as they are very stable, evem with fairly large softboxes, after a few smashed fingers I really like the air cushion feature and they nest together nicely when folded for storing.
Best, Bruce
bobbyz
May 11, 2012 16:00 |  #12
aroundlsu wrote in post #14416707 (external link)
Anythiny special we should know. Rented couple of times, seemed pretty easy to use.
Fuji XT-1, 18-55mm
aroundlsu
May 11, 2012 16:55 |  #13
bobbyz wrote in post #14417406 (external link)
Lots of things.
1. Knuckle always on the right of the hanging weight. Righty tighty, lefty loosey. I have seen young grips get yelled at on set for breaking this rule. Bill Clinton was once whacked in the head from a c stand that had the knuckle on the wrong side and loosened.
2. Tall leg points towards the weight if you are hanging something off the arm.
3. Sandbag goes on the tall leg. Never let the sandbag touch the floor. If its a big sandbag you can wrap it around the shaft of the stand.
4. Put tennis balls on the feet of the stand if in someone's house.
5. When putting the stand away line up all the knuckles and tighten them all. Nothing is more annoying then picking up a stand and a shaft goes flying out.
6. Never leave the arm pointed out at eye level with nothing on it. Someone will run into it. If you must, put a tennis ball over it.
7. When carrying a stand and you approach a corner or a doorway or you need to carry it through a bunch of people yell Hot points! Hot points! so you don't whack someone with the stand.
Those are the most common mistakes I see grips and assistants make.
Teddy Smith, SOC
SethDuBois
Joined Nov 2011
May 11, 2012 17:03 |  #14
My one and only Impact 8' air cushioned (external link).
It does the job, but I'll definitely be investing in better soon enough. It feels flimsy when extended all the way with a 43" umbrella on it.
Gear & Feedback|Flickr (external link)|500px (external link)|Facebook (external link)
www.sethdubois.com (external link)
eddieokeefe
Joined Jul 2011
May 11, 2012 19:06 |  #15
Manfrotto 1004's - they stack flat and snap together. amazing stands.
8,599 views & 0 likes for this thread, 23 members have posted to it.
1115 guests, 173 members online
