Thread started 13 May 2012 (Sunday) 09:17
finding the same picture on computer
phonedrn8
May 13, 2012 09:17 |  #1
not sure if right loaction, but here it goes
I looked but not found a good program that will find duplicate photos with differnt file names.
I have 3 computers and a back up hard drive, that have multi pictures in differnt places, some same file name some, copy 1-2- eexc..., but it the same picture, i have a 5 backup files of pictures that have diffent amounts of pictures. I'm trying to clean up and relocate all my photo onto 1 deciated HD for photos only
What have the people used, like, and what to carefull of?:confused:
tonylong
...winded
Gallery: 60 photos
May 13, 2012 16:48 |  #2
I've heard of software that searches out duplicates, but I don't have anything and can't recall specifics. Maybe someone else will chime in here.
What software are you using to sort through/organize your photos?
Tony
KirkS518
Joined Apr 2012
May 13, 2012 19:33 as a reply to  @ tonylong's post |  #3
I have Auslogics Duplicate File Finder (external link) that was recommended in another thread. Seems to do a good job across different folders, but I haven't tried it on multiple drives.
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
Merovius
Joined Jul 2011
May 13, 2012 23:07 |  #4
I use one called, imaginatively enough, just plain old "Duplicate File Finder". It's old - hasn't been updated in years, but it works fine on Windows 7 64 bit, and also works across multiple folders or drives. It's what I used when I decided I needed to clean up my image library.
http://www.softpedia.c​om …plicate-File-Finder.shtml (external link)
--Howard
SmugMug (external link) | G+ (external link) | HJW Photography (external link)
7D Mark II | 6D | Σ 35mm f/1.4 | EF 50 f/1.4 | EF 24-70 f/2.8L II | EF 135 f/2L | EF 70-200 f/2.8L IS II | EF 100 f/2.8L Macro | Tamron 150-600
Sparky_79
Joined May 2012
May 14, 2012 12:46 |  #5
The best is backing up files I have ZenOK Online Backup (external link) and No problems and it performs everything it says it is capable of doing. Easy to set up and use. Very great tool to provide your remote access to multiple pc's
mike1812
May 14, 2012 14:35 |  #6
The problem that you are going to have is being able to search across all 3 computers (because I'm assuming you're concerned that you have "image 1" on pc 1, pc 2, AND pc 3. The Auslogic software faq indicates it does NOT work on network drives. You may wind up having to move all the pictures onto a single drive then run duplicate file software against that single large library.
Haven't used the above two programs, but I have another one for you to try: http://www.identicalfi​les.com/Home (external link). I've used it in the past, and like any of these tools, you need to be very careful of what you are deleting, because it is easy to get wrapped up on "clean up" and accidentally delete too much.
EF 135L | EF 70-300 L | ST-E3-RT | (4) Einstein E640s | Sekonic L-758 | Sony A7RII Gripped | Sony A7RIII Gripped | Sony 16-35GM | Sony FE 55 f/1.8 | Sony FE 85 f/1.4 GM | Sony FE 100-400GM | Sony 1.4x | Sony HVL-60M | Sigma MC-11 | Flashpoint Xplor AD600 | Flashpoint AD200 (2)| Flashpoint AD360 | plus too many doodads to list
Traci_Ann
I'm a masochist
Gallery: 27 photos
May 14, 2012 20:24 |  #7
I use Vistanita Duplicate Finder, it has worked very well for me. But seems they have discontinued sales.
Sevas Tra
1,149 views & 0 likes for this thread, 7 members have posted to it.
1285 guests, 117 members online
