Thread started 13 May 2012 (Sunday) 10:49
Premiere (5Dmk2 files) zoom help
dynamitetony
May 13, 2012 10:49 |  #1
i have imported some files straight from my 5Dmk2 in to adobe premiere
when i look at the files on the left preview window , they look fine
but when i drop them on the timeline and look on the right output window they seem zoomed in
can anyone help with why ?
see here
thank you in advance
5Dmk4 : 5Dmk3: Sigma 24mm F1.4 :Sigma 35mm F1.4 : Canon 50mm F1.4 : Canon 85mm F1.8 : Canon 100mm F2.8 Macro : Canon 24-105 F4 : Canon 70-200 F2.8L mkii : Flashes, lights & Stuff
AKphoto23
May 13, 2012 13:30 |  #2
I believe because the one on the left is a "Source" window which is used mainly to preview unedited clips before adding to your time line so it automatically fits the video to the viewing box.
Whereas the right is a "Program" viewing box which is used to view the video off of your timeline and therefor how it will view once exported say to a DVD or viewed on youtube.
I think the reason for this is because your paramaters for you timeline settings arent matching up with your native clip size. For instance if the timeline paramaters are set to 720p and your video clip is 1080p you going to encounter some clipping on the viewing area of your media. You should be given the option to set your parameters when you make a new project in premiere. Make sure they are set correctly to match your video.
Hope this helps!
dynamitetony
May 13, 2012 15:02 |  #3
thank you for taking the time to answer.
i found a setting on the right click menu called "scale to frame size" and that has solved it
AKphoto23
May 13, 2012 15:21 |  #4
Glad it was something simple!
821 views & 0 likes for this thread, 2 members have posted to it.
1338 guests, 131 members online
