Thread started 15 May 2012 (Tuesday) 11:06
is there a way to fix my classic 5d shutter button?
mantra
May 15, 2012 11:06 |  #1
Hi
is there a way to fix my classic 5d shutter button ?
the camera works, i used a remote shutter and work perfectly
camera service asked me 350€ /450,94$ , shipping not included :(
i guess i'm not good enough to isassemble the camera
is there a way to use an eletronic cleaner spray ?
and try to let it go inside pushing the shutter button?
did you have such issue?
did you solve outside send to mom canon and spend $$$$?
thanks
cheers
canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
3 analogic Hasselblad and 2 anologic Mamiya
number ­ six
fully entitled to be jealous
May 15, 2012 14:12 |  #2
Some POTN members have fixed a sticky shutter button by pouring a small amount of isopropyl alcohol into the battery box.
This thread is about the 30D, but I think your 5D is built the same as the 30D.
https://photography-on-the.net/forum/showthre​ad.php?t=907496
Good luck!
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
crn3371
May 15, 2012 14:58 |  #3
I did the alcohol bit on 30D with good results. There's also some YouTube videos showing how to do it.
John ­ from ­ PA
Joined May 2003
May 15, 2012 16:04 |  #4
mantra, the sticky shutter button is a relatively common problem with Canon dslr cameras. Review the thread at https://photography-on-the.net/forum/showthre​ad.php?t=836663 for a 1 minute sticky shutter fix or go to http://www.youtube.com​/watch?v=tB_gSqyidI0 (external link) for the YouTube video on a fix.
One note, use a relatively fresh bottle of the isopropyl alcohol, 99% if you can find it, 95% as a minimum. When alcohol is exposed to air it absorbs water so an older bottle maya have quite a bit of water content.
Good luck and let us know how you make out.
mantra
May 16, 2012 02:01 |  #5
crn3371 wrote in post #14436151 (external link)
thanks
but does it damage the lcd or the sensor ?
i read after the tip the sensor did change orientation
did you use an electronic cleaner?
John from PA wrote in post #14436447 (external link)
but a electronic cleaner spray , pushing the shutter button , should it work?
thanks
John ­ from ­ PA
Joined May 2003
May 16, 2012 10:42 |  #6
I can't say with any assurance, you do this at your own risk, but I would not spray anything into the parts of the camera because you lose much of the ability to control the areas where the fluid might travel due to the pressure. I would also not use electronic cleaner because depending on what chemical it is, damage to plastics could result. This is not the case with isopropyl alcohol. The procedure has you add a small quantity of alcohol to the battery compartment while maintaining a certain tilt to the camera to move the liquid specifically into the switch area and then you operate the switch to free it up. Being almost pure isopropyl, it evaporates quite rapidly.
Do a search on the web using canon sticky shutter button. You'll find a lot of people have had success and not too many failures. I personally haven't had the need yet.
crn3371
May 16, 2012 10:47 |  #7
Do not use spray cleaner! First, you have little control on where it goes. Secondly, it can have very adverse effects on certainly plastics. I found this out the hard way when I tried spray cleaner on my Apple mighty mouse and literally had it disintegrate in my hand.
John ­ from ­ PA
Joined May 2003
May 16, 2012 12:43 |  #8
crn3371, perhaps you should have just done a copy and paste operation of my response just prior to yours.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
May 16, 2012 13:09 |  #9
John from PA wrote in post #14440962 (external link)
Or perhaps, you both were typing the same basic answer and then submitted the results independently. Happens alot, it just means you both are on the same page... :)
5,589 views & 0 likes for this thread, 5 members have posted to it.
1053 guests, 103 members online
