Thanks everybody, we sure appreciate all your comments.
jimi60d wrote in post #14430684
Excellent shots, Kenn. My wife got an SX40 about 3 months ago. She was wondering if you could describe how you got these shots.
Jim - Here is the exif data for the first shot above (Downy fledgling). I've highlighted a few settings in bold, which may be of particular interest:
Camera Model Name Canon PowerShot SX40 HS
Shooting Date/Time 5/9/2012 9:04:46 AM
Shooting Mode Manual
Tv (Shutter Speed) 1/500
Av (Aperture Value) 5.8
Light Metering Spot
ISO Speed 100
Lens 4.3 - 150.5 mm
Focal Length 150.5 mm (840mm equivalent)
Digital Zoom None
Image Size 4000x3000
Image Quality Fine
Flash Off
White Balance Day Light
AF Mode Continuous AF
Custom Color
Parameters:
Contrast -1
Sharpness -2
Saturation -1
Color Space sRGB
File Size 2641 KB
Drive Mode Continuous shooting
In summary: We generally shoot close (the Downy is a full-frame uncropped shot taken from @14ft, and with 840mm even the portrait shots often don't require deep cropping. We shoot hand-held in Manual mode, so the exposures captured are our fault... The exposure metering modes in these cameras are pretty limited and often struggle to cope, but the EVF is "live-view" so we set exposures based on what we see in the frame, while using the viewer spot meter as a guide. We strive to keep ISOs as low as possible, although the SX40 often does produce surprisingly better results above base ISOs than our other superzoom cams. Note the "detuned" in-camera jpeg settings... Sharpness Minimum, Contrast and Saturation both reduced. Ive found this gives me much better lattitude in post, and let's me develop our shots with cleaner detail and better overall IQ than is produced sooc by the jpeg engine. And we use the heck out of Continuous shooting... While not fast by DSLR standards, this helps us get a lot of shots from which to choose the best poses and sharpest captures for processing.
And btw, Temple took the SX40 shots in this set.
Hope this is helpful.
Kenn
