when I go "Save As", and select the JPEG in the "Format section, it adds ".eps" not the .jpg format.
The only way to get the .jpg option is to select the "multi-picture format", from the format list, which then brings up the ".jpg".
smclaren Member 213 posts Joined Mar 2009 Location: London More info | May 12, 2012 13:41 | #1 when I go "Save As", and select the JPEG in the "Format section, it adds ".eps" not the .jpg format.
tonylong ...winded More info | May 12, 2012 16:00 | #2 I don't have CS6, but what is the image originally -- and is it in 8 bit or 16 bit? Tony
May 13, 2012 00:42 | #3 tonylong wrote in post #14421733 I don't have CS6, but what is the image originally -- and is it in 8 bit or 16 bit?
tonylong ...winded More info | May 13, 2012 01:21 | #4 So, scroll up and down the file formats -- what do you see? Tony
ssim POTN Landscape & Cityscape Photographer 2005 10,884 posts Likes: 6 Joined Apr 2003 Location: southern Alberta, Canada More info | The attached print screen from my CS6 is the order for which my file types show up. This is for an 8 bit save. If you are having to select the multi-Picture format to get it to give you JPG then it would seem to be off in reading the order of the file formats. If you have tried all the standard things like restarting Photoshop and rebooting your system I would then lean towards re-installing the program. Something is out of order on your system and this might fix it. I would also check for updates before you try this. This can be found under the help menu. Image hosted by forum (595689) © ssim [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. My life is like one big RAW file....way too much post processing needed.
May 13, 2012 03:48 | #6 tonylong wrote in post #14423540 So, scroll up and down the file formats -- what do you see? All the formats are there as per the others post's screen dump, but when i click on the jpeg, it put the .eps in the save select.
RichSoansPhotos Cream of the Crop 5,981 posts Likes: 41 Joined Aug 2007 Location: London, UK More info | May 13, 2012 03:58 | #7 Permanent banHow many times has this happened? Do you have a mouse that has a scroll wheel in the middle?
May 13, 2012 12:23 | #8 400dabuser wrote in post #14423832 How many times has this happened? Do you have a mouse that has a scroll wheel in the middle? Have done a full re-install, it happens every time.
kirkt Cream of the Crop More info | May 13, 2012 12:28 | #9 Do you have your preferences set up to point your cs6 install to a previous (say cs5) plug-ins folder in the "Additional Plug-ins Folder" preference? If you point cs6 to the cs5 plug ins folder (to use third party plugins without having to reinstall them) then you are also telling cs6 to use cs5 plugins for saving files, etc. this is confusing CS6. If you want to access already installed third party plugins from another folder, move them out of the previous cs plug in folder, into a separate folder outside the photoshop folder structure. Then point cs6 to this folder and see if that works. Kirk
kirkt Cream of the Crop More info | May 13, 2012 17:58 | #10 Also read this: Kirk
ssim POTN Landscape & Cityscape Photographer 2005 10,884 posts Likes: 6 Joined Apr 2003 Location: southern Alberta, Canada More info | May 14, 2012 01:47 | #11 That is an interesting read. I can't see where the OP has done this but maybe he has. For the OP is this the free download beta version of CS6 or one you have already bought and received. As far as I can find via internet searches this is unique to you so it has to be something locally but at this I would suggest that you should post the question on the Adobe Photoshop Forum My life is like one big RAW file....way too much post processing needed.
Be onto Adobe ALL day:
No it has not worked, so back to adobe tomorrow.
| Latest registered member is Monkeytoes 1364 guests, 163 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
