Thread started 13 May 2012 (Sunday) 22:56
How to slide slider carriage smoothly?
thedcmule2
Joined Nov 2011
May 13, 2012 22:56 |  #1
Besides paying for a more expensive slider, does anyone have any tips on moving the carriage of a slider (specifically the basic glidetrack sd-100) in a smooth constant motion? I keep having small shakes stops or jerks as i do it.
Maverick530
Joined Jan 2012
May 14, 2012 02:31 |  #2
try this, Attach a big rubberband to whatever you are pulling, That way it ads tension while taking out vibration. (pull the rubberband)
6D |60D | 24-105 L | 50mm 1.8 | battery grip | 18-135 |bw! |
gibsonla
May 14, 2012 12:55 |  #3
Always use a push/pull forward or back motion. Try and add as much weight as you can to the carriage. More weight will give you a more stable pull.
Michael L. Solomon
DP/AC/Colorist
www.SolomonM.com (external link)
ARTnVIDEO
Joined May 2012
May 14, 2012 13:18 |  #4
Adding weight to the base/carriage helps stability, and rubber band helps with creating steady pull .
ben_r_
-POTN's Three legged Support-
May 14, 2012 16:16 |  #5
Move the carriage itself (put your hand on it), not the camera or head thats mounted to it. Practice practice practice.
But yes, seriously this is one of the reasons we buy more expensive sliders (not saying yours isnt as I dont know what it is).
Channel ­ One
Joined Nov 2010
May 14, 2012 18:02 |  #6
thedcmule2 wrote in post #14427472 (external link)
Might I ask a question?
Unloaded does the carriage slide perfectly smooth?
If not double check for debris on the slider bars and if needed give them a good wipe with an alcohol pad or two.
If it does slide smoothly, then the next step is to assure your camera is balanced upon the carriage, that slider (SD) only has the capability of supporting a downward load, as such for the best performance you must have your camera’s center of gravity balanced upon the carriages mount, if you fail to do this, you will be placing a lateral load on the side wheels of the carriage, twisting them against their axles, which will affect your drag and therefore the smoothness of your pan.
Wayne
Do what you love and you will love what you do, that applies to both work and life.
Channel ­ One
Joined Nov 2010
May 14, 2012 18:04 |  #7
ben_r_ wrote in post #14431129 (external link)
Probably this.
http://www.bhphotovide​o.com …D_100_SD_Slider​_39_4.html (external link)
Wayne
thedcmule2
Joined Nov 2011
May 19, 2012 03:08 |  #8
Thanks for the good advice everyone, feel free to chime in if you have more. The rubberband one im having trouble with, it takes a lot of pull to get the carriage to start moving which jerks into motion to start even with a big rubberband- not good for constant motion. Where do I hook it to? How big? Etc
Channel One wrote in post #14431585 (external link)
Wayne
This is a good tip, now to figure out how to balance its center of gravity. I need one of those sliding plates is that what you are implying?
John ­ Sims
May 19, 2012 03:26 |  #9
I have found that attaching the carriage to either end of the slider with big rubber bands help as it gives you a force to work with.
Initially the pull on the band means you are holding the slider back and the then you go through a point of inertia at the middle of the rail when both bands are pulling equally and then have to push against the force of the band.
Because the amount of change from push to pull is completely linear it seems easy to maintain an even speed.
I know its sounds strange but it seems human power doesn't work well against an even load. You'll not believe me until you try it.
John Sims
Canon 60D, 30D, 10D, AE1 & some other stuff
mikez
Joined Feb 2006
Jun 28, 2012 22:28 |  #10
Can someone demonstrate it on a video?
charro ­ callado
Jun 28, 2012 22:32 |  #11
I use a rubber band and a quick wipe of wd-40 on the rails every hour or so. butter smooth.
Orguss
Jun 29, 2012 02:49 |  #12
like other said, rubberband is your friend
4,518 views & 0 likes for this thread, 10 members have posted to it.
1345 guests, 176 members online
