Thread started 15 May 2012 (Tuesday) 14:15
Do you guys normally use center focus point during events?
5W0L3
Joined Mar 2012
May 15, 2012 14:15 |  #1
or do you use more than 1 AF point?
It would make more sense to me to use only centre point as it gives you way more control at thin apertures to get only what you want in focus.
How about when people are dancing / moving around? Would it be better to use more focus points then...
I've upgraded from a T3i to 5D3 so its a giant leap for me in terms of AF points... from 1 cross type to 43 (i think) cross type lol.. with my T3i i used to use center point for everything because i had no other choice.. but should i be using more points on 5D3 during EVENTS only... i mean obviously during sports you would use more..
Manav
5D III x 2 (gripped) | 35L | 85L II | 100L | 24-70mm IIL | 70-200mm IIL | Some strobes & some speedlights.
Nathan
Can you repeat the question, please?
Gallery: 18 photos
May 15, 2012 14:25 |  #2
Not sure how I might change my shooting habits if I had a 5D3. That said, I use center focus when my subject and composition changes frequently or when I move around a lot. It depends on the event.
I find it easier to use center focus and recompose when shooting candids at weddings because I cannot always plan for composition when I'm scaning the room looking for moments to capture. I can crop later.
When it comes to the dance or cake cutting, I will have selected my focus point because I will have already determined how I want to compose the shot.
If I'm at an event where I don't move around much and I know where my subjects will be, I'll just choose the focus point that makes sense.
Taking photos with a fancy camera does not make me a photographer.
www.nathantpham.com (external link) | Boston POTN Flickr (external link) |
5D3 x2 | 16-35L II | 50L | 85L II | 100L | 135L | 580 EX II x2
robertwsimpson
Joined Jun 2010
May 15, 2012 14:35 |  #3
I almost never use the center focus point.
snake0ape
May 15, 2012 14:53 |  #4
Spot center focus for thin DOF.
Expanded Center focus for fast moving objects.
Normal center for rest of shots.
5Diii | 50D | 8-15L 4| 16-35L 2.8 II| 24-70L 2.8 II | 70-200L 2.8 IS II |Tamy 150-600 | Σ35Art 1.4 | 40 2.8 | Σ50Art 1.4 | 85L 1.2 II | 100 2.8 Macro | Helios 44-3 58mm f2.0 |Helios 40-1 85mm f1.5 | 1.4x & 2x teleconverters
tvphotog
May 15, 2012 15:39 |  #5
I've been playing with the 5D3's 61 points, and it's very quick to shift from center focus to left or right. I'm going to stop focus and recompose as much as possible.
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
robertwsimpson
Joined Jun 2010
May 15, 2012 15:40 |  #6
pick a point, use AI servo, compose and shoot. I've never had a problem hitting focus on my XTi, 50d, t2i, 5d2 or 1d3.
DarthVader
There is no such thing as Title Fairy ever
May 15, 2012 16:08 |  #7
Your 5D III is such a capable AF machine, use the other AF points, use them to your advantage. Not only it will make your shots better composition-wise but also you'll avoid problem with focus-and-recompose when shooting open wide. There is a way to register a point and come back quickly...
http://www.canon1dx.co​m/af-points-area-selection/ (external link) for more info check your 5D III User Manual.
5W0L3 wrote in post #14435967 (external link)
Nikon/Fuji.
Gear is important but skills are very important :)
brokensocial
Joined Apr 2012
May 15, 2012 19:06 |  #8
We use the D700...I personally go back and forth between focus/recomposing and using multiple AF points. It essentially comes down to a question of how much time I have to get the shot.
[mike and frida] photography - we shoot stuff.
chicago wedding photography (external link) | chicago wedding photography blog (external link)
chrismarriott66
Gallery: 14 photos
Joined Jan 2012
May 16, 2012 03:30 |  #9
When shooting events, yes I leave it on centre focus... however, the 50d AF system is a lot more basic than the 5d3 :)
Chris Marriott Photography (external link)| Facebook (external link)
Complete Gear | 1ds iii | 5d iii | 50d | EF 16-35 f2.8 L USM ii | EF 24-70 f2.8 L USM | Σ 70-200 f2.8 ii EX DG HSM | Σ 35mm f1.4 Art | EF 50mm f1.4 USM | EF 85mm f1.8 USM | EF 85mm f1.2 L USM ii | 600EX-RT | 580EX ii | 430EX ii | YN622Cs |
lensfreak
Joined May 2012
May 16, 2012 04:51 |  #10
I have always used single focus point from the start. I never use the multi point system.
CincyTriGuy
Joined Nov 2011
May 16, 2012 08:38 |  #11
robertwsimpson wrote in post #14436337 (external link)
Are you using AI Servo on portraits / glamour? I haven't yet but have been considering giving it a try.
Jason
Canon 1DX Mark II | 16-35 f/2.8L | 24-105 f/4L | 50 f/1.4 | 85 f/1.8 | 70-200 f/2.8L
Tessa
Playing with fire
May 16, 2012 08:57 as a reply to  @ CincyTriGuy's post |  #12
Single point, nearly always center. I only use multiple point AF when shooting flying planes at an airshow.
Pull the lever, Kronk!
EL_PIC
May 16, 2012 09:26 |  #13
Center and Single shot is your best and most reliable regardless of camera.
Recompose if required since events are so easy to do such.
But sometimes you need to vary with Action events.
Nothing ruins your day - and clients - more than OOF.
The new 5D MKIII appears more capable with outside edges and multi shot continous.
The very delayed 1DX will be interesting at that high FPS and AI Servo.
EL_PIC - RIT BS Photo '78 - Photomask Engineering Mgr
Canon DSLR - Nikon SLR - Phase One 60MP MFDSLR
http://www.Photo-Image-Creations.com (external link)
http://www.musecube.co​m/el_pic/ (external link)
http://www.facebook.co​m/PhotoImageCreations (external link)
robertwsimpson
Joined Jun 2010
May 16, 2012 09:49 |  #14
I use AI servo on everything. I take 2 or three shots to make sure that one of them is in focus, but I like it. you've got all those points to choose from, why would you only use the center one?
CincyTriGuy
Joined Nov 2011
May 16, 2012 10:20 |  #15
robertwsimpson wrote in post #14440066 (external link)
Well I'm constantly moving around through all of my points, but I'm usually in One Shot for portraits / glamour. So using back button focus, how would you use AI Servo for portrats? Focus on an eye, keep AF-ON depressed, and shoot?
Jason
5,149 views & 0 likes for this thread, 21 members have posted to it.
2798 guests, 136 members online
